Angular position, speed, and acceleration
The discussion revolves around calculating the angular acceleration and the angle of rotation for a dentist's drill that starts from rest and reaches a speed of 2.52 x 10^4 rev/min after 3.30 seconds of constant angular acceleration. The user attempts to find the angular acceleration using the formula ωf = ωi + αt, resulting in an angular acceleration of 7636.36 rev/min². They also need to convert this value into rad/s² for proper unit consistency. Additionally, they are calculating the total angle of rotation using the formula θf = θi + ωit + (1/2)αt², but acknowledge that their answers are in incorrect units. The discussion highlights the importance of unit conversion in physics problems.
aaronb
A dentist's drill starts from rest. After 3.30 s of constant angular acceleration, it turns at a rate of 2.52 multiplied by 104 rev/min.
Find the drill's angular acceleration.
Determine the angle through which the drill rotates during this period
\omegaf=\omegai+\alphat
\varthetaf=\vartheta<sub>i</sub>+\omegait+(1/2)\alphat2
2.52x10^4=0+\alpha3.3=7636.36
\varthetaf=0+0+1/2=4150
I know the answers are in the wrong units so can someone tell me what to do change my rev/min into rad/s2 for the first part and to find rad for the second part?
Thanks for the link LowlyPion it helped me a lot.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 17 ·
14K
