An object moves with constant speed
The discussion revolves around the relationship between velocity and acceleration vectors in the context of an object moving with constant speed. Participants are exploring the implications of constant speed on the acceleration vector and how to prove this relationship mathematically.
  • Participants discuss the implications of constant speed on the acceleration vector, questioning whether the acceleration must be zero or if it can be orthogonal to the velocity vector. Various mathematical approaches, including differentiation of the dot product and the use of specific formulas, are suggested to analyze the relationship.
The discussion is ongoing, with participants providing guidance on mathematical techniques and questioning the clarity of the original claim. There is an exploration of different interpretations regarding the relationship between the velocity and acceleration vectors, particularly in the context of constant speed.
Participants note that the original poster's claim may lack clarity, and there is a focus on ensuring that the mathematical reasoning aligns with the physical concepts being discussed. The assumption of constant speed is central to the discussion.
reyrey389
What relationship exists between the velocity and acceleration vectors? Prove your claim
Since speed = |v| = constant, acceleration_tangential = d|v|/dt = 0. My question is on the "prove your claim part" Can I see simply just say let v(t) = a*i + b*t j (i = unit vector i, j = unit vector j). And since there is no t next to a or b, v(t) doesn't change and it's deritvative is zero ? Or do I have to show using dot product/cross product
I think that's a bit too loose handwaving there. Try considering
[tex]\frac{\mathrm{d}}{\mathrm{d}t} \left(\mathbf{v}^{2}\right) = \frac{\mathrm{d}}{\mathrm{d}t} \left(\mathbf{v}\cdot\mathbf{v}\right)[/tex]
and see where that leads you to.
Hi thanks for the quick response. I 'm not sure where to go with that. I know there's a theorem that says the dot product of a vector with itself is the magnitutde of the vector squared, but I am not sure where I can go with what you said..
But on the other hand, can I also use this formula , a = v' T + kv^2 N where v = speed , k= curvature, T = unit tangent ,, N= unit normal ,and since speed is constant v' is zero so a_tangential is 0 ?
thanks
Why not differentiate the right-hand side? Assuming you know how to differentiate a dot product?
I don't think that's a general formula. Actually, come to think of it, you have not formulated your claim clearly in the first place. The question asked you for the relationship between the acceleration and velocity vectors. All you have said is that [itex]\frac{d}{dt}|\mathbf{v}| = 0[/itex], which is just restating that the speed is constant.
Yes. So [itex]\mathbf{v} \cdot \mathbf{v} = \mathbf{v}^{2}[/itex] is simply the speed squared, which is constant with time here. You will also need to recall that
[itex]\mathbf{a} = \frac{d}{dt}\mathbf{v}[/itex]
So d/dt (v • v) = v'•v + v•v' = 2 v•v' but I'm not sure where to go with this, is it that since the two vectors are orthogonal their dot product is thus zero and since this dot product = d/dt |v|^2 then that quantity is also zero , so acceleration is zero?
So since d/dt (v • v) = d/dt |v|^2 and since v doesn't depend on t, the right hand derivative is the derivative of a constant and thus zero?
Go back a step. You have:
## \frac{d}{dt}(v^2) = 2 \mathbf{v.a} ##
What do you know about the left hand side?
That it is zero since |v| doesn't change. So a•v= 0 meaning either the vectors are orthogonal or one of the vectors is the zero vector ?
QED!
