Another projectile motion problem.
A spring toy is launched at 2.3 m/s at a 78° angle, and the goal is to determine its maximum height. The vertical component of the initial velocity is calculated as 2.3sin(78°), leading to a vertical velocity of approximately 2.24 m/s. The time to reach maximum height is found to be about 0.5 seconds, but the calculations for vertical distance yield a negative value, indicating an error. The user expresses confusion over the equations used and seeks clarification on the correct approach to find the maximum height. The discussion highlights the importance of correctly applying kinematic equations in projectile motion problems.
-Dragoon-
A spring toy is launched from the ground at 2.3 m/s at an angle of 78° to the ground. What is the maximum height reached by the spring toy?
Vv = vertical velocity, V1 = initial velocity, Dv = vertical distance.
Δt = 2V1Sinθ/(acceleration)
ΔDv = VvΔt + 1/2(acceleration)(Δt^2)
Vv = V1Sinθ
First I find the time, since I am given the initial velocity and the launch angle. I get a value of 0.5 seconds. Then I find the vertical velocity by using the equation above, and get about 2.24 m/s. Finally, I use all the information I calculated to find the vertical distance traveled by spring toy, and yield a negative value. What am I doing wrong? I am completely stumped as I haven't been taught any new equations to find the vertical distance. Thanks for all the help!
http://zonalandeducation.com/mstm/physics/mechanics/curvedMotion/projectileMotion/generalSolution/generalSolution.html"
The vertical component of the initial velocity is 2.3sin(78^{\circ}).
V_{f} = v_{0} + at
t = \frac{V_{f} - v_{0}}{a} = \frac{0 - 2.3sin(78^{\circ})}{-9.81}.
D = v_{0}t + \frac{1}{2} at^{2} = (2.3sin(78^{\circ}))(\frac{0 - 2.3sin(78^{\circ})}{-9.81}) + \frac{1}{2}(-9.81)(\frac{0 - 2.3sin(78^{\circ})}{-9.81})^2 \approx .26 meters.
V_{f} = v_{0} + at
I used the formula and still get the same negative value.
  • · Replies 18 ·
  • · Replies 39 ·
  • · Replies 21 ·
