Calculating Sonic Boom Time: Jet Aircraft at Mach 1.5 and Altitude of 5029m
  • Thread starter Thread starter inflames829
    Sound
The discussion centers on calculating the time it takes for an observer on the ground to experience a sonic boom from a jet aircraft traveling at Mach 1.5 at an altitude of 5029 meters. The speed of sound is established at 343 m/s, leading to a jet speed of 514.5 m/s. The correct approach involves calculating the horizontal distance using trigonometric functions and then determining the time by dividing this distance by the jet's speed. The final correct answer for the time elapsed before the sonic boom is experienced is approximately 11 seconds.
  • Understanding of Mach number and its conversion to meters per second
  • Basic trigonometry, specifically sine and tangent functions
  • Knowledge of sonic boom physics and shock cone concepts
  • Familiarity with distance, speed, and time calculations
  • Study the principles of sonic booms and shock waves in aerodynamics
  • Learn about trigonometric applications in physics problems
  • Explore the conversion of Mach numbers to linear velocities in various conditions
  • Investigate the effects of altitude on sound propagation and sonic boom perception
Aerospace engineers, physics students, and anyone interested in the dynamics of supersonic flight and sonic boom phenomena.
inflames829
A jet aircraft traveling with a velocity of mach 1.5 at an altitude of 5029m passes directly over an observer on the ground. How many seconds elapse before the observer experiences the sonic boom created by the jet? speed of sound= 343ms-1
the only example i can find of this in my book has only this equation (its for the angle of the shock cone) sin theta = v sound/ v object. Can anyone give me any help on how i can work out the time from this, I am pretty sure you have to use this equation at some point. Can anyone give any help please.
Draw a picture. The sound will reach you when the shock cone hits you. It's a trig problem. Work out the horizontal distance the plane needs to travel for that. Then use that to find the time.
i did that an got the angle as 0.8867. then i used tan-1 x adjacent equals opposite, which i had as the horizontal distance. Then i used time = distance/velocity but still get the wrong answer. Can you please help, am i still doing something wrong
vsound/vobject=1/1.5. I don't get sin(theta)=1/1.5 giving me theta=0.8867. Can you check that? And tan(theta)=height/distance traveled, right?
i converted mach to meters a second but if i use 1/1.5 i get 0.73 degrees for theta. Using this i got 3171.18m for the horizontal distance. Now do i use time = distance/velocity, and if so do i keep the speed in mach or meters a second
I'll take 0.73 radians (NOT DEGREES) as a correct answer. But I still don't get your horizonal distance. Keep the velocity in m/sec. Mach is a ratio, you can't divide distance by mach and get seconds.
i still get the same horizontal distance. I use tan theta = opposite/adjacent, which i rearrange to tan theta x adjacent = opposite, so tan 0.73 x 5029 = 4500.54. Is that right because i still get the wrong answer
Opposite=5029m, right? It's the height. distance=5029m/tan(theta). theta is the opening angle of the cone, innit?
ohh, i didnt pick up on the rearranging error. Now I get the horizontal distance to be 5619.51223. Is that right. Then if i divide that by 442.5696 (which is mach 1.5) i get 12.70, but the correct answer is 11, am i still doing something wrong? do i use taht equation?
Have you thought about taking your calculator in for a tune-up? You never seem to get the same numbers I do. Mach 1.5 is (343m/sec)*1.5. I get 514.5m/sec, not 442.
thanks. I got the right answer...in the end. I was using a converter for the mach to meters a second conversation that's why i got it wrong. But thanks for the help
