Angular velocity of a solid disk
17 replies · 8K views
Nininguyen6
A solid disk is spinning around it center with an angular velocity of 35.0 rad/s. The disk has a mass of 3.6kg and a radius of .50m. You drop a thin ring with the same radius and a mass on the disk along the same center of rotation. What is the angular velocity of the disk and ring?
Id= 1/2mR^2
Ir=mR^2
w=vf/R
Id=1/2(3.6kg)(.50)^2 =.45 kg m/s
Ir= (3.6)(.50)^2= .90
W= (I'd+Ir)/ R
= (.45+.90)/(.50)
=2.7 rad/s
Is that the correct answer?
Nininguyen6 said:
w=vf/R
w stands for angular velocity right?
That's the relationship between linear velocity (at a distance R) and angular velocity.
For this problem you'll want to use conservation of angular momentum.
Yes, it would be [itex]L_i=L_f[/itex] (initial angular momentum = final angular momentum)
So what is the initial angular momentum? What then changes? And what does this change do to the angular velocity?
The initial is 35 rad/s aNd nothing changes because the second object is has the same mass and radius. Therefore would the finial be 35 as well?
35 rad/s is the initial angular velocity, but it is not the same as the initial angular momentum.
Angular momentum is conserved, not angular velocity.
So it would be L= I times w
Since I solved for IDisk and Iring, would I add those two up and mutiple by w?
What would be your reasoning for doing that?
You know [itex]I_i[/itex] and [itex]ω_i[/itex] and [itex]I_f[/itex] so how can you solve for [itex]ω_f[/itex]?
(Check posts #3 and #4)
((Id)(wd)+(Ir)(wr)) / R
= answer
Wf=w initial - answer
And that would give me the final angular vel?
= answer
I'm not sure where you're getting these equations.
If:
Then:
[itex]I_iω_i=I_fω_f[/itex]So what is the final rotational inertia?
I'm a little confused because I solved for the iRing and the iDisk but no I don't know where to plug it in
iDisk is the initial rotational inertia right?
And after the ring is added, it still has that initial rotational inertia, but now it also has an additional rotational inertia from the ring (iRing)
How would you write that in math?
Nininguyen6 said:
So would it be (.45)(2.7rad/s)=(.45+.90)(Wf)?
Very close, but where did you get 2.7 rad/s?
I got 2.7 from the first post so would it be (.45)(35m/s)=(.45+.90)(Wf)?
Yes, it would be that.
Now just solve for the final angular velocity and you're done!
