Always 100% relative humidity over water? Supersaturation?
In a closed container with water, relative humidity (RH) should theoretically reach 100% under uniform conditions of temperature and pressure. However, measurements exceeding 100% RH indicate errors in the measuring device or experimental setup. The discussion highlights that polymer capacitive RH sensors, such as those from Honeywell, are not designed for calibration at 100% RH, leading to inaccurate readings, particularly at lower temperatures. Therefore, any RH readings above 100% in this context are attributed to measurement inaccuracies rather than the existence of supersaturated air.
  • Understanding of relative humidity and its measurement
  • Knowledge of closed container thermodynamics
  • Familiarity with polymer capacitive RH sensors
  • Basic principles of partial pressures in gases
  • Research the calibration methods for polymer capacitive RH sensors
  • Study the effects of temperature on humidity sensor readings
  • Learn about the principles of supersaturation in gases
  • Explore the calculation of partial pressures in closed systems
Researchers, environmental scientists, and engineers working with humidity measurement and calibration, particularly those using polymer capacitive RH sensors in controlled environments.
Roger44
Hello
Is there any way that RH over water in a closed container could not be 100%? Assuming that the walls of the container are at the same temperature as the contents, that sufficient time has gone by for uniform diffusion of water vapour, that we are at usual room temperatures and atmospheric pressures, and RH errors of the order of 1 or 2%.
I'm getting values over 100%, can there be the notion of supersatured air in this case?
What does 100% relative humidity mean to you?
If it is a closed container, why would usual atmospheric pressure apply?
usual atmospheric pressures INSIDE the container, in order to keep it simple. At extremely high or low pressures other phenomena may become important, I don't wish to diverge onto these domains.
Roger44 said:
usual atmospheric pressures INSIDE the container, in order to keep it simple...
The pressure inside the container is the sum of the partial pressures of the air and the water vapor. Do you know how to figure out the partial pressures?
Roger44 said:
I'm getting values over 100%..
How?
... can there be the notion of supersatured air in this case?
No.
So can we say that if RH >100% in this case, there can be absolutely no other conclusion than errors in the measuring device?
Or in the setup of the experiment, yes.
Good comment Mentor. Oh too true! Set up errors like drops of water around the ouside of the bowl containing a saturated NaCl solution, so the measured RH was obviously much too high.
But I now know that there is no theoretical reason not to use "over water" as a 100% RH calibration reference.
Thanks everybody
In fact there is a very good reason why you cannnot use "100% RH over water" to calibrate polymer capacitive RH sensors, It's simply because they are not spec'd for use at 100% RH.
The Honeywell sensors I'm using are barely sensitive to temperature in the normal operating range, whereas at 100%RH the output voltage rises linearly with falling temperature, leading to aberrations like 112% RH at 12°C.
  • · Replies 24 ·
12K
