Android programming language to ios programming language?
The discussion revolves around the feasibility of translating or converting Android applications written in Java to iOS applications using Xcode. Participants explore the technical and legal implications of such conversions, particularly in the context of copyright laws in different countries.
  • Some participants propose the idea of a translator or converter for Android to iOS applications, questioning its technical feasibility.
  • Others argue that while emulators exist, they are often slow and inefficient for running code across different operating systems.
  • A participant mentions that converting Java to Objective-C or Swift could be possible but would limit the use of unique platform features.
  • Unity is highlighted as a platform that allows for code to be written once and deployed across multiple systems, using a common library.
  • Some participants discuss Xamarin as a potential solution for developing applications for both Android and iOS from a single codebase in C#.
  • Concerns are raised about the cost of using Xamarin, with one participant noting the expense associated with its trial period.
  • Another participant mentions the MEAN stack and Adobe Phonegap as alternatives for developing web applications that could run on multiple platforms.
Participants express differing views on the practicality and legality of converting applications between platforms. There is no consensus on the best approach or the feasibility of such conversions, with multiple competing views presented throughout the discussion.
Participants acknowledge the limitations of automated code conversion, noting that significant manual rewriting may be necessary due to differences in libraries and OS calls between platforms.
Prof.gaming
I mean something like a translator ( a convertor , if you prefer ) for another platform , windows for example , to translate the codes of an android program that is written in java language to the ios language which is Xcode . That way , lots of apps that are unavailable for android or ios , would then be available .
I know it is illegal , but considering using it in a country which the copyright laws are not an issue ( like my own country , iran ) . I was wondering , is it possible ?
Technology news on Phys.org
We don't discuss breaking copyrights here. Technically programmers can build emulators for any code base but practically trying to run iOS code on an Android using an emulator and vice versa would be very slow and painful.
There may be software tools to convert Java to Objective-C or to Swift so that a developer can support both platforms but again things get reduced down to the common elements of the platforms and unique features can't be used.
The Unity game engine is an interesting platform where you write code once in either Javascript or C# and then deploy it to multiple platforms. They can deploy to Android, to Apple iOS and others.
I just wanted to know if it was possible , not to do it ... but its legal in my country ... I just wanted to know :)
At least I learned something about unity !
What country is that, if I may ask?
Iran !
An Android application written in Java or native C/C++will be of little use if another version of it isn't made in Objective-C or C/C++ in iOS. It is not necessarily a violation of the copyright if 2 different companies sell same game product. Programming languages are the same (e.g old classic war of Java against C#), even today both of them still share many places in their open source code where the implementation is done using the same algorithms with only different coding styles. I always wonder what one actually thinks when he claims publicly that his resources are open but then still insists payment for them if any is commercially put into use.
BTW, people tend to use *Platform* to indicate system types e.g 32 vs 64 bit not the OSes (Linux and Mac are two different OSes).
In most cases there can't be a simple way to automatically convert code written for one OS so that it runs for another OS.
As mentioned earlier there are things called 'emulators' which try to mimik the original OS whilst actually running under a different one, but the problem with this is that the emulator itself can use up an enormous amount of CPU resources,so while your program might work this way,it will run too slow to be of any use.
In practice the only way to be sure of getting a workable result is to re-write the source code to target the new OS. (you might get an acceptable result using an emulator on a powerful desktop PC, but unlikely with relatively weak mobile system).
Rewriting the code could be partially automated, but quite a lot of it would need to be done manually because the code for the original system will likely be making use of libraries and OS calls which have no direct equivalent in the target OS.
Unity gets away with it by using 'Mono' as it's primary library, which is an open source equivalent to Microsoft's .Net framework. Being open source it's available for all machines and OS, not any particular one.
You can use Xamarin. You can develop for both android and apple devices with one single code project. It's in C#, which I prefer to java anyways.
What limits have you seen with Xamarin so far?
Heh, sorry for the late reply.
I haven't used Xamarin that much to actually learn any particulars, the main reason being that the free trial lasts a couple weeks and it is rather expensive. So that is one major con I can think of: It's costly! :rolleyes:
I'm tending toward the MEAN web stack and the using Adobe Phonegap to make the web app.
https://en.m.wikipedia.org/wiki/MEAN_(software_bundle)
Recently though at work, we used the Android SDK and Processing to create a proof of concept app on Android which was quite cool.
TheDemx27 said:
[...] It's costly! :rolleyes:
Expensive ? These are calculated per month or year.
Also. do you like dotNet ? It is always for free.
  • · Replies 16 ·
  • · Replies 122 ·
18K
