Angular Momentum Problem: Mouse walking on a rotating turntable
  • Thread starter Thread starter thebeegchung721
    Momentum
The discussion revolves around a physics problem involving a mouse walking on a rotating turntable. When the mouse moves from the rim to the center, the total angular momentum of the system remains constant, but the moment of inertia changes, leading to a change in angular speed. The confusion arises from understanding how to calculate the final angular speed of the turntable, given that the mouse's contribution to angular momentum becomes zero at the center. Participants clarify that the mouse should be treated as a point mass and emphasize the importance of distinguishing between linear momentum and angular momentum. The resolution lies in applying the conservation of angular momentum correctly to find the new angular speed after the mouse reaches the center.
thebeegchung721
[Mentor’s note: moved from the technical forums so no template]
A turntable with a moment of inertia of 5.4x10-3 kg
\cdot
m^2 rotates freely with an angular speed of 33 1/3 rpm. Riding on the rim of the turntable, 15cm from the center is a cute, 32g mouse. a) If the mouse walks to the center of the turntable, will the turntable rotate faster, slower, or at the same rate? Explain. b) Calculate the angular speed of the turntable when the mouse reaches the center. The axis of rotation is through the center of the turntable. What is the moment of inertia of the mouse? What is the total moment of inertia when the mouse is at the time of the turntable? What is the total moment of inertia when the mouse is at the center of the turntable?
If someone can help I'm stuck on part of this problem. It's assumed that angular momentum is conversed, so that means Li=Lf. In order to find Li, you find the angular momentum of both the turn table and mouse, and add them. Now since the mouse has no radius at the center, it has no momentum, so that part of the final momentum equation is zero. What confuses me however is finding the final angular speed of the turntable when the mouse reaches the center. The problem says no friction, so why isn't the angular momentum of the turntable the same initally and final? Is it because it essentially "loses" the weight of the mouse which causes it spin faster?
1) Don't confuse momentum and angular momentum
2) If only mass is given for the mouse, then you are supposed to treat the mouse as a point mass. Look up the definition of angular momentum for a point mass around some reference point, and calculate the angular momentum of the mouse around the turntable center based on that.
The problem says no friction...
It doesn't mention bearing friction at the turntable axle, so that can be assumed to be zero. It says the mouse walks to center, so there must be static friction at the mouse feet.
The total angular momentum of mouse and turntable stays the same, but since the total moment of inertia changes, the angular velocity must also change.
\cdot
Let's see your equations.
But the mouse is initially
Doesn't that count as the radius for the initial angular momentum of the mouse?
If you read on in post #1:
so @thebeegchung721 is not referring to finding Li.
No friction where? Please quote the exact wording.
Yes, I see now. It didn't occur to me that the OP has difficulty writing an expression for the final angular momentum when all the angular momentum is in the turntable.
10K
15K
