Angular Acceleration (I don't see HOW I can be wrong?)
The discussion centers on calculating the initial angular acceleration of a board connected to a pivot point, with a length of 2.4 meters and a mass of 1.8 kg. The correct approach involves using the moment of inertia, I = 1/3ML², and understanding that the torque is not solely due to gravity, as the pivot exerts a force as well. The initial angular acceleration is calculated using the formula τ = I(α), where τ is the torque and α is the angular acceleration. The correct answer is 6.13 rad/s, which the user failed to derive due to misunderstanding the forces acting on the board.
  • Understanding of angular momentum and acceleration concepts
  • Familiarity with torque and moment of inertia calculations
  • Knowledge of basic physics equations related to rotational motion
  • Ability to apply Newton's laws to rotational systems
  • Study the derivation of torque and its relation to angular acceleration
  • Learn about the effects of pivot forces on rotational motion
  • Review the principles of moment of inertia for various shapes
  • Practice problems involving angular acceleration and forces in rotational dynamics
This discussion is beneficial for physics students, particularly those studying mechanics, as well as educators seeking to clarify concepts of angular motion and acceleration.
Lucretius
My friend in introductory physics came to me for help today. He has a test on angular momentum, acceleration etc. I figured, with me in upper-division physics courses, I'd be able to help him out. Well, I guess I was dead wrong. In half an hour I couldn't figure out a SINGLE THING. I don't see how my answers could be wrong. Everything I tried did not line up with that his professors answers were.
We have a horizontal board of length 2.4 meters and mass 1.8 kg connected on the left side to a pivot point, and was suspended by some string at the other side. The string is cut, and we are to find the initial angular acceleration of the board. Sounds easy enough... as the initial acceleration is just due to gravity, the only force now acting on the board.
A lot of formulas were provided, a tangential = r*a angular, t=I(angular a) t=rF. Standard equations for angular rotation.
At first I tried simple a tangential = r a angular. I used g for the tangential acceleration and the r I used was both the full length of the board, and the cm length (l/2). Either way, I didn't get the 6.13 rad/s that the answer supposedly was.
Next I tried using I(a)=rF, where F is due to gravity, the r was at the cm length. The I was 1/3ML^2, where L is the length of the board, M is the mass of the board (1.8 kg). I STILL did not get the correct answer.
I'm out of ideas now, and even though this isn't my class, I still want to know why can't I get basic physics right? It's times like these that I feel like I've learned absolutely nothing as a physics major over the two-three years I've been in the department.
Isn't it just the torque divided by the moment of inertia? I think the torque is (gML)/2 and the moment is (ML^2)/3 which would give 3g/2L as the answer.
Yes, 3g/2L it is.
Gravity is not the only force on the board--you still have a force from the pivot. Accordingly, the acceleration of the center of mass does not equal g.
This won't work, for reasons stated above.
This is perfectly correct, so you must have made an error somewhere.
16K
