What could be causing an ANSYS Explicit Dynamics error during solution process?
The discussion revolves around troubleshooting an ANSYS Explicit Dynamics error that occurs after the AUTODYN pre-solver setup, resulting in a general failure message. The user has confirmed that the same ANSYS version works on another PC with identical hardware specifications. Suggestions include checking for differences in setup menus between the two computers and simplifying the simulation model to identify potential issues. The conversation also explores the possibility of utilizing initial conditions to stabilize the simulation, akin to techniques used in SPICE circuit simulators. Ultimately, the focus is on diagnosing the root cause of the error to enable successful simulation execution.
Pled
TL;DR
ansys, explicit dynamics, error
I am trying to run explicit dynamics, but after AUTODYN PRE-SOLVER SETUP is complete the solution stops and the following message is displayed "A general failure occurred during the solution process."
I have installed the same ansys version on another pc and everything works ok. RAM is the same, processor is the same, both nvidia GPUS.
What could cause such an error?
Welcome to the PF. :smile:
Pled said:
Summary: ansys, explicit dynamics, error
I'd recommend going through the setup menus for the two PCs to see if there is a setting that is different between them. Can you say more about what you are simulating?
If the settings seem the same between the two computers, can you simplify the simulation to see if you can get a simpler version of the simulation to run? That might start to give some clues about what the issue is with that one computer...
I have already tried to simulate a simpler model but nothing. I am trying to simulate an impact and after pre-solver setup it simply does not initialize aytodyn solver.
With SPICE circuit simulator packages, you can often force initial conditions that help a circuit to stabilize at the start of the simulation. Sometimes you do a very long simulation to find the initial conditions of the circuit before there is a forcing function, and you can save and input those initial conditions into a quicker simulation with the forcing function.
Does the ANSYS package offer something similar? It sounds like it is having trouble finding a stable operating point to start the simulation from. Maybe output the initial operating point from the PC that has the working simulation to see if that helps the problem PC to carry forward with the rest of the simulation?
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 23 ·
37K
22K
