Alpha Decay and Total Kinetic Energy
The discussion revolves around calculating the total kinetic energy released during the alpha decay of the polonium isotope 211 Po. The initial approach mistakenly summed the kinetic energies of the lead nucleus and a typical alpha particle, yielding an incorrect total of 5.12 MeV. Participants emphasized the importance of conservation of momentum in decay processes, suggesting that kinetic energy is related to momentum through the equation KE = p² / 2m. The conversation highlights the need to consider both energy and momentum conservation principles when solving nuclear decay problems. Ultimately, the original poster resolved their confusion and successfully approached the problem.
asifion
The polonium isotope 211 Po is radioactive and undergoes alpha decay. In the decay process, a 211 Po nucleus at rest explodes into an alpha particle (a 4 He nucleus) and a 207 Pb lead nucleus. The lead nucleus is found to have 0.12 MeV of kinetic energy. The energy released in a nuclear decay is the total kinetic energy of all the decay products.
How much energy is released, in MeV, in a 211 Po decay?
Ei = Ef
K total = K alpha + K Pb
Since we are looking for K total, I summed the given kinetic energy for lead and the typical kinetic energy of an alpha particle: 0.12 + 5 = 5.12 MeV. My answer is definitely wrong, but I don't how I should approach the problem.
asifion said:
Problem Statement: The polonium isotope 211 Po is radioactive and undergoes alpha decay. In the decay process, a 211 Po nucleus at rest explodes into an alpha particle (a 4 He nucleus) and a 207 Pb lead nucleus. The lead nucleus is found to have 0.12 MeV of kinetic energy. The energy released in a nuclear decay is the total kinetic energy of all the decay products.
Relevant Equations: Ei = Ef
Have you thought about what quantity must be conserved in a decay?
Likes asifion
Energy? Not quite sure what you are getting at. I was thinking Ui + Ki = Uf + Kf where Ki is 0.
Not energy. Hint: Newton's third law.
Force?
asifion said:
Force?
One thing you must never forget is conservation of momentum.
Likes asifion
But we aren't given any velocity
It depends what you mean by "given". You are given the KE and you can look up the mass of the components.
You need to think how KE relates to momentum.
Likes asifion
KE = p^2 / 2m
asifion said:
KE = p^2 / 2m
Good. You need to look at how to solve the problem now. I'm going offline now, but maybe someone else can help if needed.
Thanks for the help; I figured it out.
  • · Replies 24 ·
