Answer: Energy Conservation: Maximum Compression & Max Velocity
The discussion focuses on solving a physics problem involving energy conservation, where a 10 kg box slides down a frictionless ramp and compresses a spring with a spring constant of 250 N/m. The maximum compression of the spring is calculated using the conservation of energy principle, equating spring potential energy to gravitational potential energy. Initial attempts yielded a maximum compression of 1.25 m, but the correct answer is 1.46 m, with the maximum velocity occurring at 19.6 cm compression. Participants emphasize the importance of considering the total distance moved by the box, including the spring's compression, in their calculations. The conversation highlights the need for careful application of energy equations to arrive at the correct results.
habibclan
A 10 kg vox slides 4.0 m down the frictionless ramp shown in the following link. It then collides with the spring whose spring constant is 250 N/m.
a. What is the maximum compression of the spring?
b. At what compression of the spring does the box have its maximum velocity?
http://i196.photobucket.com/albums/aa59/aliatehreem/chapter_10.jpg
Usf= Ug [ spring potential energy final = gravitational potential energy initial.
0.5 k x^2 = mgy
Find height corresponding to 4 m.
h= 4 sin30
a. Then use conservation of energy to find compression.
0.5 k x^2 = mgy
0.5 (250) (x ^2) = (10) (9.81) (4sin30)
x= 1.25 m
Apparently, the correct answer is 1.46 m for a. and 19.6 cm for b. Can someone please help me figure out what I am doing wrong? It would be greatly appreciated! I wish that they would give the length of the spring, then I could calculate the gravitational potential energy more accurately.
The force acting on the block is mgsin(theta) and distance moved by the block is (4 + x). In solving this problem the length of the spring is not required.
Have you taken into account that the pe of the box is minimum when the spring stops not at first contact, so the box slides (4+x) down the slope
For (b) write the energy as KE+PE+spring=0 ( get the sign's correct! ) to find an equation only in V and x.
(Oops posts clashed)
by writinf 4 + x, i get 2.2 m, which is still not the correct answer.
Also, for Ke +PE + spring=0, why is the sum 0?
0.5 (250) (x ^2) = (10) (9.81) (sin30)(4+x) .
Solve for x.
Solve for x.
Nice! Thank you so much!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
