Why Is Instantaneous Value Used in Amplitude Modulation?
The discussion clarifies the use of instantaneous values in the amplitude modulation equation V=(Ec+Ei*coswt)coswt. It emphasizes that the instantaneous value of the information signal is essential for accurately representing the signal over time, as observed on an oscilloscope. The maximum amplitude is determined by Ec + Ei, independent of the cosine functions. Additionally, it highlights that for undistorted amplitude modulation (AM), the modulating signal amplitude (Ei) must not exceed the carrier amplitude (Ec) to avoid phase distortion and excessive sideband generation.
  • Understanding of amplitude modulation principles
  • Familiarity with the amplitude modulation equation V=(Ec+Ei*coswt)coswt
  • Knowledge of signal representation on oscilloscopes
  • Basic concepts of carrier and modulating signals
  • Study the effects of modulation index on amplitude modulation
  • Learn about sideband generation in amplitude modulation
  • Explore the differences between instantaneous and peak values in signal processing
  • Investigate techniques for avoiding distortion in amplitude modulation
Electrical engineers, communication system designers, and students studying signal processing who seek to understand the intricacies of amplitude modulation and its practical implications.
rahuld.exe
In the amplitude modulation equation,
I don't understand why the instantaneous value of information signal is used. Shouldnt it be peak value as that would give the maximum value (amplitude)?
There is an error here. There are two frequencies (ω) involved. ωc and ωi, where the suffices correspond to Carrier and Input (?) / Modulating signal (the same as the E suffices).
The equation tells you the value (in volts) of the signal, V at all times. It's what you will see on an oscilloscope. The maximum amplitude, for your equation, would be Ec + Ei and doesn't involve any Cos functions.
"Ei*coswt" is the shape of the envelope (the cosinusoidal modulating signal). If you want undistorted AM, Ei must be no greater than Ec. If it gets bigger then the phase of the carrier undergoes an abrupt change and this will involve a 'splash' which generates a large number of sidebands both in and out of band. (Not to be recommended)
Most likely this can only be answered by an "old timer". I am making measurements on an uA709 op amp (metal can). I would like to calculate the frequency rolloff curves (I can measure them). I assume the compensation is via the miller effect. To do the calculations I would need to know the gain of the transistors and the effective resistance seen at the compensation terminals, not including the values I put there. Anyone know those values?
  • · Replies 19 ·
  • · Replies 33 ·
