Angular Acceleration Homework: 1014.65°, 17.97 rad/s
The discussion revolves around a physics homework problem involving a wheel rotating with constant angular acceleration. The calculations show that the wheel rotates an angle of 1014.65 degrees between t=0 and t=3.67 seconds, and its angular speed at 4.1 seconds is 17.97 rad/s. Some participants question the correctness of the initial calculations, specifically regarding the need to square the time variable in the angular displacement formula. There is also confusion about tangential and total acceleration values, suggesting a possible mix-up with a different problem. The conversation highlights the importance of correctly applying formulas in angular motion problems.
dr2112
wheel rotates w constant acceleration 3.65rad/s2
angular speed is 3.00 rad/s at t=0
a)what angle does wheel rotate between t=0 and t=3.67s?
b)what is angular speed of wheel at 4.1s?
wt+1/2alphat
(3.00rad/s)(3.67t)+1/2(3.65rad/s2)(3.67)2=17.70rad
17.70rad*360degrees/628rad=1014.65degrees
w=w0+alpha t
3.00rad/s+3.65rad/s2(4.1s)=17.97rad/s
a=1014.65 degrees
b=17.97rad/s
Hi dr2112,
wt+1/2alphat
I don't believe this is correct. The final t needs to be squared:
<br /> \Delta\theta = \omega_0 t + \frac{1}{2}\alpha t^2<br />
alphysicist said:
Hi dr2112,
Ok how is 1.60 m/s^2 for tangential and 8.61 m/s^2 for total acceleration?
Is this for a different problem, or is there more to the problem in your first post?
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 17 ·
  • · Replies 19 ·
