Already-charged Capacitor Voltage time function
The discussion revolves around finding the voltage across a capacitor as a function of time after a switch in a circuit is opened. The capacitor is initially charged to a specific voltage, and participants are exploring the implications of this initial charge on the voltage function after the switch is opened.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the general expression for the voltage of a charging capacitor and question how the initial charge affects the voltage function after the switch is opened. There is also confusion regarding the circuit configuration and the role of certain components.
Some participants have provided guidance on modifying the voltage expression to account for the initial charge on the capacitor. Others have raised questions about the circuit's configuration and the effective resistance seen by the capacitor, indicating a productive exploration of the problem.
There are uncertainties regarding the resistance values in the circuit and how they change when the switch is opened. Participants are also considering the implications of the capacitor's initial voltage on the subsequent behavior of the circuit.
libelec
Find V(a) as a function of time in the following circuit when the switch is opened. Originally, the capacitor is charged to Vc = 1/101 * V1.
I know that when the switch is opened, the capacitor is going to get charged again, and V(a) is going to be the same as its voltage. I know the general expression for the voltage of a charging capacitor is:
Vc(t) = V0 + V * (1 - e-t/RC)
Where Vc is the voltage of the capacitor, V0 is its original voltage, V is the voltage of the source, R the resistance and C its capacitance.
So, V(a)(t) is going to be the same as that. The problem is that I know that, in its stationary, Vc has to be equal to V, yet the expression I found doesn't do that. In this problem, I found that V0 = 0,29V, V = 30V, C = 2200μF and R... is it 100Ω? 100100Ω?
In an experiment I made (from which this questions comes), after 160 seconds V(a) was around 30V, but if I replace 160s in t in that expression, I get something closer to 17V. I thought that it has to be because I'm not calculating the R of the equivalent RC circuit right. Is that it?
Thanks
Circuit makes no sense. Opening the switch does nothing since it's permanently shorted by a wire in parallel with it.
Also, Va is shown as a source on top of the output voltage which also makes no sense.
Yeah, sorry. V(a) isn't supposed to be a a source, it was just the only way I had to draw it.
This is the circuit written on the assignment, I'll edit it:
Pay no attention to the rest of the circuit. Just the bottom half.
Nobody?
I moved your thread to "Introductory Physics Homework", see the pinned thread for the difference.Concerning your question: V0 and V should be the same if the final voltage is V0. If your capacitor starts with a non-zero charge, modify the exponential instead of the prefactors:
$$V_c(t)=V_0 \left(1-e^{\frac{t-t_0}{RC}}\right)$$
Alternatively, let t=0 refer to some unknown point before the experiment starts, and determine t where the capacitor is charged to its initial voltage.
The problem is that the previous voltage over the capacitor is the one it has in its stationary while the switch L1 is closed. Then when its opened, is when the experiment begins. So that rule for the voltage over the capacitor isn't valid for the previous situation while it is loading at the beginning, only when it is after the switch is opened.
Is this OK?
If I understand your problem, you're worried about how the initial potential across the capacitor will affect the expression that describes the potential after the switch opens. Your equivalent circuit would look something like this:
The thing to do is to find the ΔV that will applies. That is, suppose the capacitor potential starts at V1 and and will head towards a final value of V2. Then ΔV = V2 - V1, and the capacitor potential will follow the curve:
$$Vc(t) = V1 + ΔV e^{-t/\tau}$$
I understand. So it would be something like:
Vc = V1 + (V2 - V1) * e-t/τ
Is this correct? One final question: the total R in this circuit, is it 10100ohm?
Yes, see my post above
No, the resistance that the capacitor "sees" will depend upon the position of the switch. When the switch is open, the 100Ω resistor effectively disappears from the circuit. While the switch is closed, there is a voltage divider situation. You should be able to work out the effective resistance and initial potential by finding the Thevenin equivalent model for the source and resistor network.
Thank you very much.
