Analytic solution of a Convolution Integral
13 replies · 4K views
Legend101
The question is in the attached image . My problem starts when dealing with the limits of integration . I need an analytic procedure of solving such problems without involving graphical method . The equations of the graphs of h(t) and x(t) are easily derived .
See attached image:
The convolution integral of 2 functions is defined as :
[itеx] y(t) = \int_{-infinity}^{+infinity}h(\tau}*x(t-\tau)d\tau [\itеx]
See attached image
Legend101 said:
The question is in the attached image . My problem starts when dealing with the limits of integration . I need an analytic procedure of solving such problems without involving graphical method . The equations of the graphs of h(t) and x(t) are easily derived .View attachment 79013
See attached image
See attached image
The integral in your second attachment (both attachments have image.jpg as their filename) is not difficult to write using LaTeX.
$$y(t) = \int_{t - 4}^{t - 2} h(\tau) d\tau $$
The LaTeX script that produces this integral is y(t) = \int_{t - 4}^{t - 2}h(\tau}d\tau. Use two $ symbols at each end. More info here: https://www.physicsforums.com/help/latexhelp/
##h(\tau) ## is a linear function, and should be easy to integrate if you break it into two pieces.
The problem , as i mentioned , is in the intervals of integration . We should consider to which interval t belongs . The overlapping confuses me
h(t) is non-zero for 1<t<3, so your integral will be zero for t<3, it will grow on 3<t<5, then shrink down again on 5<t<7 and be zero from that point on.
So from the outset, restrict t to between 3 and 7 and see where that gets you.
I seriously didn't understand . How did you know that the integral will be zero for t<3 and grow in...?
How am i supposed to know the different intervals of t for integration ?
##f(t) = \int_{t-4}^{t-2} h(\tau) d\tau = \int_{2}^{4} h(t-\tau) d\tau##
If the intersection: ##[t-4, t-2] \cap [1,3] ## is empty, then the function is zero, since the integrand is zero over the entire integral.
This intersection is maximized when the two ranges match exactly, i.e. t=5.
Other than that, you are evaluating a portion of the area under the tent of h.
Are you able to write the integral of h as a function of x?
something like ## f(x) = \left\{ \begin{array} {l l } \displaystyle \int_1^x g(t) dt & 1<x\leq 2 \\ \displaystyle \int_1^2 g(t) dt + \int_2^x k(t) dt & 2< x\leq 3 \end{array} \right. ##
Always draw a picture! Look at the feasible region in ##(\tau,t)##-space.
Legend101 said:
The question is in the attached image . My problem starts when dealing with the limits of integration . I need an analytic procedure of solving such problems without involving graphical method.
I have to admit I'm always puzzled by students when they insist on a non-graphical method of analyzing a problem. Analyzing the problem graphically is probably one of the most powerful tools you have and much less error-prone than trying to apply a non-intuitive, non-graphical method.
Unfortunately , I'm not . It seems I need to do further readings :(
In your attached photo, you already have the piecewise definition of h as:
## \left\{ \begin{array} {l l} t-1 & 1<t\leq 2 \\ 3-t & 2<t\leq 3 \\ 0 & \text{Otherwise} \end{array} \right. ##
What happens if you take the integral of this for t from 0 to 2? From 1 to 3? From -2 to 0? From 2 to 4?
If you can answer these questions, you should know enough to complete this problem.
But the integral is from t-4 to t-2 . The intervals of t that we should consider are not the same as h(tau) 's intervals of definition . For now , i obtained 7 cases of t
What if you made a shift and said x= t-4 and x+2 = t-2?
Either way, you will get an integral that depends on some variable which can be evaluated as a function that has maximum of 1 and is zero for all but a small interval of length 4.
7 cases? Could you show what you have so far?
