onurbeyaz
- 21
- 0
Why do alpha ray tear out neutron in Be, but don't do such thing in Au?
The discussion centers on the interaction of alpha particles with beryllium-9 (9Be) and gold-197 (197Au), highlighting the reasons why alpha particles can liberate neutrons from 9Be but not from 197Au. The key factors include the weak binding of 9Be, which allows for neutron liberation at a threshold of 1.57 MeV, compared to the much higher threshold of 8.07 MeV required for 197Au. The discussion also emphasizes the role of the Coulomb force and the significance of using heavy elements like gold in experiments, such as the Geiger-Marsden experiment, due to their ability to produce observable elastic scattering.
PREREQUISITESThis discussion is beneficial for nuclear physicists, researchers in particle physics, and students studying atomic interactions, particularly those interested in the behavior of alpha particles and the historical experiments that shaped modern physics.
Simon Bridge said:It is difficult to know how to answer that other than to say "because it can" but using bigger words.
1. we talk about alpha particles rather than rays
2. "tearing out" is not a good way to think of what happens
3. some isotopes of gold do undergo alpha-decay
If you think of a nucleus as a kind of liquid that is constantly shaking, then some nuclei shake hard enough that droplets fly off, some don't, it depends on how hard the nuclei is held together, which depends on the balance between protons and neutrons - the strong force vs the coulomb force.
e.bar.goum said:It's nothing about atomic bonds. This is pure nuclear physics! But you're correct to invoke the coloumb force.
Beryllium-9 is a "fragile" or "weakly bound" nucleus, and it's quite easy to liberate a neutron in a direct breakup process:
9Be + a -> 3a + n.
The threshold for this is 1.57 MeV, so it's not hard to liberate a neutron. This is why a common laboratory source of neutrons is an Am-Be source - the Am decays giving ~5.1 MeV alpha particle, which breaks up the Be, giving a neutron.
On the other hand, if you consider the knockout reaction
196Au+4He+n, you need at least 8.07 MeV
The same cannot be said for 197Au.
This is not even considering the different charges of 197Au and 9Be - the extra 75 protons will make it much harder for the alpha particle to come in close enough to knock out a neutron from gold.
onurbeyaz said:Thanks for the answer. I don't know any of the nuclear physics so this is much more than I expected. Is this why Rutherford used Gold in his experiment? What will happen if we use any other material such as any other metal like iron, or non metal like carbon
