Amplitude of a stretched spring that is stretched further
The discussion revolves around the concept of amplitude in the context of oscillations of a spring, specifically comparing two problems from Halliday and Resnick. The first problem involves a spring pulled down 10 cm, while the second involves a spring initially stretched 9.6 cm and then displaced an additional 5 cm.
  • Participants explore the definition of amplitude in relation to the given problems, questioning why the stated amplitude is 5 cm in both cases despite different initial displacements.
Some participants express confusion regarding the assumptions made about amplitude, particularly whether it should be calculated or is simply given. There is an ongoing examination of the definitions and interpretations of displacement and amplitude in the context of the problems.
Participants note that the problems involve specific conditions regarding the spring's displacement and the nature of oscillations, which may influence their understanding of amplitude. There is a mention of forced initial displacement and its role in determining amplitude.
MenchiKatsu
Thread moved from the technical forums to the schoolwork forums
In question 37 of halliday and resnick a spring at rest length is pulled 10 cm down. And the answer say its amplitude is 5 cm. Okay. But then in question 73 a spring is stretched 9.6 cm by being hung from a weight, and then another 5 cm by hand. But this time the amplitude is 5 cm. Why ?
Are those the full problem statements?
A vertical spring stretches 9.6 cm when a 1.3 kg block is hung from its end. (a) Calculate the spring constant.This block is then displaced an additional 5.0 cm downward and released from rest. Find the (b) period, (c) frequency, (d) amplitude, and (e) maximum speed of the resulting SHM.
And the other one is:
A massless spring hangs from the ceiling with a small ob-ject attached to its lower end.The object is initially held at rest in a position yisuch that the spring is at its rest length. The object is then released from yiand oscillates up and down, with its lowest position being 10 cm below yi. (a) What is the frequency of the os-cillation? (b) What is the speed of the object when it is 8.0 cm be-low the initial position? (c) An object of mass 300 g is attached to the first object, after which the system oscillates with half the origi-nal frequency.What is the mass of the first object? (d) How far be-low yiis the new equilibrium (rest) position with both objects at-tached to the spring?
Those are two different problems. Can you solve them?
Yes I can solve them. But that's not the question. In the second question it is assumed that the amplitude is 5 cm. There's is nothing to calculate. It's just given. But shouldn't it be 10 ? And it's the same for the first one. 5 cm amplitude is stated. It's not calculated.
I don't see that assumption.
Read the question carefully. That's not the forced initial displacement.
That's the initial forced displacement - which determines the amplitude.
Thanks that did it
  • · Replies 20 ·
  • · Replies 16 ·
