Ampere's Law-cylindrical shell
  • Thread starter Thread starter Krikri
    Shell
The discussion focuses on calculating the magnetic field \(\vec{B}\) around a conducting cylindrical shell with inner radius \(R1\) and outer radius \(R2\), given a volume current density \(\vec{j}(r) = J0\frac{r}{R1}\hat{i}\). The magnetic field is determined using Ampere's Law, revealing that \(\vec{B}\) is zero for \(r < R1\), follows a specific formula for \(R1 < r < R2\), and decreases with a ratio of \(1/r\) for \(r > R2\). The participants clarify integration steps and correct minor mistakes in the calculations, ensuring accurate results.
  • Understanding of Ampere's Law
  • Familiarity with cylindrical coordinates
  • Knowledge of magnetic field concepts
  • Ability to perform calculus, specifically integration
  • Study the derivation of Ampere's Law in different geometries
  • Learn about magnetic field calculations in cylindrical coordinates
  • Explore the effects of non-uniform current density on magnetic fields
  • Investigate applications of magnetic fields in engineering and physics
Physics students, electrical engineers, and anyone interested in electromagnetic theory and applications related to cylindrical geometries.
Krikri
A conducting cylindrical shell has it's axle on Ox axis, inner radius R1 and outer radius R2. If the volume current density is given by the formula \vec{j}(r)=J0\frac{r}{R1}\hat{i} where J0 is a constant and r the distance from the cylinder's axle, calculate the magnetic field \vec{B} : 1) Everywhere in space and 2) On the Oy. Oz axis in a position y>R2 and z>R2
Using ampere's law we can easy say that for r<R1 the magnetic field is zero because there is no current passing through the amperian loop. For R1<r<R2 the region that the not uniform density takes place.
I draw an amperian loop of radius r. The whole point as i see it is to calculate the Ienc . So step by step what i did :
1) dI=J*da ,da=2πrdr so dI= \frac{2π}{R1}j0 r2dr
2)so Ienc= \frac{2π}{R1}j0 ∫r2dr from R1 to r.
3)so Ienc= \frac{2π}{3R1}j0 (r3-R13)
4) Thus the amperes law gives ∫Bdl=μ0\frac{2π}{3R1}j0 (r3-R13) and B2πr=μ0\frac{2π}{3R1}j0 (r3-R13) so B=μ0\frac{2π}{3R1}j0 [r2-(R13/r)]
5) For r>R2, outside the cylinder, the amperian loop will include the total current which the same as Ienc but for r=R2 so Itotal= \frac{2π}{3R1}j0 (R23-R13)
6) And applying the ampere's law again into a loop radius r>R2 it gives B= (μ0j0/3r)[(R23/R1)-R12]
7) It seems that in the Oy,Oz axis the magnetic field is the same and outside the cylinder it decreases with a ratio 1/r. The magnetic field is doing loops around the cylinder and inside the area with the current in the \hat{φ} direction.
I am not sure if what i did is correct and the conclusions i made. Can you comment please?
Right.
Wrong. Why did you not integrate dI = 2 pi j r' dr' from R1 to r?
rude man said:
Right.
I thought that if the current is in the green area, then the integration is from R1 o r.
EDIT: i saw it now. I did integrate from R1 to r..i forgot to put the 'd' in the r2..so it is dr2 in the first step
Not sure I understand that.
Actually however, you did everything right in your original post except when it came to evaluating B for case 2 where you forgot to divide by 2 pi.
I'm sorry, your expressions fooled me for a while but they were mostly OK all along.
never mind that, it was a mistake i thought i did :)
thanks for your reply you really helped me
