Alternative definitions of energy?
  • Context: Undergrad
  • Thread starter Thread starter Millenniumf
    Definitions Energy
The discussion revolves around the definitions and interpretations of energy, particularly in the context of physics. Participants explore alternative definitions, the circular nature of existing definitions, and the implications of these definitions in various physical scenarios. The conversation includes theoretical considerations, conceptual clarifications, and challenges to established definitions.
  • One participant suggests that energy could be redefined as the vibrations of cosmic strings, indicating a lack of confidence in their understanding and acknowledging the speculative nature of this idea.
  • Another participant emphasizes that work done on a system is defined as the change in kinetic energy, presenting the equation E=PE+KE as a standard definition of total energy.
  • A different viewpoint references Feynman's explanation of energy as a conserved quantity in nature, suggesting that energy can be redefined as needed to account for different forms without implying it "exists" in a conventional sense.
  • Some participants argue against the definition of energy as merely the ability to do work, claiming that this perspective is flawed and that energy itself cannot be destroyed, unlike the ability to do work.
  • There is a contention regarding the relationship between work and kinetic energy, with some asserting that work done does not always equal the change in kinetic energy, particularly in scenarios involving friction or other forces.
  • One participant proposes a mathematical definition of energy using the Hamiltonian and state of a system, challenging the conventional definitions and suggesting that alternative definitions must remain mathematically equivalent.
Participants express multiple competing views regarding the definition of energy, with no consensus reached on a singular definition. Disagreements persist about the implications of defining energy as the ability to do work and the mathematical equivalence of alternative definitions.
Some participants note that definitions of energy may vary depending on the context, particularly in cases where force and distance are difficult to quantify. There are also unresolved issues regarding the implications of different definitions on physical scenarios.
  • #61
juanrga said:
The recommended (IUPAP, ISO, IUPAC) notation for heat flow is [itex]\Phi[/itex]. And the recommended notation for heat flux density is [itex]J_q[/itex]. Of course [itex]J_q \neq \Phi \neq Q[/itex].
juanrga said:
Ignoring stuff corrected before, I will add that IUPAP, ISO, IUPAC, define the heat flux as [itex]\dot{Q}[/itex], which is not the same than heat, evidently.
That's completely backwards.
[itex]\dot{Q}[/itex] is symbol for heat transfer rate. [itex]\overrightarrow{\phi_q}[/itex] is the symbol for heat flux.
  • #62
juanrga said:
{*} It is very very complex and I prefer do not to write D in explicit form.
That is fine. I understand that answering such questions is often much more effort than it is worth, and I don't want to push you to do more work than you feel the topic merits.
However, I hope you understand that I will have to remain slightly skeptical (though less certain than before) that your definition of energy is, in fact, more general. I have never seen Hamiltonians applied to friction, and from what you say here it seems to be needlessly complicated even for simple systems. If nothing else, this shows that in some cases there is a definite computational value in the "introductory" definition.
In any case, regardless of whether or not it is more general, your preferred definition is certainly a good definition and it reduces to the "introductory" definition in situations where they both apply.
  • #63
juanrga said:
As said I will ignore errors corrected before as well as stuff that I have not said.
About the remaining stuff, Q in the first law ΔU = Q + W, denotes heat, not heat flux.
Do you actually know anyone who pays attention to the IUPAP guidelines? I mean, they're nice folks and all, but in most fields of physics, it's more important to follow the conventions in the literature of the field than the recommendations of some folks who have spent a little too much time in the company of chemists, if you know what I mean.
For example, IUPAP recommends using the term "enplenthy" for the amount-of-substance-usually-just-called-number-of-moles. Do you know anyone who uses this terminology? Along these lines, IUPAP discourages the use of "molar volume" and instead prefers "enplenthic volume". There are a lot of idiosyncratic recommendations in the IUPAP guidelines. Do you know anyone who uses "L" for Avogadro's number?
I tend to follow the advice of Howard Georgi, which is not to get too hung up on notation. You have to know what the symbols mean, but getting fussy about whether the speed of light in vacuum is c or c0 (the IUPAP recommendation) is a waste of time. I've seen a lot of different ways to write the first law; I usually prefer the version with the slashed d's for heat and work inexact differentials, but that can sometimes be a typographic challenge. So sometimes I write
du = δq - δw
and let the δ stand in for slash-d. I'm okay with
ΔU = Q12 - W12
for a finite process between initial state 1 and final state 2, but the bare version ΔU = Q - W looks a little funny. But like I said, it's not worth it to get hung up on notation.
BBB
  • #64
juanrga said:
The dynamics of any system is given by the equation
∂ρ/∂t = LHρ + Dρ (1)
where LH is the Liouvillian of the system LH=LH(H) and D the Dissipator, which is also a function of the Hamiltonian {*}.
Could you elaborate on this? It's not clear to me how the dissipator can be a "function" of the Hamiltonian (which is actually a functional) and still represent arbitrary forms of dissipation.
It seems to me that you are adding a term to the equations of motion to represent dissipation. Why in principle is this any different from inserting the Rayleigh dissipation function into the Euler-Lagrange equations of Lagrangian mechanics? I think it's a little silly to argue whether the Hamiltonian or Lagrangian is somehow more fundamental. I prefer the Lagrangian formulation of dynamics because it's more convenient for the work I do, but your mileage may vary. And Noether's theorem provides a powerful, intuitively appealing paradigm that resides naturally in the Lagrangian formulation -- but now I'm arguing aesthetics.
I do have to say that I've never been satisfied with the glibness of "energy is the ability to do work" because the grammar seems faulty to me -- "I have the ability to do work -- am I energy?"
BBB
  • #65
The IUPAP,ISO,IUPAC definition for heat flux is [itex]\Phi \equiv \dot{Q}[/itex]. Another recommended name for heat flux is thermal power.
Maybe the problem here is that both of you are not aware of the last international standards and official recommendations about those topics.
  • #66
kmarinas86 said:
Juanrga is not wrong here. In thermodynamics, "heat" is not defined as a state quantity. Heat is a process quantity. Blame that on the horrendous nomenclature adopted by thermal physics. For a state quantity that is similar to what a normal person calls "heat" or "BTUs", we have the a term "thermal energy" instead. In physics, the process quantity [itex]Q[/itex] is the heat, which is a transfer of thermal energy, not a transfer of heat, but in engineering, this quantity is called heat transfer. Heat therefore is a flow of energy, not the energy itself. I have some problems with this nomenclature, as I believe that heat should be synonymous thermal energy, but that is not how it is done in our sciences. In the mathematical physics sense, you cannot "store" heat (i.e. Heat (a mathematician's view)=Heat flow (a layman's view)=Heat transfer (a thermal engineer's view)). Saying that [itex]Q[/itex] is the "heat transfer" or "heat flow" rather than "heat" is still misleading because: 1) the word heat (a noun or verb, but never an adjective) is modifying the following noun in both of these terms as if "heat" was what is flowing or transferring, in the layman sense of the term, and 2) neither of these two terms stand for the thing being transported but rather they refer to the measure of how much was transported, and it is not even an "accumulation of heat". But again, that is how it is done. [itex]\dot Q[/itex] is the rate of heat transfer at an instant of time. Similarly, heat flux is the is rate of heat transfer at an instant of time per area.
He confounds heat with heat flux and you confound heat flux with heat flux density.
  • #67
Well, I have read a paper by Radu Balescu apologizing because the dissipator is an extremely complex object and cannot be written in concise analytic form, and then denoting it with a mere symbol. Precisely he is well-known for developing a graphical method (think of something much more complicated than Feynman diagrams) for obtaining the different terms involved in the dissipation term.
I had no problem with the «"introductory" definition», and indeed I remarked that would be a good definition for basic courses of physics {*}. I had problem only when someone pretended that the introductory definition (obtained from a first course in classical mechanics) was a general definition valid elsewhere.
{*} That introductory textbooks would not be taken as gospel is is not characteristic of physics. In elementary textbooks in chemistry we are said that water is just H2O, but in more advanced courses chemists learn that water is much more than H2O.
  • #68
BBB
Yes, D is a function of the Hamiltonian, just as the non-dissipative part LH is function as well; the difference is that D is a very very complicated function (as said before). Therefore I prefer not to write it in explicit form here.
As also explained in #56, the Lagrangian formulation (including the Euler Lagrange equations) can be derived after applying approximations on the general equation of motion; the approximations include the neglect of dissipation. You can try to add, by hand, some dissipative term to the final Euler Lagrange equations but the resulting theory will be totally inconsistent {**}.
{**} Recall the same online reference that you introduced in a previous post. Read the part where says you that the Lagrangian formalism does not work for systems with dissipation.
  • #69
The horrendous nomenclature rears its ugly head again.
In thermodynamics, heat flux=heat flux density. Yet in electrodynamics, magnetic flux/area=magnetic flux density, which makes more sense.
http://www.google.com/search?q=heat+flux
Heat flux - Wikipedia, the free encyclopedia
http://en.wikipedia.org/wiki/Heat_flux Cached - Similar
You +1'd this publicly. Undo
Heat flux or thermal flux is the rate of heat energy transfer through a given surface. The SI derived unit of heat rate is joule per second, or watt. Heat flux is the ...
Heat flux sensor
http://en.wikipedia.org/wiki/Heat_flux_sensor
A heat flux sensor is a transducer that generates an ...
Critical heat flux
http://en.wikipedia.org/wiki/Critical_heat_flux
Critical heat flux describes the thermal limit of a ...
More results from wikipedia.org »
Heat Flux Thermodynamics - Engineers Edge
http://www.engineersedge.com/thermodynamics/heat_flux.htm Similar
Sometimes it is important to determine the heat transfer rate per unit area, or heat flux, which has the symbol Q" . Units for heat flux are Btu/hr-ft2. The heat flux ...
[PDF]
Heat flux 1. Measurement of heat flux
http://nptel.iitm.ac.in/courses/IIT-MADRAS/Mechanical.../pdf/3_1.pdf Similar
File Format: PDF/Adobe Acrobat - Quick View
Heat flux is defined as the amount of heat transferred per unit area per unit time from or to a surface. ... direction of heat flux or parallel to the direction of heat flux. ...
Furnace Improvements
www.heatflux.com/ Similar
Jan 18, 2011 – FIS Training Programs “I wish I had this course a year ago; Discussion on levels of Burner NOx capabilities, information on vendor products, ...
Heat Flux
http://www.tpub.com/content/doe/h1012v2/css/h1012v2_25.htm Cached - Similar
Common units for heat Q transfer rate is Btu/hr. Sometimes it is important to determine the heat transfer rate per unit area, or heat flux, which has the symbol . ...
Welcome to Hukseflux - Thermal Science - Heat Flux Measurement
http://www.hukseflux.com › thermal science Cached - Similar
The Hukseflux Thermal Science Homepage. Hukseflux specialises in the design of thermal sensors for the measurement of heat flux, thermal gradients and ...
heat flux sensors vatell
http://www.vatell.com/articles.htm Cached - Similar
A number of articles describing heat flux measurement and its practical applications.
7(j) Global Heat Balance: Introduction to Heat Fluxes
http://www.physicalgeography.net/fundamentals/7j.html Cached - Similar
May 7, 2009 – Global Heat Balance: Introduction to Heat Fluxes ... Sensible heat flux is the process where heat energy is transferred from the Earth's surface ...
Heat Flux Density Conversion - FREE Unit Converter
http://www.unitconversion.org/unit_converter/heat-flux-density.html Cached - Similar
perform conversions between Heat Flux Density units.
http://search.yahoo.com/search?p=heat+flux
1.
en.wikipedia.org/wiki/Heat_flux - Cached
More results from en.wikipedia.org »
Heat flux sensor - Wikipedia, the free encyclopedia
* Usage|
* Properties|
* Error sources|
* See also
A heat flux sensor is a transducer that generates an electrical signal proportional to the total heat rate applied to the surface of the sensor. The measured heat ...
Heat flux: Facts, Discussion Forum, and Encyclopedia Article
Heat flux or thermal flux is the rate of heat energy. transfer through a given surface. The SI derived unit of heat rate is joule per second, or watt.
http://www.absoluteastronomy.com/topics/Heat_flux - Cached
More results from absoluteastronomy.com »
How to Calculate Heat Flux | eHow.com
Heat flux, or heat transfer per rate unit area, is a useful quantity in applications such as determining the transfer of energy from a fuel plate to working fluid ...
http://www.ehow.com/how_6494497_calculate-heat-flux.html - Cached
More results from ehow.com »
heat flux: Definition from Answers.com
The amount of heat transferred across a surface of unit area in a unit time. Also known as thermal flux.
http://www.answers.com/topic/heat-flux - Cached
More results from answers.com »
The rate at which heat is transferred is represented by the symbol Q. Common units for heat transfer rate is Btu/hr. Sometimes it is important to determine the heat ...
Heat Flux - Repair and Maintenance Manuals - Integrated ...
Heat Transfer HEAT TRANSFER TERMINOLOGY Heat Flux The rate at which heat is transferred is represented by the symbol . Common units for heat Q transfer rate is Btu/hr.
http://www.tpub.com/content/doe/h1012v2/css/h1012v2_25.htm - Cached
What Is Solar Heat Flux? | eHow.com
Heat flux is the distribution of energy across the surface of an object. Solar heat flux may refer to the the distribution of the sun's energy across the face of the ...
http://www.ehow.com/facts_6777836_solar-heat-flux_.html - Cached
Heat Flux, Solar Radiation and Thermal Conductivity: Welcome ...
Pyranometers, heat flux sensors, net radiometers, Hukseflux specializes in the design of thermal sensors for the measurement of heat flux and thermal conductivity.
http://www.hukseflux.com - Cached
Heat Flux - Scribd
Thomas E. Diller. "Heat Flux." Copyright 2000 CRC Press LLC. <http://www.engnetbase.com>. [/PLAIN] Heat Flux 34.1 34.2 34.3 34.4 34.5 34.6 34.7 Heat Transfer Fundamentals ...
http://www.scribd.com/doc/6938941/Heat-Flux - Cached
More results from scribd.com »
http://msxml.excite.com/info.xcite.psp/search/web?q=heat+flux
• Google, Yahoo! Search, Bing
Heat flux or thermal flux is the rate of heat energy transfer through a given surface . The SI derived unit of heat rate is joule per second, or watt. Heat flux is the ...
• Yahoo! Search, Bing
http://nptel.iitm.ac.in/…chanical_Measurements_Metrology/pdf/3_1.pdf
• Google
http://www.heatflux.com/
• Google
Jan 18, 2011 ... FIS Training Programs “I wish I had this course a year ago; Discussion on levels of Burner NOx capabilities, information on vendor products, ...
Heat Flux
http://www.hukseflux.com/thermalScience/heatFlux.html
• Google
• Google
Heat Flux Description - OAFlux Homepage
http://oaflux.whoi.edu/descriptionheatflux.html
• Bing
Net heat flux, Q net, is computed as: Q net = SW- LW - LH - SH. where SW denotes net downward shortwave radiation, LW net downward longwave radiation, LH latent heat ...
• Google
Heat Flux - Heat Transfer - Engineers Edge
http://www.engineersedge.com/heat_transfer/heat_flux.htm
• Bing
The rate at which heat is transferred is represented by the symbol Q. Common units for heat ˙Q transfer rate is Btu/hr.
Heat Flux - Scribd
HeatFlux
http://oaflux.whoi.edu/heatflux.html
• Google
Ocean surface heat flux products. OAFlux latent heat flux 2010 mean, OAFlux sensible heat flux 2010 mean. 1958-2010 mean, 1958-2010 mean ...
• Yahoo! Search
• Google
May 7, 2009 ... Global Heat Balance: Introduction to Heat Fluxes ... Sensible heat flux is the process where heat energy is transferred from the Earth's surface ...
http://www.dogpile.com/info.dogpl.t2.7/search/web?fcoid=417&fcop=topnav&fpid=27&q=heat+flux&ql=
Found on: Google, Yahoo! Search, Bing
Found on: Yahoo! Search, Bing
http://nptel.iitm.ac.in/…easurements_Metrology/pdf/3_1.pdf
Found exclusively on: Google
Heat Flux
http://www.tpub.com/…ontent/doe/h1012v2/css/h1012v2_25.htm
http://www.ask.com/web?q=heat+flux
EFD FluxPlus™ Flux Paste - Specialized Paste Flux Available.
Request a Free White Paper.
http://www.nordsonefd.com/Solder
TRANE Air Conditioners - Sugar Lands Oldest Trane Comfort Specialist.
A/C Repair & Sales
http://www.jacksonairandheatinc.com
http://nptel.iitm.ac.in/courses/IIT-MADRAS/Mechanical_Measurem
Heat Flux
compute heat/flux - LAMMPS WWW Site
Define a computation that calculates the heat flux vector based on contributions from atoms in the specified group. This can be used by itself to measure the heat ...
http://lammps.sandia.gov/doc/compute_heat_flux.html
Ads EFD FluxPlus™ Flux Paste - Specialized Paste Flux Available.
A/C Repair & Sales
  • #70
The real problem is that the IUPAP, ISO, and IUPAC do not have a dictatorship that forces these definitions to be the only ones taught (and available to learn) via publications. If they had that, we wouldn't have multiple definitions for the word heat flux like what we already have for heat, which helps no one to have, and the wrong people wouldn't be blamed for not being aware of this by others like yourself. Problem is, they don't have that kind of control. Though, it would actually be helpful if they did.
  • #71
Several journals (including tops from the APS) follow IUPAP recommendations.
I do not know what you mean. Please explain with detail.
The term enplenty was suggested by one IUPAC commision, but has not still been accepted and is not part of IUPAC official recommendations, less still of IUPAP.
It is not Avogadro number but Avogadro constant, and IUPAP, IUPAC, and ISO recommend both symbols L and NA. I understand rationale beyond both symbols: L is used in honor of Josef Loschmidt.
Both of you missed the point. The point is not to change A by B because the launch of a coin suggested it. The point is the development of a modern, consistent, and interdisciplinar notation, terminology, and units.
Regarding the ISO,IUPAP,IUPAC symbol for the speed of light you seem to miss the recommendation to omit the subscript denoting vacuum, «when there is no risk of ambiguity».
du = δq - δw
ΔU = Q12 - W12
BBB
This is fine
du = δq - δw
and the finite counterpart
ΔU = Q - W
is fine as well. The subindices in your
ΔU = Q12 - W12
are redundant, but it is still acceptable.
What is not acceptable is the notation given here by Andrew Mason, ΔU = ΔQ - W, because this is an inconsistent (and misleading) notation.
  • #72
Exactly, heat flux=heat flux density makes no sense, because you are equating a quantity with the density of that quantity.
Although in previous years the IUPAP also did the mistake heat flux=heat flux density, they have corrected its mistake now.
The IUPAP defines heat flux density=heat flux/area in its more recent recommendations.
You can find all kind of misconceptions and inconsistencies on the web. Not an argument
  • #73
It is good to be aware of last international standards and recommendations; but, of course, I do not encourage to follow anything said by them.
Personally, I try to understand the rationale behind their recommendations and I follow a lot of them, but not all.
  • #74
The Δ in ΔQ means "difference" in heat flows in the process (|heat flow in| - |heat flow out|). Some times the first law is written ΔU = ΔQ - ΔW where ΔW refers to the difference in work done in the process ie.: |work done by the gas| - |work done on the gas|. ΔU means difference in internal energy. Since internal energy refers to a state rather than a process, it means difference in internal energy between initial and final states.
So long as everyone understands what it means and there is no risk of ambiguity, what is wrong with it?
AM
  • #75
Well, first, the microscopic Lagrangian is the Standard Model Lagrangian (with the exception of gravity -- we don't know the appropriate way to integrate gravity with either the microscopic Lagrangian or microscopic Hamiltonian in a way that works above tree-level). Most of the time that people do calculations in the Standard Model, they use the Lagrangian formulation, whether the calculation is perturbative or non-perturbative. But Hamiltonian approaches to the Standard Model are equivalent, just usually not as easy to use.
Macroscopic Lagrangians and Hamiltonians are always approximations to collective microscopic dynamics. I don't know of any exceptions to this.
At the macroscopic level, dissipation is incorporated into the Lagrangian approach with the Rayleigh dissipation function (usually denoted with F). F is a functional of [itex]{x}[/itex] and [itex]\dot{x}[/itex], just like the Lagrangian. However, F is not a "function" of the Lagrangian. Both Lagrangian and Hamiltonian functionals just involve energies, so I am unclear how dissipation can be modeled with something that is *just* a "function" of the Hamiltonian.
Let's consider the simplest example of a classical dissipative system: a block of mass m sliding on a horizontal plane with a frictional force that is proportional to velocity. The Lagrangian is
[itex]L=\frac{1}{2}m\dot{x}^2[/itex]
and the Rayleigh function is
[itex]F=\frac{1}{2}c\dot{x}^2[/itex].
The Euler-Lagrange equation is
[itex]\frac{d}{dt}\frac{\partial L}{\partial \dot{x}}-\frac{\partial L}{\partial x}+\frac{\partial F}{\partial \dot{x}}=0[/itex]
which gives
[itex]m\ddot{x}+c\dot{x}=0[/itex]
In the method you advocate, using the dissipator D, what is the corresponding formulation? And why do you think this model is "totally inconsistent"?
I've ignored your note before because you're misinterpreting this Wikipedia entry, possibly because English is not your first language, not that there's anything wrong with that. But in the interests of clarity, the (recently edited) Wikipedia entry on Noether's theorem says
Noether's theorem has become a fundamental tool of modern theoretical physics and the calculus of variations. A generalization of the seminal formulations on constants of motion in Lagrangian and Hamiltonian mechanics (developed in 1788 and 1833, respectively), it does not apply to systems that cannot be modeled with a Lagrangian alone (e.g. systems with a Rayleigh dissipation function). In particular, dissipative systems with continuous symmetries need not have a corresponding conservation law.
What this means is that Noether's theorem does not apply to systems with a dissipation term, for example, there is no conserved current in the sliding block system I presented above. It does not say that systems with dissipation cannot be modeled in the Lagrangian formulation of mechanics. Dissipation is modeled with the Rayleigh dissipation function, which is different from the Lagrangian. Systems with dissipation do not conserve energy -- unless one proceeds to model the system at a lower level, e.g. with a Lagrangian that incorporates the degrees of freedom that absorb the dissipated energy. Ultimately, the microscopic Standard Model Lagrangian is reversible.
BBB
  • #76
AM
All of this was corrected before
  • #77
This is plain wrong. As correctly emphasized by Weinberg in the volume 1 of his quantum theory of fields. It is the Hamiltonian, not the Lagrangian, which is used to obtain the S-matrix elements, after confronted with experiments at lab.
The only utility of the Lagrangian in the SM is that it is more easy to check certain symmetries (which do no need to be fundamental). The Lagrangian is only an easy tool to obtain a Hamiltonian (H=pv-L) with certain physical requirements, nothing more. Since the Lagrangian plays absolutely no central role in the dynamics of particle physics (the generator of time translations is the Hamiltonian), Weinberg even speculates about future Hamiltonian theories not obtained from some previous Lagrangian.
which gives
Why this kind of nonsense again? The Euler-Lagrange equations are only valid when one ignores dissipation and takes the pure state approximation.
The Euler Lagrange equation for [itex]L[/itex] is
[itex]\frac{d}{dt}\frac{\partial L}{\partial \dot{x}}-\frac{\partial L}{\partial x}=0[/itex]
if you add some term [itex]A=A(v)[/itex] to the Lagrangian the equation for the new Lagrangian [itex]L' = L+A[/itex] would be
[itex]\frac{d}{dt}\frac{\partial L+A}{\partial \dot{x}}-\frac{\partial L+A}{\partial x}=0[/itex]
But this is not what you are doing.
What you do first is to agree that the Euler-Lagrange equation for the Lagrangian [itex]L[/itex] is not valid
[itex]\frac{d}{dt}\frac{\partial L}{\partial \dot{x}}-\frac{\partial L}{\partial x} \neq 0[/itex]
and second to add a non Lagrangian term [itex]\frac{\partial F}{\partial \dot{x}} \neq \frac{\partial A}{\partial \dot{x}}[/itex]
[itex]\frac{d}{dt}\frac{\partial L}{\partial \dot{x}}-\frac{\partial L}{\partial x} + \frac{\partial F}{\partial \dot{x}} = 0[/itex]
You are confirming that dissipation cannot be studied using the Lagrangian formalism, as you even agree-disagree-agree-disagree-agree-disagree...
Let us now to be serious about dissipation. Applying a number of approximations to the Dρ in the dissipative equation of motion given before, we can obtain the following approximate equation
[itex]m\dot{v} = -\zeta v + \tilde{f}[/itex]
Applying the further approximation that the block of mass is placed in an environment with zero temperature [itex]T=0 \mathrm{K}[/itex], this is reduced to
[itex]m\dot{v} = -\zeta v[/itex]
which cannot be derived from a Lagrangian, as has been known for centuries.
bbbeard said:
I've ignored your note before because you're misinterpreting this Wikipedia entry, possibly because English is not your first language, not that there's anything wrong with that. But in the interests of clarity, the (recently edited) Wikipedia entry on Noether's theorem saysWhat this means is that Noether's theorem does not apply to systems with a dissipation term, for example, there is no conserved current in the sliding block system I presented above. It does not say that systems with dissipation cannot be modeled in the Lagrangian formulation of mechanics. Dissipation is modeled with the Rayleigh dissipation function, which is different from the Lagrangian. Systems with dissipation do not conserve energy -- unless one proceeds to model the system at a lower level, e.g. with a Lagrangian that incorporates the degrees of freedom that absorb the dissipated energy. Ultimately, the microscopic Standard Model Lagrangian is reversible.
BBB
In the interest of clarity, Bbbeard edited the Wikipedia the day 27 November 2011 (i.e. yesterday)‎. The entry before your modification said
it does not apply to systems that cannot be modeled with a Lagrangian; for example, dissipative systems
Which is correct and just what I said. This is a beautiful example of why the Wikipedia has a bad fame among scholars. Everyone can go and put any nonsense that (s)he want.P.S: I solicited you more information about your 'insinuations' about the IUPAP and the chemists. What happened?
  • #78
I don't see the problem with what Andrew is saying. Even the IUPAP Red Book says it's fine to use Δ to indicate a finite change in a quantity (on p.48).
BBB
  • #79
BBB
It is fine for me if both of you do not see any problem with your incorrect and ambiguous notation and terminology and it is also fine for me if both of you decide to re-write the first law as ΔU=ΔQ-ΔW, ignoring all that was said to both.
Fortunately, the rest of us (including ISO, IUPAP, and IUPAC, and standard textbooks) can sanely avoid such abhorrences and write nicely stuff as ΔU=Q-W
  • #80
Energy is a property of moving bodies and of anything which has the capacity to create movement.
  • #81
Well, you are welcome to prefer whichever approach you'd like, but the Hamiltonian and Lagrangian frameworks are two sides of the same coin. It's like arguing whether a periodic function is better represented in time domain or frequency domain; because the Fourier transform is invertible, both domains contain the same "essence" of the function. As you yourself have pointed out, the Legendre transformation connects the Hamiltonian and Lagrangian. Equivalently, you can go back and forth between the time-evolution operator (i.e. Hamiltonian) formulation and the path integral (Lagrangian) formulation. If you pick up any textbook, as I'm sure you often do, you will notice that we go back and forth between the two approaches nearly without comment.
However, the Lagrangian is more directly connected to physical symmetries, via the afore-mentioned Noether theorem. In general, you can't just inspect a Hamiltonian and deduce the symmetries that have conserved currents. More to the point, particle physics proceeds by formulating Lagrangians that have desired symmetries and then calculating the observational consequences. Weinberg says this (Vol I, p.298-9):
Having seen that various realistic theories may be cast in the canonical formalism, we must now face the question of how to choose the Hamiltonian. As we will see in the next section, the easiest way to enforce Lorentz invariance and other symmetries is to choose a suitable Lagrangian and use it to derive the Hamiltonian. There is not much loss of generality in this; given a realistic Hamiltonian, we can generally reconstruct a Lagrangian from which it could be derived, be reversing the process that we are going to describe here of deriving Hamiltonians from Lagrangians... But although we can go from Hamiltonians to Lagrangians or Lagrangians to Hamiltonians, it is easier to explore physically satisfactory theories by listing possible Lagrangians, rather than Hamiltonians.
Indeed, this is the basis of chiral perturbation theory -- you start with a Lagrangian that contains all the possible terms (to the desired order) that respect the symmetries of the parent theory, you work out the observables, and you match the undetermined coefficients with the data from other sources. A beautiful example of this is the 1996 paper by Beard and Wiese, which provides numerical estimates of the parameters of the CPT formulation of Hasenfratz and Niedermayer for the anti-ferromagnetic Heisenberg model.
A more pragmatic approach is advocated by Halzen and Martin (Quarks and Leptons, p.313):
What is the relation between the Lagrangian approach and the perturbative method based on Feynman rules obtained from single-particle wave equations? To each Lagrangian, there corresponds a set of Feynman rules; and so, once we identify these rules, the connection is made. We can then calculate physical quantities by just following the methods presented in Chapters 4 and 6.
The identification of the Feynman rules proceeds as follows: [rules are given]...
In the orthodox approach to quantum field theory, we would now proceed to formally derive these assertions. In order to do this, the classical Lagrangian is quantized... The end result of this lengthy and formal approach can always be translated into a set of Feynman rules which are exactly those we just described. So, we might as well take these rules and proceed to investigate the physical implications of a given Lagrangian using the methods with which we are already familiar. The canonical formalism was formerly regarded as more rigorous and can be found in many books... We do not present it, as we will never use it. We hereby subscribe to the growing belief that "the diagrams contain more truth than the underlying formalism" ['t Hooft and Veltman (1973)]
You know I could go on. Practically every book on quantum field theory uses the same approach. What I said is true: "Most of the time that people do calculations in the Standard Model, they use the Lagrangian formulation, whether the calculation is perturbative or non-perturbative." You lift the Feynman rules from the Lagrangian, not the Hamiltonian. To formulate a theory that respects a desired set of symmetries, you write down a Lagrangian, not a Hamiltonian.
And this is what you seem unwilling to face: the Lagrangian is not just a "check", and not just a way point on the way to a Hamiltonian, but it's how particle physics is done. We go straight from the Lagrangian to Feynman rules to calculating amplitudes, or, we go straight from the Lagrangian to numerical methods. Now again, I'm not claiming primacy for Lagrangians over Hamiltonians in some metaphysical sense -- as I said, they are two sides of the same coin. It's your eccentric view that the Hamiltonian approach is somehow more fundamental than Lagrangian approach.
juanrga said:
Why this kind of nonsense again? The Euler-Lagrange equations are only valid when one ignores dissipation and takes the pure state approximation... if you add some term [itex]A=A(v)[/itex] to the Lagrangian... But this is not what you are doing... You are confirming that dissipation cannot be studied using the Lagrangian formalism, as you even agree-disagree-agree-disagree-agree-disagree...
Honest to gosh, Juan, you act like you've never studied Lagrangian mechanics. You don't add the Rayleigh dissipation function to the Lagrangian. And the Rayleigh function is just an elegant way to insert external forces, which are more often computed using the method of virtual work. And all this is part of Lagrangian mechanics -- go get a book.
Nor can it be derived from the Hamiltonian. The term [itex]-\zeta v[/itex] is inserted "by hand" just like the Rayleigh function. It is not, as you have claimed, a "function" of the Hamiltonian.
On the contrary, this is the strength of Wikipedia -- that knowledgeable contributors can correct and refine the information without an interminable review process. In fact all I did was to clarify what the previous text meant -- that some systems require more than just the Lagrangian to describe. It is not the case that the systems cannot be treated within the Lagrangian framework; what was meant was that these systems are not described by a Lagrangian alone. This is an elementary point.
However, the fact that Wikipedia is compiled by volunteers can mean that the quality is variable. I am willing to cite Wikipedia when I feel that the content is appropriate for pedagogy, but it is rarely, if ever, reasonable to cite it as authority.
BBB
  • #82
It is the Hamiltonian, not the Lagrangian, which enters in the computation of the S-matrix. Standard textbooks will give you the definition of the S-matrix in terms of the Hamiltonian...
What he says in that quote is essentially what I said and is still quoted at the start of your above message.
This whole part is rather incorrect.
(i) Precisely the fact of that many 'old' textbooks on quantum field theory lack precision and rigor was the starting point why Weinberg decided to write his own book, without worrying about «historical precedent», and using a new and fresh perspective about QFT.
(ii) You cite partially Weinberg in your message:
In that part he is confirming what I said before about the role of the Lagrangian as check for obtaining a suitable Hamiltonian. But Weinberg also says in his book:
It is the Hamiltonian formalism that is needed to calculate the S-matrix (whether by operator or path-integral methods)
Which is a kind of trivial statement: first, because the Hamiltonian is the generator of time-translations and, second, because the S-matrix is defined using this generator. However, I understand that he needs to emphasize this kind of trivial stuff, because the old literature on QFT is full of misconceptions and nonsense {*}.
(iii) Regarding the Feynman rules, precisely Weinberg offers an example of a kind of theories for the which
using the naive Feynman rules derived directly from the Lagrangian density would yield an S-matrix that is not only wrong but even non-unitary
. He then derives the path-integral formalism from the Hamiltonian formalism, supplementing the simplest version of the Feynman path-integral.
You are so confused about the Lagrangian formalism that you not even understand that derivation what you pasted in this forum.
Let me explain what you really did. You introduced a 'Rayleigh function' for accounting for dissipation, because dissipation cannot be studied using a Lagrangian and the Euler-Lagrange equations.
If dissipation could be studied using the Lagrangian formalism, one would simply write down some Lagrangian and then derive the dissipative equation of motion for the mass using the Euler-Lagrange equations. Since this is not possible, you have amended the Euler Lagrange equation with an ad hoc non-Lagrangian term.
Precisely, this is the reason, which the Wikipedia article correctly said that dissipative systems could not be described by a Lagrangian.
The Wikipedia article, before you edited it, said exactly:
External forces (non-dissipative) can be introduced in the Lagrangian-formalism by adding a potential term to the Lagrangian (L → L - U) and then deriving the equation of motion using Euler-Lagrange. It is not needed to use a 'Rayleigh function' for introducing external force as you claim. You are mixing apples and oranges once again.
If you read the part what you quoted, you can see me saying that the term [itex]-\zeta v[/itex] was derived from the dissipator (which itself is a function of the Hamiltonian).
But there is more, if you continue reading the part what you quote, you will discover how we go beyond your approach and obtain a correction term [itex]\tilde{f}[/itex]. This term, absent in your ad hoc equation, is needed to correct your equation in well-defined situations.
When the particle subject to friction is relatively small and placed in a heat bath, the equation that I derived gives the correct asymptotic behavior, whereas yours ad hoc equation miserably fails. Your equation miserably fails because does not account correctly for dissipation and, as a consequence, predicts an incorrect final thermal state.
BBB
Evidently, the problem is when those «knowledgeable contributors» have absolutely no idea of the topic. That is the reason for which scholarly alternatives to the Wikipedia only allow to «knowledgeable contributors» (i.e., scholars with credentials) to edit the articles.
{*} An author of a well-known handbook did the silly claim that QED is a Lagrangian theory and that no Hamiltonian exists for QED. Silliness of his claim increases when the same handbook contains a chapter (by another author) devoted to give the Hamiltonian of QED...
  • #83
This is a most interesting discussion, gentlemen.
Please do not let the rhetoric become overheated to the point of obscuring the physics.
  • #84
Yes, well, apparently quantum field theory has not yet reached the point of "consensus science"...
BBB
  • #85
juanrga, I'm not sure if I understand your claim that the Dissipator is a function of the Hamiltonian correctly.
The full Hamiltonian for a dissipative system (S) and the relevant part of it's environment (E) reads H=HS+HE+Hint. The Dissipator of the system can't be expressed by the system Hamiltonian HS alone, because it describes interactions of the system with it's environment. It has to include Hint.
So did you mean that the Dissipator is a function of the full Hamiltonian?
The difference between the Lagrangian formulation and the Hamiltonian formulation would then be the following: Under certain physically justifiable approximations, we can derive an effective description of the dissipative system from the full Hamiltonian. We can't do this using the full Lagrangian. Instead we have to start with the Lagrangian of the system without dissipation and include dissipation by hand.
  • #86
As showed in #56 the Hamiltonian formalism is derived when dissipation is ignored and a pure approximation is applied. As also said in #56
Of course, we can derive the Lagrangian formalism from the Hamiltonian formalism, using the Legendre transformation L(q,v) = pv - H(q,p)
That is, the Lagrangian formalism is valid only when dissipation is ignored and a pure approximation is applied.
Of course, you can start with a «Lagrangian of the system without dissipation and include dissipation by hand». But there is not guarantie. Precisely even the trivial equation obtained by bbbeard fails in several well-known cases. Whereas the equation obtained from the dissipative theory gives the correct final thermal state.
The equation of motion given in #56 is exact and, so far as I know, describes any system either dissipative or not.
As also said in #56 both the Liouvillian and the dissipator are functions of the Hamiltonian.
The dissipator is a very complex object that includes several powers of the interaction Liouvillian Lint (which is itself a function of Hint), 'propagators' exp(L0t), where the 'free' Liouvillian L0 is itself a function of HS and HE, and more stuff.
If you know the Hamiltonian you can obtain both Liouvillian and dissipator. Another thing is if after obtaining both you find a powerful enough supercomputer to solve the resulting equation.
The Lagrangian formalism cannot account for dissipation, as the Wikipedia article cited by bbbeard correctly said before bbbeard corrupted it. Moreover, the Lagrangian formalism plays absolutely no role in the dynamics of quantum mechanics or in QFT scattering. As Weinberg correctly notices in his celebrated textboook in QFT:
In QFT, the Lagrangian is only a simple way to check that the resulting quantum Hamiltonian formalism satisfies certain symmetries. Again Weinberg is very clever:
In classical mechanics, the Lagrangian formalism is, in principle, equivalent to the Hamiltonian formalism (see #56). The two difficulties are (i) those cases in which the Legendre transformation cannot be solved exactly and (ii) the well-known computational difficulties associated to the Lagrangian formalism (second order equations). In practice, is much simpler to design computational algorithms for the Hamiltonian formalism (first order equations).
  • #87
Ah, I just realized that I assumed that the term "Hamiltonian formulation" would also apply to the Liouvillian / von Neumann equation, which is probably wrong. Now your posts make much more sense to me. ;-)
So the true advantage of the Hamiltonian formalism is that it generalizes easily to mixed states, while the Lagrangian formalism does not?
I don't think it is the general form of dynamics for an arbitrary subsystem of a closed system. In deriving such structures from the full Liouville / von Neumann equation, one usually makes certain assumptions (Markov approximation, weak coupling) which may not be fulfilled in general.
If I know the full Hamiltonian and don't care about computational power, I could also just solve the Liouville / von Neumann equation for the whole system and trace out the environmental degrees of freedom later.
  • #88
Andrew Mason said:
This is not generally true. It is only true if the applied force F is the only force acting on the body.
AM
I think you are not interpreting what was initially said or meant.
If you want to correct the statement, it would be that the NET WORK done on a body is equal to its change in kinetic energy. I think that was implied.
Where the NET work done is the sum of all the works done on the body. For the car moving up a hill at constant speed, the net work done is zero.
  • #89
I was responding to the statement that [itex]W = \int F\cdot ds = mv^2/2[/itex]
This is not true unless the force, F, applied to the body is the only force (or is the net force) acting on the body. The work done by an applied force to a body against gravity does not result in kinetic energy of mv^2/2, for example.
That is all I was saying.
AM
  • #90
AM
The 1st statement written was
"Work done on a system is defined as the change in Kinetic Energy (KE) of that system. While The total energy of a system is the potential energy (PE) plus the kinetic energy, E=PE+KE."
There isn't anything wrong with this, one can read that is that the NET work done on a body is equal to its change in kinetic energy.
Furthermore, if you read the responding post there is clearly a summation over (i)
W12=∑i∫21Fi⋅dsi=∑i∫21miv˙i⋅vidt=∑i∫21d(12miv2i)=T2−T1 where T=12∑imiv2i is the kinetic energy of the system.
The summation clearly takes into account all the forces and gives you the net work done on the object. So I don't know what your talking about only one force, it works for many forces.
For instance if a block slides down a plane at constant speed, two forces contribute non zero work, the work done by gravity and the work done by friction. The NET work done on the object is zero, hence its kinetic energy remains constant.
Both original posts are correct.
  • · Replies 64 ·
9K
  • · Replies 43 ·
  • · Replies 62 ·
13K
  • · Replies 65 ·
10K
