Ansys Maxwell 2D Number of turns
Defining the number of turns in a coil for Ansys Maxwell 2D involves integrating the number of turns into the matrix and multiplying the current by the number of turns (I*N) when assigning excitation. Users noted that Maxwell's approach is similar to Comsol, where coils are treated as single conductors with properties assigned for turns and current direction. For accurate magnetic flux calculations, parameters must be set correctly, including checking the relevant boxes in the setup and post-processing tabs. While the discussion primarily focused on Maxwell 2D, users confirmed that similar principles apply in Maxwell 3D. Understanding these steps is crucial for achieving accurate simulation results.
tya1010
Hi,
How do you define number of turns in a coil designed to operate at 100 kHz? Maxwell 2D axisymmetric treats the coils as a single conductor, how can we define number of turns. I would appreciate any response.
Thanks
I don't know Maxwell but in Comsol you simply identify a toroidally shaped shell as being a "coil" and assign N turns plus a current direction (as a cross product orientation) as a property to it. IR losses are determined by the resistivity of the material assigned. The simulator "cheats" and simplifies the B calculation based on circular sheet currents in the structure and multiplies by N.
I'm guessing that Maxwell does something like this.
Thanks for the reply. I actually figured out how to integrate the number of turns (integrate N on the matrix) and maxwell does exactly the same thing with comsol and call it post processing.
Hi tya1010. I'm having the same problem you had (with the difference that I'm using Maxwell3D in magnetostatic mode).
I'm still learning to use this software. Could you elaborate on "integrating the number of turns"? or point me to where you found that information?
Any help with be highly appreciated.
Hi,
To get the correct magnetic flux you need to simply multiply the current with the number of turns and enter I*N when you are assigning excitation. Apart from that for the correct results (for example L) go to parameters and there is two tabs one set up and the other one is postprocessing after you check the box include under set up then under postprocessing tab you can define the number of turns. These are all done on Maxwell 2D so I am not sure if it would work on 3D though.
Makes sense. As far as I can see, It's the same in Maxwell 3D.
Thank you very much!
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
