How Does Viète's Formula Apply to Trigonometric Products?
  • Thread starter Thread starter ehrenfest
The discussion revolves around proving that the product of tangents, specifically Π_{k=1}^n tan(kπ/(2n+1)), equals √(2n+1) for positive integers n. Participants explore the application of Viète's formulas and de Moivre's theorem to derive the result but struggle to identify the necessary polynomial. There is confusion between using summation and product notation, which complicates the approach. Ultimately, it is suggested that both de Moivre's theorem and Viète's formulas are necessary to solve the problem effectively. The conversation highlights the challenges in connecting trigonometric identities with polynomial roots.
ehrenfest
[SOLVED] another Viete problem
Prove that for every positive integer n,
\Pi_{k=1}^n \tan \frac{k \pi}{2n+1} = \sqrt{2n+1}
http://en.wikipedia.org/wiki/Viète's_formulas
I cannot figure out what polynomial I need to apply Viete to.
Should I let
f(x) = \Pi_{k=1}^n \left(x- \tan \frac{k \pi}{2n+1}\right)
? That doesn't seem to help at all. I looked for relevant trig identities and couldn't find any. I tried induction (the case n=1 is trivial) but that failed also so alas I am stuck again. :(
Hi ehrenfest! :smile:
Hint: use de Moivre's theorem. :smile:
Hmm.
\cos n \theta (1 + i \tan n \theta) = (\cos \theta + i \sin \theta)^n
We can let \theta = pi/(2n+1). We could then sum both sides over n. But somehow we need to get a polynomial and then apply Viete to it. I don't see what polynomial to use. Sorry tiny-tim. :(
ehrenfest said:
Hmm.
:cry: (tears hair out) :cry:
But the whole point of de Moivre's theorem is that it avoids using Viete! :rolleyes:
Just do what you said … sum kπ/(2n+1) from 1 to n. :wink:
ehrenfest … you keep doing this … you get it fixed in your head that you have to do something, even when you yourself have found a way that avoids it! :smile:
Well I really didn't see how anything would simplify after I summed it:
<br /> \sum_{k=1}^n \cos \frac{k \pi}{2n+1} (1 + i \tan \frac{k \pi}{2n+1} ) = \sum_{k=1}^n (\cos \frac{\pi}{2n+1}+ i \sin \frac{\pi}{2n+1})^k<br />
But I'm sure you have some clever trick up your sleeve tiny-tim.
\cos \theta + i \sin \theta = ?
e^{i \theta}
But how does that help simplify the RHS. I know there must be something obvious I am missing? It is just the first n of the 4n+2 roots of unity but does that equal something nice?
ehrenfest said:
e^{i \theta}
But how does that help simplify the RHS?
Substituting this shows that this series is a special type of series.
What type of series?
I'm an idiot.
The RHS is
\frac{1-\exp \frac{i (n+1) \pi}{2n+1}}{1-\exp \frac{i \pi}{2n+1}}
So
<br /> <br /> \sum_{k=1}^n \cos \frac{k \pi}{2n+1} (1 + i \tan \frac{k \pi}{2n+1} ) = \frac{1-\exp \frac{i (n+1) \pi}{2n+1}}{1-\exp \frac{i \pi}{2n+1}}<br /> <br />
Sorry to keep prolonging this but I still don't see where this is going. I mean how are we ever going a product of tangents from this!
You're getting confused.
You've used ∑ instead of ∏. Your:
should be: \Pi_{k=1}^n \cos \frac{k \pi}{2n+1} (1 + i \tan \frac{k \pi}{2n+1} ) = \Pi_{k=1}^n (\cos \frac{\pi}{2n+1}+ i \sin \frac{\pi}{2n+1})^k = (\cos \frac{\pi}{2n+1}+ i \sin \frac{\pi}{2n+1})^{\sum{k=1}^{n} k}\\,=\,...<br />
hmm … the LaTeX hasn't come out right … but I hope you see what I mean! :redface:
You've used ∑ instead of ∏. Your:should be: \Pi_{k=1}^n \cos \frac{k \pi}{2n+1} (1 + i \tan \frac{k \pi}{2n+1} ) = \Pi_{k=1}^n (\cos \frac{\pi}{2n+1}+ i \sin \frac{\pi}{2n+1})^k = (\cos \frac{\pi}{2n+1}+ i \sin \frac{\pi}{2n+1})^{\sum{k=1}^{n} k}\\,=\,...<br />
Well you said sum in post #4. Sorry I still don't see where we are going with this. I agree with what you posted above and the sum of the first n integers is n(n+1)/2 but I cannot even see what will happen in the case of n=2.
Then we have
\exp i \frac{3 \pi}{5} = \cos \frac{\pi}{5} \cos\frac{2 \pi}{5}(1+i\tan \frac{\pi}{5})(1+i\tan\frac{2\pi}{5})
We can take the real part of both sides but then what?
ehrenfest said:
… the sum of the first n integers is n(n+1)/2 but I cannot even see what will happen in the case of n=2. …
ah, but if you use de Moivre again, then the n+1 cancels, and you get … ? :smile:
What? There is a 2n+1 not an n+1 in the denominator of the cosine and the sine...
Well, this was really bothering so I looked at the solution in my book that employs Viete. Using de Moivre was a good idea but I think you really do need Viete also.
