Ampere's law to find free current in a wire
The discussion focuses on applying Ampere's Law to determine the free current in a wire using the equation ∫ H.dl = ∫ j_f.dS = I_f. Participants address the dimensional inaccuracies in the equation H = j_0/r ((1/a^2)sin(ar)-(r/a)cos(ar)) and emphasize the importance of correctly defining the surface vector dS. The conversation highlights the use of azimuthal symmetry to simplify the integral calculation, ultimately leading to the conclusion that the total enclosed current can be found by evaluating H.2πr at r = R.
  • Understanding of Ampere's Law and its mathematical formulation
  • Familiarity with vector calculus, particularly surface integrals
  • Knowledge of azimuthal symmetry in cylindrical coordinates
  • Basic principles of electromagnetism and current density
  • Study the derivation and applications of Ampere's Law in electromagnetism
  • Learn about vector calculus, focusing on surface integrals and their applications
  • Explore the concept of azimuthal symmetry in electromagnetic fields
  • Investigate common mistakes in dimensional analysis in physics equations
Students and professionals in physics, electrical engineering, and anyone involved in electromagnetic theory or current analysis in conductive materials.
Benlaww
An long straight wire (can be assumed infinite) with a circular cross-section of radius R is lying along the z axis and it has
an internal H~ field given by:
H = (j_0/r) ((1/a^2)sin(ar)-(r/a)cos(ar)) φˆ
where r is the radial distance from the centre of the circular conductor, φˆ is the azimuthal unit
vector, J0 is a constant current density, and a=π/(2R).
Find an expression for the total free current
in the conductor, and give its direction.
Ampere's law
∫ H.dl = ∫ j_f .dS = I_f
∇ x H = j_f
I'm not sure how to actually solve this?
Do the integral. What is ##d\vec S##?
Your equation
H = j_0/r ((1/a^2)sin(ar)-(r/a)cos(ar)) φˆ is dimensionally incorrect. Parameter a apparently has dimensions of inverse length. You can't have (1/a^2)sin(ar)-(r/a)cos(ar). Please fix it.
I know that I have to do the integral but it's actually doing the integral which I'm struggling with. This is the equation that I was given.
You can see that the equation is dimensionally incorrect. You have to ask the person who expects you to solve the problem about it, but let's set it aside for the time being. If you know you have to do the integral, you need to assemble its components. First and foremost is ##d\vec S##. How would you write that as a vector? In other words, what is its direction and what is its magnitude?
So dS is the small surface vector which is the area on the end of the wire (πR^2) pointing normally outward in the z direction?
You got the direction right but not the magnitude. See here how to write the magnitude.
so dS = r dr dθ Z
as there's no terms in θ, after canceling terms becomes:
(j_0/a^2) ∫ sin(ar) dr - (j_0/a) ∫ rcos(ar) dr
I think you are doing the hard way by calculating a surface integral. In the OP you write something that inspires for a clever shortcut, $$\oint \mathbf{H}\cdot d\mathbf{l}=I_{\text{free_enclosed}}$$
This integral will be much easier to find since the given H has azimuthal symmetry and is in the ##\hat\phi## direction, so just choose as loop of integration any circle of radius r.
So would it be
∫ H . 2πr dr with bounds 0 and R?
Benlaww said:
So would it be
Nope, dl of post #8 and your dr are not the same, the integral of H around a circle of radius r, will essentially be $$H\cdot 2\pi r$$ that is just a multiplication because H has azimuthal symmetry and is in the ##\hat\phi## direction.
So H.2πr = I _ free enclosed? Does r stay as r or does it go to R?
After you multiply you can put r=R to find the total enclosed current.
Thank you so much! This is a great help!
  • · Replies 30 ·
