Analysis: the closure of a set is closed?
2 replies · 8K views
memolee
Prove or disprove the following statement:
The closure of a set S is closed.
Definition of closure: set T is the closure of set S means that T is the union of S and the set of limit points of S.
Definition of a closed set: set S is closed means that if p is a limit point of S then p is in S.
So, the closure of set S-- call it set T-- contains all the elements of S and also all the limit points of S. Then, T must have limit points that is contained in it.
I can't prove that all the limit points of T is in T. I can only prove that all the limit points of S is in T. Help?
You can make this very simple.
The definition of a closure of a set A: the closure of A is the intersection of all closed sets containing A.
In a topological space, what is the intersection of any number of closed sets?
That the limit points of S are in T is directly given by the definition of closure. That's not much of a start to the proof. If you want to do this without radou's alternative definition of 'closure', pick p to be a limit point of T. Can't you show that's also a limit point of S? Stating the definition of 'limit point' might help.
