An idea on dreams and their function (more)
The discussion explores the relationship between neural pathways, dreaming, and consciousness. It proposes that the brain uses dreams to map and analyze neural pathways formed from daily experiences, suggesting that dreams serve as a controlled environment where the brain feeds itself stimuli to evaluate its responses. This process may explain the recurrence of dreams and the inefficiency of the brain, which has a vast number of neurons yet operates slower than simpler computational devices. The conversation also touches on the phenomenon of sleep paralysis, leading to a metaphysical theory that consciousness connects individuals, forming a network that could explain experiences like déjà vu and precognitive dreams. The idea posits that these connections allow for the sharing of thoughts and knowledge across minds, challenging traditional notions of individuality and fate.
Sikz
I know that this is a subject of much debate among the fields of metaphysics, general philosophy, neuroscience, psychology, etc. Today I came up with an idea, I'm really not sure if others have, unbeknownst to me, thought of the same previously, or if I have come up with a new possibility. In any case, I shall present it to you here:
As you will no doubt be aware, our minds work by taking input through a neural network, a sort of tree. For instance, IF you are thirsty, THEN look for a drink, OTHERWISE don't. IF you look for a drink, THEN see what kind you have. IF you have coke, THEN see if you have Dr. Pepper, OTHERWISE drink the coke. IF you have Dr. Pepper, THEN drink it. etc.
We create new neural pathways as we experience things and learn. We then edit these pathways in order to make them more effecient. While these "programs" may run correctly, in order to change (improve) them we must know each step in the pathway. The only way this can be known is if either (A) each node on the web sends out a signal when activated, the signal reaches another web which analyzes it and adds it to a map of the former web. (B) diverse stimuli are fed into the network as input and the output is analyzed carefully and cross-referenced with output from different input.
I propose that (B) is the way the brain does it, and that dreams are the brain mapping out the neural pathways acquired over the previous day. At night, when we are unconscious, we are isolated from any external stimuli- we are a controlled environment. I propose that the brain feeds itself specially selected stimuli in order to analyse its own reactions and use the information gathered to deduce any changes in its neural networks. This would explain why dreams contain elements of things from the previous day- any changes to the networks would be related to the stimuli we had experienced. Therefore similar stimuli would activate the same areas of the "program". Recurring dreams, perhaps, are the brain feeding itself the SAME stimuli to see how its response has improved or degenerated, and use that information to tell whether it has been improving its effeciency.
Any comments, ideas, questions, etc would be greatly appreciated! Thank you.
Biology news on Phys.org
Our brains, however you may not think so are EXTEEMLY inneficiant. We have 1,000,000 times more neurons, than a graphing calculator has circuits, however we think 1,000,000 times slower than it does when it comes to math. Why is this? For one, and one reason only, that our brains were not designed to only do certain functions, to enable true thought; The efficiancy of inneficiany as I like to call it. As for neuron networking, each time we have a new thought, feeling, or otherwise a new neuron, or neuron creates a chain reaction in the brain to create a memory. THIS DOES NOT HAPPEN DURING DREAMING. Which is why we can not remember most dreams we have unless we make a true effort while the very temporary thought of the last dream still creates an echo. Dreams are only random assortments of information collected in the brain to create a story. Wierdly, our brains arew more active durring sleap then when we are awake, this is because no matter how strange, we reach an odd level of consciousness when we are asleep, then we could never achieve when we are awake, besides in occasions such as sleep paralysis.
I had 19 episodes of sleep patralysis, and have come to a much greater metaphysical understanding of my own mind then most people have. It has even drove me to create my own theory on such things as religion, consciousness, ands the metaphysical in general.
I have come to one VERY ODD, and extremely unrealistic conclusion that one, n my belief, can only understand if they had many episodes of sleep paralysis. The theory is that one of the points opf the innfeciancy of our minds is to connect to other conscious minds. These connections for a network, and every minds' connection is sent back to him the amount of conscious minds-1 (himself). In the center of all this, is what we like to precieve as god, the center of all thought. To understand this make a circle, create 32 points, and connect every points to every possible other points, you will see that there is a center, fallowed by 32 circles, becoming exponentially closer as they get closer to the points. What is my logic behind this? Sometimes in our dreams we dream things we couldn't possibly have gotten from the physical world, dreaming of future events, getting deja vus, knowing others thoughts or their location without any previous logical information to indicate this truth. In dreams, this other level of cosciousness captures some of the information from these connections, mostly the stronger ones.
Try to think of this network on another dimention, where the speed of thought is 0, since it instanly arrives at all other conscious minds, and as the thoughts themselves as waves, that as they disperse they become weaker. Also, think of the deja vus and realize that with all thought, it is possible to know exactly what will happen at any time, that though there is no "destiny" or "fate" and though we are free minds, knowing all thought and all knowledge, would let one predict everything according to the theory of cause and effect.
The reason for deja vus: we take all these predictions given to us, and only select the very few that pertain to any thought or feeling in our lives, however these are distant since transforming these "higher thoughts" into conscious knowledge is neerly impossible...I hope you liked my 3368 letter summary. [zz)]
https://www.nhs.uk/mental-health/conditions/body-dysmorphia/ Most people have some mild apprehension about their body, such as one thinks their nose is too big, hair too straight or curvy. At the extreme, cases such as this, are difficult to completely understand. https://www.msn.com/en-ca/health/other/why-would-someone-want-to-amputate-healthy-limbs/ar-AA1MrQK7?ocid=msedgntp&cvid=68ce4014b1fe4953b0b4bd22ef471ab9&ei=78 they feel like they're an amputee in the body of a regular person "For...
Thread 'Did they discover another descendant of homo erectus?'
The study provides critical new insights into the African Humid Period, a time between 14,500 and 5,000 years ago when the Sahara desert was a green savanna, rich in water bodies that facilitated human habitation and the spread of pastoralism. Later aridification turned this region into the world's largest desert. Due to the extreme aridity of the region today, DNA preservation is poor, making this pioneering ancient DNA study all the more significant. Genomic analyses reveal that the...
Popular article referring to the BA.2 variant: Popular article: (many words, little data) https://www.cnn.com/2022/02/17/health/ba-2-covid-severity/index.html Preprint article referring to the BA.2 variant: Preprint article: (At 52 pages, too many words!) https://www.biorxiv.org/content/10.1101/2022.02.14.480335v1.full.pdf [edited 1hr. after posting: Added preprint Abstract] Cheers, Tom
