All the lepton masses from G, pi, e
  • Level: Graduate
  • Thread starter Thread starter arivero
    Lepton Pi
Multiple poll: Check all you agree.
  • Logarithms of lepton mass quotients should be pursued.
    Votes: 21 26.6%
  • Alpha calculation from serial expansion should be pursued
    Votes: 19 24.1%
  • We should look for more empirical relationships
    Votes: 24 30.4%
  • Pythagorean triples approach should be pursued.
    Votes: 21 26.6%
  • Quotients from distance radiuses should be investigated
    Votes: 16 20.3%
  • The estimate of magnetic anomalous moment should be investigated.
    Votes: 24 30.4%
  • The estimate of Weinberg angle should be investigated.
    Votes: 18 22.8%
  • Jay R. Yabon theory should be investigate.
    Votes: 15 19.0%
  • I support the efforts in this thread.
    Votes: 43 54.4%
  • I think the effort in this thread is not worthwhile.
    Votes: 28 35.4%
  • Total voters
    79
492 replies · 176K views · last reply
CarlB said:
[tex]M = \left( \begin{array}{ccc}<br /> \sqrt{2} & e^{i\delta} & e^{-i\delta} \\<br /> e^{-i\delta} & \sqrt{2} & e^{i\delta} \\<br /> e^{i\delta} & e^{-i\delta} & \sqrt{2} \\ \end{array} \right)[/tex]
where [tex]\delta = .222 = 12.72[/tex] degrees, is the Cabibbo angle. Let
The use of circulant or retrocirculant mixing matrices in order to implement a permutation symmetry between generations was abogated by Adler in the late nineties. He missed this formula of course because he wasn't interested on square roots, and besides he used the antidiagonal version of the matrix. Koide's arrived to Carls's version a bit after Adler, in hep-ph/0005137, and hoping to relate it to trimaximal mixing. Intriguingly, his parametrisation in this paper does not get Cabbibo angle.
A footnote in Weinberg's The Problem of Mass points to old attempts to derive Cabibbo's angle, not only from [tex]m_d/m_s[/tex] but also from pre-quark formalism, [tex]m^2_\pi/2m^2_K[/tex]. Fascinating.
Carl could be interested on the preon models that motivated the formula time ago in the eighties. Someones are available in the KEK preprint server. http://ccdb3fs.kek.jp/cgi-bin/img_index?8208021
Let me note here a personal communication from Dr. Koide.
Koide said:
The most difficult point in my mass formula is that
the charged lepton mass term is [tex]\Delta I =1/2[/tex] if we
consider mass generation by Higgs scalars, while if
we consider that mass term is given by a bilinear form,
it means that the term is [tex]\Delta I =1[/tex].
We need something beyond Standard Model.
Dear Dr. Rivero, Thanks for the Koide references. I picked up photocopies of the ones you listed yesterday.
Could you please explain your interpretation of Koide's comment on [tex]\Delta I =1/2[/tex]? I have no idea what [tex]\Delta I[/tex] is.
The problem with making the fundamental fermions out of a combination of a fermion and a boson is that it requires a force that isn't described, and it would imply the existence of more particles that haven't been observed. But to make them out of fermions requires either that the spins cancel, which also has problems with too many particles, or, more naturally, that the spin angular momentum of the subparticles be h-bar/6. But that violates the usual understanding of the relation between spin and statistics. On the other hand, the hiding of fractional spin by a subcolor force does remind one of the hiding of fractional charge by the color force.
There is no way that I would have come to these very radical and speculative conclusions if I'd started out by looking for a method of unifying the elementary particles. Instead, I started out by trying to understand Lorentz symmetry. So if what I've written seems insane, please understand that you're not getting the story as it unfolded to me. Instead, I'm including here only conclusions, and only those conclusions that contribute to a connected understanding.
My difficulty is that no one has enough patience to go through the reasoning I went through to get where I am now.
Suppose you discovered the unified field theory, but the theory required a modification of every assumption of both quantum mechanics and relativity. Maybe you can convince a few people to listen to an alternative interpretation of the foundations of one of those two theories, but long before they have heard your alternatives for both theories they will have concluded you are insane.
And to show equivalence to the standard model requires not only rewriting the foundations for both theories, but then to make simple but non trivial calculations in the new theory. There is not a chance in hell that you will convince anyone to sit through this.
So what you do instead is you use your understanding to find relationships between the parameters of the standard model. After I get papers written up to correspond to talks I gave at the PHENO2005 and APSNW meetings (on centauro cosmic rays and binding calculations for binons, respectively), I will start working on the fine structure coupling constant. When I'm done, I hope to have a complete derivation of the standard model from first principles. It will be impossible to get anyone to read it, but it should allow me to derive relationships between standard model parameters, and who knows, maybe then. Or perhaps new observations of the Centauro events will match my predictions.
Carl
I guess it is about Isospin.
Personally I dislike composite models because of this; it is not easy to see how to interpret them in a realistic way without generating excessive particles at the same time.
A very honourable quest.
I would try to make sure that both QM and Relativity were got in the adequate limit, as well as QFT. On the contrary I would need to reproduce all the known results, a lifelong work.
This is a different problem, and this thread is long enough already without philosophical discussions. As you can see, we have focused the thread on mass predictions, including analysis of the exactitude and full description of the input. I'd not like to miss focus. Perhaps in other thread.
Just a question here: are you claiming that your matrix above has been derived from your theory? Iff so, please give here a link to a corresponding webpage.
Hi Carl
That's not for you to say. Maybe someone will have the patience. Could you give us a link, or explain some more of the fundamentals that you have in mind?
All the best
Kea
:smile:
Dear Kea, Dr. Rivero is right, a long discussion really doesn't belong on this thread. At this time, I'm busily texing up a report for the PHENO2005 meeting. I should be done in a few days, and I'll link it in then.
Basically, the idea is to assume that one must generalize the Dirac propagator to form a Dirac equation that simultaneously contains multiple particles. One does this with a Clifford algebra. There are very few choices that one can make, and the choices pretty much amount to assumptions about the nature of the manifold that the Clifford algebra is defined on. (In other words, this is a "geometric algebra" variety of Clifford algebra as promoted by David Hestenes.)
Having a propagator that contains multiple particles, one derives the symmetries that the propagator must have, and sees whether these symmetries correspond to those observed in the natural world. Fitting the two together take a lot of work.
Carl
I understand now, but I doubt I understand to the extent that Koide meant. From my point of view, the problem with mass is that it is the only thing in QM that couples opposite handedness.
> well as QFT.
Fortunately, I don't have to worry about relativity, as several other physicists have already worked out the details. I'm not a general relativity expert, but since there are 5 physicists publishing papers on the theory, I expect that at least one of them got it right. The GR theory goes by various names that differ according to the researcher, but a common name that seems to be coming to the fore is "Euclidean relativity". A place to start reading is Hestenes's review article, Almeida's "4DO" version, or Montanus's famous work:
http://modelingnts.la.asu.edu/pdf/GTG.w.GC.FP.pdf
http://arxiv.org/abs/physics/0406026
Hans Montanus, (1997) "Arguments Against the General Theory of Relativity and For a Flat Alternative," Physics Essays, Vol. 10, No. 4, pp 666-679.
It probably doesn't help with the physics community that Ron Hatch (engineer who developed GPS which depends on relativity calculations) supports the underlying modification of relativity (sometimes called "Lorentzian relativity"):
http://www.egtphysics.net/Gravity/Gravity.htm
Not really a lifelong work. All you need to be able to reproduce are the underlying assumptions and, to the extent that you can, the parameters. From those, all the rest of the standard model follows. But it certainly isn't the sort of thing that a worker cranks out (or that a crank works out) in 3 months.
> your theory?
Yes. I gave a very brief talk on this at the University of Victoria at the APSNW2005 meeting two weeks ago. After I finish typing up the PHENO2005 paper from their meeting of May 1st, I'll type up the paper associated with this.
The mass matrix problem, after one assumes that the leptons are composites of (R,G,B), boils down to the question of how one calculates |<R|G>| as compared to |<R|R>|. If you make the assumption that R, G and B correspond to 120 degree rotations around a direction of propagation of the (handed) particle, then it is required that the mass matrix have the [tex]\sqrt{2}[/tex] down the diagonal (if the off diagonal elements are to have magnitude 1). The 120 degree assumption is not so radical as it might appear at first as it certainly explains why [tex]SU(3)_c[/tex] is a perfect symmetry.
The freedom to apply real world geometry to internal states of quantum particles comes from the use of the alternative version of relativity mentioned above. Within the assumptions of standard relativity, perfect Lorentz symmetry obtains, and this leads to the "no-go" theorems of Coleman-Mandula &c.
Carl
Ahh. How interesting. My colleagues here are very interested in Hestenes' approach. I look forward to seeing your report.
Cheers
Kea :smile:
Perhaps I have exagerated the point. Of course any direct justification of any of the formulae we are cataloging is on-topic. It is just that as I see it, it is better to wait for Carl to write down his note (next month? next couple of months?) and then to announce it here. It is no news, to theoretically specullate about preons, because the original paper was already from a preon theory.
On my side, I am trying to thing how a [tex]m^\frac 12[/tex] factor can appear in a modern theory. Classical non-relativistic theory needs such factors in order to go from Energy to Velocity, but in a relativistic theory we have the "c" highway.
On other hand the scattering matrix (whose poles are the masses) has two traditional expresions, as funcion of energy or as function of momentum, but we are in the same situation than above: when going relativisitic, there are not m^1/2 factors around.
I probably have another 7 days of texing before I release the first of those papers. It won't have quite enough to get the lepton masses, but that should follow a few weeks later.
By the way, I should note an interesting fact that I don't think has been mentioned here. If you set the angle [tex]\delta[/tex] to zero in that [tex]M^{1/2}[/tex] matrix, you won't get a result that satisfies the square root mass formula unless you conclude that the square root of the electron mass is negative.
In that sense, it's a good thing that [tex]\delta[/tex] is as large as it is, otherwise we'd have missed the square root mass formula completely.
On the other hand, one could also take the point of view that the fundamental mass matrix is [tex]M[/tex], in which case the existence of a convenient square root of it is just a coincidence.
Carl
I don't know what to make of this.
The problem with the binons that I believe underly the fundamental particles is that they have their spins aligned with their velocity vectors. That makes it necessary to have fractional spin or something similar. In the search for something similar, I found an unusual coincidence having to do with the structure of the eigenvectors for the fermion square root mass matrix, [tex]M^{1/2}[/tex].
The eigenvectors, with their eigenvalues, were:
[tex](1,1,1),\sqrt{m_\tau / 156.9281952 (123)}[/tex]
[tex](1,s,r), \sqrt{m_\mu / 156.9281952 (123)}[/tex]
[tex](1,r,s), \sqrt{m_e / 156.9281952 (123)}[/tex]
where [tex]r = e^{2 i \pi/3}, s = 1/r.[/tex].
The problem is that I have to have three subparticles have a spin that somehow unites to produce [tex]\hbar/2[/tex]. The natural way of doing this would be to use the usual Clebsch-Gordon coefficients. What I'd like to point out here is that the Clebsch-Gordon coefficients have a pattern curiously similar to the pattern of the above eigenvectors.
First, consider three spin-1/2 particles:
[tex]\frac{1}{2} \times \frac{1}{2} \times \frac{1}{2} = \frac{3}{2} + \frac{1}{2} + \frac{1}{2}'[/tex]
It's natural to associate one of the [tex]\frac{1}{2}[/tex] with the combined spin-1/2, but it turns out that if you look at the states that have [tex]S_z = 1/2[/tex], they have exactly the coefficients as the above three eigenvectors. That is:
Let
[tex]| R \rangle = |\frac{1}{2}\; \frac{1}{2}\rangle|\frac{1}{2}\; \frac{1}{2}\rangle|\frac{1}{2}\; \frac{-1}{2}\rangle[/tex]
[tex]| G \rangle = |\frac{1}{2}\; \frac{1}{2}\rangle|\frac{1}{2}\; \frac{-1}{2}\rangle|\frac{1}{2}\; \frac{1}{2}\rangle[/tex]
[tex]| B \rangle = |\frac{1}{2}\; \frac{-1}{2}\rangle|\frac{1}{2}\; \frac{1}{2}\rangle|\frac{1}{2}\; \frac{1}{2}\rangle[/tex]
Then
[tex]|\frac{3}{2} \;\frac{1}{2} \rangle = |R\rangle + |G\rangle + |B\rangle[/tex]
[tex]|\frac{1}{2} \;\frac{1}{2} \rangle = |R\rangle + r|G\rangle + s|B\rangle[/tex]
[tex]|\frac{1}{2} \;\frac{1}{2}' \rangle = |R\rangle + s|G\rangle + r|B\rangle[/tex]
In other words, the electron and muon families are alone, but there should be a spin-3/2 version of the tau. That is, according to this logic, there should be a spin-3/2 set of quarks and leptons.
Anyone seen them? I would think that the experimental results having to do with the number of lepton families based on counting neutrinos would apply, but maybe spin-3/2 neutrinos don't buy it. Or maybe it's a candidate for dark matter.
Carl
P.S. Part of the problem of quantum mechanics is the huge number of accidental symmetries. It's like navigating in a house of mirrors.
I can not but agree. Take SU(3)_color. It was introduced in order to solve the problem of (anti)symmetrizating protons and pions. But at that time there was only three quark flavours, thus another, approximate, SU(3). So the people involved on colour needed to remark, in their preprints, that SU(3)_c was independent of any SU 3, 4, 5, or 6 of flavour.
About m^1/2: I am surprised nobody mentioned harmonic oscillator frequency.
Congratulations on your new arxiv posting!
http://arxiv.org/abs/hep-ph/0505220
The strange formula of Dr. Koide
Alejandro Rivero (Universidad de Zaragoza), Andre Gsponer
10 pages, 1 figure
"We present a short historical and bibliographical review of the lepton mass formula of Yoshio Koide, as well as some speculations on its extensions to quark and neutrino masses, and its possible relations to more recent theoretical developments."
The formula works fine with the square roots of the quark masses as
well. Within the experimental values given by codata it seems.
[tex]M^\frac{1}{2} = \left( \begin{array}{ccc}<br /> D & e^{i\delta} & e^{-i\delta} \\<br /> e^{-i\delta} & D & e^{i\delta} \\<br /> e^{i\delta} & e^{-i\delta} & D \\ \end{array} \right)[/tex]
Leptons:
[tex]D\ = \sqrt{2}[/tex]
[tex]\delta\ \ = 0.2222220471[/tex]
BSD quarks:
[tex]D\ = \sim 1.2987[/tex]
[tex]\delta\ \ = \sim 0.1089[/tex]
TCU quarks:
[tex]D\ = \sim 1.1320[/tex]
[tex]\delta\ \ = \sim 0.0706[/tex]
The angles are different for the various cases. Altough we do
define 2 parameters to get 2 mass ratio's per set of 3 masses,
this doesn't mean we can find solutions for any arbitrary set of
masses. This is not the case.
Regards, Hans
P.S. The following values fit with the [itex]\overline{MS}[/itex] running mass of the
bottum quark (~4.25GeV) rather than the 1S value (~4.75GeV)
used above.
BSD quarks:
[tex]D\ = \sim 1.3150[/tex]
[tex]\delta\ \ = \sim 0.1149[/tex]
Yuri Danoyan "18 Degrees"
My last headache comes from a Yuri Danoyan, who wrote to tell me of some hadronic relationships. Basically it can be noticed that some products of mesons map approximately into barion masses. Particularly a pair of products are near the mass of the nucleon (proton or neutron):
[tex] m_B m_\pi \approx m_D m_K \approx m_p^2[/tex]
So Yuri proceeds by taking the quotient of every (pseudoscalar, no excited) meson against proton mass, and then plotting the arctan of this quotient. The pattern that emerges is a clustering reflecting the above approximation, but the unexpected phenomena is that all the intervals are about the same, some 18 degrees, symmetric around the 45 degrees or arctan(1), exhausting the quadrant.
If we believe Gell-Mann view of chiral perturbation theory, [square of] the first product should be or order K m_b (m_d+m_u)/2, while the [square of the] second one should be K m_c m_s, so the first equality amounts to [tex]m_b (m_d+m_u)/2 \approx m_c m_s[/tex]. Somehow poor result, because, after all, chiral p.t. does not apply to the bottom mesons (and very badly to charmed ones). Worse, chiral p. t. does not predict, afaik, a value for the nucleon mass, so even a way to analise the second equality is barren. Another problem is that the pure[tex]s\bar s[/tex]meson is not a mass eigenstate, and it should be extracted from the eta-eta' mixing so see how it fits in the patterns.
So I am afraid I will not be able to progress in this line, but anyway I thought it was worthwhile to mention it here.
Wojciech Krolikowski
Recently I noticed hep-ph/0504256, from W Krolikowski, and I have read a bit across its bibliography. In the early nineties, he proposed a model of "algebraic partons" (yep, more preons) based on a Clifford-guided generalisation of Dirac-Kaehler equation. It was published in some minor journals, but also reported in http://prola.aps.org/abstract/PRD/v45/i9/p3222_1 (and having a sequel about http://prola.aps.org/abstract/PRD/v46/i11/p5188_1 that I haven't read yet).
Well, the point is that in his Phys Rev article, after some summations and normalisation of that extended Dirac formalism, and including a guesswork of a very Barut-like formula, he arrived to a prediction for the mass of the tau:
[tex]m_\tau={6\over 125}(351m_\mu+136m_e) =1783.47 MeV[/tex]
The numbers are ugly, but K. did a good work of justifying them, at least good enough for the Phys Rev D referee... And well, you can remember that at these times the reported value of tau mass was 1784 MeV (+2.7, -3.6) and how this value was problematic for Koide's formula. Here on the contrary the value was right.
Ok for the old times, but now the measured value is 1777. So what of Krolikowski?. Well, he reviewed his guesswork for the massformula and he found a sign to change somewhere (EDITED: he only needed to remove a somehow arbitrary -1 imposed subtly in the Phys Rev article to keep the three masses at positive values).
[tex]m_\tau={6\over 125}(351m_\mu-136m_e) =1776.80 MeV[/tex]
Amusing.
Unfortunately it is not exactly compatible with Koide's 1776.97 prediction, so we can not straighforwardly to intersect both equations. As Koide in his first papers, also Krolikowski has forseen some places to tweak its relationship, see eg hep-ph/0108157.
CarlB said:
where degrees, is the Cabibbo angle.
CarlB said:
Convincing the physics world to simultaneously accept so many hard things to swallow is essentially impossible.
Well, no need to proceed simultaneously.
The Minakata Smirnov relation,
[tex]\theta_{\mbox{sun}} + \theta_{\mbox{cabibbo}} = {\pi \over 4}[/tex]
(hep-ph/0405088; I noted it some months later at sci.phys.research, and at PF the day after my birthday) has got some attention during the last year. A review by Minakata appeared yesterday as hep-ph/0505262. It has been renamed to "quark-lepton complementarity". The point is that, if true, it is evidence of a common origin of leptons and quarks. So it makes a good selling argument for Cabibbo in charged leptons. If it is Cabibbo and not the 2/9 of Hans!
The formula had been mentioned before in the thread (message #15) but not explicitly. I though the observation was vox-populi, but acording Minakata it was first voiced by Smirnov in a conference in December 2003, hep-ph/0402264. In july 2004 I was somehow depressed and I went on holidays to Benasque, simultaneusly to http://benasque.ecm.ub.es/benasque/2004neutrinos/2004neutrinos-talks.htm, so perhaps I overheard it around there.
Dr. Rivero, On the W Krolikowski papers,
Thanks for the links. The mass formula is stunning in its length, and surely the Koide is more attractive. The funny thing is that W Krolikowski is touching on a lot of subjects that are similar to mine, that is Clifford algebra.
And the links for the neutrino mixing angle coincidence with the Cabibo angle is very helpful.
My paper is coming along. I've recently found a fascinating verification in the Centauro high energy cosmic ray events and I can barely wait to get the paper finished. You will have provided many of the references that I will have to include, if you fail to request otherwise, I will include a note of appreciation in the paper.
I mentioned that it is difficult to get the physics community to accept too many impossible ideas at the same time. When you see the write-up, you will see that I was, if anything, understating the problem. But the Centauro data are very convincing. I am so ashamed to be still sitting on this, I'll go home now and write some more.
Carl
BSD quarks:
TCU quarks:
Regards, Hans
used above.
BSD quarks:
Indeed some researchers have already noticed the BSD quarks seem close to be compatible with Foot's version of Koide's, ie that the vector [tex](\sqrt{m_b},\sqrt{m_s},\sqrt{m_d})[/tex] is at 45 degrees of (1,1,1).
For the other flavour of unix, :confused: er, not, I mean, for the TCU set, it should be possible to fit a 45 degrees rule but against the vector (1,1,0). This should be
[tex]\sqrt{m_t}+\sqrt{m_u} = \sqrt{ m_t+m_c+m_u}[/tex]
which simplifies to
[tex]{2 m_u \over m_c} = {m_c \over m_t}[/tex]
In fact decades ago this proportion, whithout the factor two, was suggested by an expert on textures (H. Fritzsch?) as a clue for a mass of the top higher than the then current expectations. The argument was drawn over a logarithmic plot, causing Feynman to protest that "In a log plot, even Sofia Loren adjusts to a straight line"
alpha based quantisation.
http://www.slac.stanford.edu/spires/find/hep/www?rawcmd=FIND+A+MACGREGOR%2C+M , Int J of Mod Phys A V. 20, No. 4 (2005) 719-798 & 2893-2894, is mostly about hadrons, but it could be [part of] an answer to the Danoyan headache I mentioned before.
Nice plots.
Hmm, and who is this McGregor? First time I heard of him. Let's research SPIRES: As it seems (hep-ph/0309197), he is a senior, now retired, of the LLNL. Early in his worklife, he become interested in a mass systematics for hadrons (http://prola.aps.org/abstract/PRD/v13/i3/p574_1, 574) which did not got its way up to the mainstream (I wonder if because of excessive predictions, just as Barut's leptons, let's say), and time after he played with the idea of spinless quarks as well as the concept of "large electron" with pointlike charge.
It seems that he become impatient about the low impact of his model; one of the last publications before going "preprint only" was titled "Can 35 Pionic Mass Intervals Among Related Resonances Be Accidental?" (Nuovo Cim.A58:159,1980). In some sense, he shares adventure with another insider, Paolo Palazzi
This one does not score in the same quality that the rest of the thread, but well... Get [tex]\pi^0[/tex] and [tex]Z^0[/tex] and consider both their mass [tex]m[/tex] and their total decay width [tex]\Gamma[/tex]. We have for the 2004 PDG central values,
[tex]{m_\pi^3 \over \Gamma_\pi} {\Gamma_Z \over m_Z^3} = 1.04...[/tex]
The listed error for the decay width of pion is relatively high, so the result is compatible with the unit. Separately we had, considering errors
[tex]\sqrt{m_\pi^3 \over \Gamma_\pi}= 541...580 GeV[/tex]
[tex]\sqrt{m_Z^3 \over \Gamma_Z}= 551.0 ... 551.5 GeV[/tex]
Another way to see the same thing is to "calculate" the lifetime of neutral pion:
[tex] \Gamma_{\pi^0}= \Big({M_{\pi^0} \over M_{Z^0} }\Big)^3 \; \Gamma_{Z^0}[/tex]
We get 8.13E-17 s (8.1 eV), compare with a theoretical effective calculation such as hep-ph/0206007, and against experimental 8.4E-17 +-3*0.2E-17 s (7.8 eV) at PDG 2004.
Let me put numbers, from PDG 2004, into the formula
[tex] \Gamma_{\pi^0}= \Big({M_{\pi^0} \over M_{A} }\Big)^3 \; \Gamma_{A}[/tex]
where mass of pi0 is 0,134976 GeV and we expect to find a value for its gamma around experimental
Gp(exp) =0,000 000 007 8 (-0 5, +0 6) GeV
or theoretical
Gp(the) =0,000 000 008 10 (+-0 08) GeV
Well, I found two valid neutral (but no scalar) particles.
First, for the aforementioned Z0, we have M= 91,1876 , G=2,4952 (all the values in GeV) and it results in a prediction
Gp(Z0) =0,000 000 008 1 (+-0.000 000 000 0)
And second, for J/Psi ! We have M=3,096916 G=0,000091 and
Gp(J/P) =0,000 000 007 5 (+-.000 000 000 3)
No bad. It should be nice to have a theory backing it.
Ah, the other neutral boson, the upsilon [tex]\Upsilon[/tex], does not fit, but it is possible to make use of MacGregor's alpha pattern and tweak a bit with the data; the best fit is with the least bounded state, upsilon(3), that after multiplication times alpha gives 0.000 000 007 9.
EDITED, VERY TECHNICAL: One argument is that as vectors can not decay to two photons except virtually, they compose the whole decay amplitude. As for Upsilon, perhaps it is decaying using the square anomaly instead of the triangular one.
alpha and the golden ratio
The following may not be in the same league as the main contributions to this thread, but I think it's cool. It doesn't work to many significant figures. Now, never mind why I'm doing this, but if we let [itex]\phi = 1.618 \cdots[/itex] be the golden ratio and we try to relate [itex]\alpha[/itex] to the Temperley-Lieb [itex]d[/itex] factor, we come up with [itex]\alpha = 137.08[/itex] from
[tex]\frac{\sqrt{\alpha}}{2} = e^{\frac{2 \pi}{2 + \phi}} + e^{\frac{- 2 \pi}{2 + \phi}}[/tex]
Cheers
Kea :cool:
Kea, you can prettify your formula, imho, by writting it as the square of a hyperbolic cosine... and adding a reference to that Temperley-Lieb factor; I am afraid it is not a object of my mathematical bagage. In any case it does not sound as bad, against the measured 137.0359, if it were the first term of a series.
Let me note that the updated Wolfram-Weisstein webpage has a pair of recent approximations, formula 6 and 7. They refer to work from Bailey and http://www.lacim.uqam.ca/~plouffe/.
About alpha from a physics point of view, I do not remember if we quoted already here Adler's program, the unsuccessful idea of looking for an eigenvalue equation for it: href=http://prola.aps.org/abstract/PRD/v5/i12/p3021_1[/URL]) of experimental values of alpha which are interesting to see (they are quoted in Peskin/Schroeder about pages 90-100, depending on edition)
Unrelated to this... I have started a note on the pion relationship, you can see the [PLAIN]http://dftuz.unizar.es/~rivero/research/pion.pdf
My last formula in hep-ph/0507144 involved a summatory in all the fermions the Z0 can decay to,
[tex]\sum_f C_f (|V_f|^2 + |A_f|^2)[/tex]
where C is a coefficicient 1 for leptons, 3 for quarks, and V and A are the vector and axial couplings.
After releasing it, I read again the calculation of the Z0 decay width in "QCD and Collider Physics" (Ellis-Stirling-Weber) and I noticed that, when summed for a complete generation of fermions, this coefficient is very near of the number e.
Let me describe the calculation. The A coupling is always [tex]\pm 1/2[/tex], but the V coupling depends of charge and Weinberg angle. Table 8.3 in the above quoted book lists the values [tex]V_u \sim +0.191, V_d\sim -0.345, V_\nu=0.5, V_e=-0.036[/tex]. And as I said, C is 3 for quarks (it receives corrections if the colour coupling constant is enabled, but the book does not worry about this, so neither me) and 1 for leptons.
So the sum is 2.717814
versus e^1= 2.71828... it makes a 0.017% discrepancy.
Now, the book calculation was for (running) sin^2 of Weinberg angle 0.232 and the intermediate rounding was against us (we get 2.7181 if we use this angle without the intermediate rounding). Let's forget about the possible corrections from C, and ask for which value of Weinberg angle is this equality exact. We need then the formulae,
[tex]A_f=T^3_f[/tex]
[tex]V_f=T^3_f-2Q_f \sin^2 \theta_W[/tex]
and we get [tex]sin^2 \theta_W = 0.231948[/tex]
Of course, we are speaking of Z0 couplings for Z0 decay, so the value of angle is to be taken to this scale, in distintion to Hans approximation early in this thread, which was unrenormalized. Check table 10.5 of the pdg review.
Hmm if we believe both Hans estimate plus the exactitude of this relationship, the running of Weinberg angle could be interpreted as a prediction of the mass scale of Z0. Then in turn the mass of W is predicted (via Weinberg angle again!) and then the scale of electroweak vacuum follows.
On other hand, it should be remarked that the minimum of this expression, 2.5, is got for Sin^2 W equal to 3/8, a value known from GUT theories, and that has the additional virtue of cancelling the top [,up, charm] V_f couplings (but not A_f ones, of course).
I was worried because in this thread we have got two very high precision inventions for [tex]\sin^2 \theta_W[/tex] and they are very different in spirit; the one by Hans about middle way in the thread, the other here in the message above.
But now I think about, this later one is about Weinberg angle as parametrisation of the coupling constants while the first one (Hans will correct me if I am wrong) was in the scent of the mass quotient between Z and W. One number can be calculated directly from the another if SU(2)xU(1) is broken via the minimal Higgs mechanism, but they are different concepts and it is possible to have different unrelated ways to estimate them. Uff.
Now I think about, I haven't put here explicitly the estimate from previous message yet; it is
[tex]\sin^2\theta_W=\frac 38 \Big(1-\sqrt\frac 23 \sqrt{(\sum_{n=0}^\infty {1\over n!}) - \frac 52}\Big)[/tex]
Or, if you prefer
[tex]4(1-2 \sin^2\theta_W + \frac 83 \sin^4\theta_W) =\sum_{n=0}^\infty {1\over n!}[/tex]
Or
[tex] 4 ( \cos^4\theta_W + \frac 53 \sin^4 \theta_W) =\sum_{n=0}^\infty {1\over n!}[/tex]
or :biggrin:
[tex]\ln ( 4 (\cos^4\theta_W + \frac 53 \sin^4 \theta_W)) -1 =0[/tex]
I was thinking to start a new thread, but well anyway... this last number, 0.231948... when checked against the aforementioned table 10.5 selects only a particular measurement: 0.23185(18), the one from the Forward/Backward asymmetry!
Why the exclamation marks? because this measurement is a well known problem of standard model fits; depending of the data it stands between 2.9 and 3.5 sigmas of the expected value, no bad enough to claim new physics, but no good enough to consider it in the same bag than the rest. And while the NuTeV anomaly comes from only an experimental group, this one comes from different teams, so it is usually assigned to "unknown systematic error".
Hans' number from posting #44, 0.2231013... , when used for the second column of table 10.5 selects the first three measurements, ie the accepted standard model value.
Perhaps it is worthwhile to remember that the relationship between Weinberg angle (ie the mixing of couplings in Weinberg model) and the masses of Z and W depends on the structure of the Higgs sector; the usual M_W/M_Z is a result for the minimal Higgs.
Hans, Please view the attachment (if this works right), I have summarized some possible relationships between your Fine Stucture Constant Work and my Earlier formula for the Tau Electron mass.
Jay.
New Paper: Magnetic Monopoles and Duality Symmetry Breaking in Maxwell's Electrodynam
Hello to all:
I wanted to let you know about my new paper just posted at
http://arxiv.org/abs/hep-ph/0508257, titled Magnetic Monopoles and Duality
Symmetry Breaking in Maxwell's Electrodynamics.
This paper summarizes the main direction of my research over these past
eight months.
The abstract is as follows:
It is shown how to break the symmetry of a Lagrangian with duality symmetry
between electric and magnetic monopoles, so that at low energy, electric
monopole interactions continue to be observed but magnetic monopole
interactions become very highly suppressed to the point of effectively
vanishing. The "zero-charge" problem of source-free electrodynamics is
solved by requiring invariance under continuous, local, duality
transformations, while local duality symmetry combined with local U(1)_EM
gauge symmetry leads naturally and surprisingly to an SU(2)_D duality gauge
group.
As regards this thread, I note the extremely accurate formula (no "mere coincidence" in my
view) that Hans has posted for the fine structure constant and the
appearance of 2pi and (pi/2)^2 as a key numeric drivers in this formula. In section 6, I call your attention particularly
to equation (6.7) which brings pi into the fine structure formula based on
phenomenological origins, and to the derivation leading to this including
the Dirac Quantization Condition expressed as (5.22) where both the 2pi and
the a^.5 (the electric charge) are apparent ingredients. Regarding the
(e^pi/2)^2 factor, pi/2 for the "complexion" angle I am using in this work
is what rotates between the electric and magnetic monopoles. And, with some
rejuggling of (5.22), one can clearly get pi^2 factors to show up there.
The exponentials do not yet have a clear phenomenological origin, but, since
running couplings a connect via a log relationship to probe energy u, that
is, ln u ~ a, so that u ~ e^a, one can conceivably get this exponential onto
phenomenological footing as well once a connection is made to probe
energies. The connection to probe energies, I will make the topic of a
follow up paper.
In other words, the complexion angle, which is central to this
paper, is a direct function of the fine structure constant a, but is an angle
of rotation which naturally introduces factors like 2pi and pi/2. I have a
strong suspicion that this might provide a basis for going beyond
"mathematical fitting" of the numbers (I am being careful not to use the
word "numerology" because of its negative connotations) to explain how Hans' Fine Structure Constant
mathematics can possibly be given a phenomenological origin.
I would be interested in any feedback, public or private, that you may wish
to provide.
Jay R. Yablon
_____________________________
Jay R. Yablon
Email: jyablon@nycap.rr.com
Hi Jay
Very interesting! I see on page 18 you begin to discuss monopole masses. I assume you know that one of the LHC experiments will be searching for such things in the right ballpark...
http://moedal.web.cern.ch/moedal/
:smile:
