Angular Momentum of an ice skater
An ice skater's angular velocity increases from 4 rad/s to approximately 4.32 rad/s when she tucks in her arms, reducing her moment of inertia by 7.5%. The discussion clarifies the calculations for both angular momentum and kinetic energy changes. While the initial kinetic energy is calculated as 8I, the final kinetic energy is determined to be about 8.65I, indicating an increase of approximately 8.1%. Participants emphasize the importance of correctly interpreting the energy change factor, which is related to the conservation of angular momentum. The conversation highlights the nuances in understanding kinetic energy variations during rotational motion.
timtng
An ice skater doing a toe spin with outstretched arms has an angular velocity of 4 rad/s. She then tucks in her arms, decreasing her moment of inertia by 7.5%
a. What is the resulting angular velocity?
b. By what factor does the skater's kinetic energy change?
For a, I use IW = I'W' >> 1(4rad/s) = (1-.075)W', then solve for W'
I got 4.32 rad/s for W'. I don't know if I'm doing it correctly. Also, I need help on part b.
For part b I got .925. Is that correct?
Thanks
For part a. you got the correct answer, but I'm not sure whether you are "shortcutting" the calculation or whether you just got lucky.
I would say:
the initial angular momentum
L = Ii* ωi
L = 4*Ii
then the moment of inertia decreases by 7.5% so If = .925*Ii and thus
L = .925*Ii * ωf
4*Ii = .925*Ii * ωf
4 = .925 * ωf
ωf = 4 / .925
ωf = 4.32 rad/s
So if that is what you intended, you were doing it correctly.
For part b, your answer is not correct, but you probably have the right idea. You're just not answering the right question. You don't really mean that the energy changed by 92.5%, do you?
You did part a correctly.
You didn't say how you did part b, but it goes something like this:
Ko = .5*I*ω^2
you're looking for K/Ko
K = .5*I'*(ω')^2 = .5*(.925*I)*(I*ω/(.925*I))^2
(velocity calculation from conservation of angular momentum (part a))
From this, K/Ko = 1/.925
I see I'm too slow with the response again; maybe I need to increase my momentum.
Yeah, well, yesterday I was real quick with some dumb answers, so I'll be taking my time from now on...
what I don't understand is why 1/.925?
I guess the question is a little vague. I would have said the energy decreases by 7.5%. At first I took your original answer to be that it decreased by 92.5%, but I guess you meant that it was multiplied by 92.5%, so maybe we're saying the same thing & the only difference is semantics.
But I agree with you -- I wouldn't say 1/.925
At the risk of being slow and stupid, wouldn't the kinetic energy increase? I can't see what I did wrong in my previous post. Let me try again:
we all agree that ω = 4.32 rad/s
initial kinetic energy Ko = .5*I*ωi^2 = .5*I*4^2 = 8*I
final kinetic energy K = .5*(.925I)*(4.32)^2 = 8.65*I
There may be a semantics issue here, but I'm calling the factor by which the kinetic energy changes k, so that K = k*Ko
In that case k = K/Ko = 8.65/8 = 1.08 (=1/.925)
You're right James. I guess I'm still going too fast. I did everything exactly the same as you until the very end, when somehow that .925 slipped from the denominator up to the numerator.
The final kinetic energy is 8I/.925 so it increases by 1/.925 or 8.1%
No worries. I do the same kind of thing all the time; the avatar to my left is actually a scale drawing of the size of my brain relative to my cranium :wink:.
Thank y'all very much for taking time to help me. I appreciate it.
  • · Replies 20 ·
13K
