MHB Angles in congruence triangles
  • Thread starter Thread starter sts1983
    Angles Triangles
The discussion centers on solving for angles and sides in congruent triangles given certain known values. The user seeks to determine the values of b, d, G, and F, with the constraint that c + d equals 90 degrees. A response highlights the uncertainty in finding F due to a lack of constraints that would limit its length while keeping other values constant. Additionally, there is a request for clarification on which congruent triangles are being referenced. The conversation emphasizes the need for more information to solve the problem effectively.
sts1983
I am trying to work out the above problem.
Known are: D,A,B,a,c,d. I need to work out b,d,G and F. Any ideas?
c+d = 90 degrees.
Regards,
Stan
Mathematics news on Phys.org
Hi, and welcome to the forum!
A am not sure we can find F because I don't see any constraint that prevents one from making F longer while preserving D, A, B, a, c, and d.
Also, what congruent triangles do you mean in the thread title?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
