DaveC426913
2025 Award
- 24,648
- 9,020
The rope is expanding in both directions.jedishrfu said:I would say no. If you think of the end of the rope as the destination then for every second forward the ant is (1km - 1cm) further away.
I don't agree. Plugging the numbers into my formula, after 1s, ##\frac xL=10^{-5}\times 2\ln 2\approx 1.4\times 10^{-5}##, which is barely 0.007% of the length of the rope at that time.DaveC426913 said:The rope is expanding in both directions.
After one second, the ant is already about 25% along its length.
An evant horizon, amirite?Hill said:If there were a bit of acceleration of the moving end of the rope, then there would've been an "event horizon", i.e., such L beyond which the ant would've never reached the other end.
I suspect so, but haven't checked. It shouldn't be difficult to write down a generalisation of the differential equations @haruspex and I wrote down for this case, but I don't know if there is an analytical solution.Hill said:Is it correct?
But does it matter, the ant is still moving away from the destination.DaveC426913 said:The rope is expanding in both directions.
It picks up speed as it moves (slowly!) because every tiny step it takes moves it on to a bit of elastic that's moving a bit faster.jedishrfu said:But does it matter, the ant is still moving away from the destination.
That separation rate only applies initially.jedishrfu said:If you think of the end of the rope as the destination then for every second forward the ant is (1km - 1cm) further away.
At a continuously decreasing rate.jedishrfu said:Basically, the ant is effectively traveling away from the end of rope destination.
Right. Yeah. You're right.Ibix said:I don't agree. Plugging the numbers into my formula, after 1s, ##\frac xL=10^{-5}\times 2\ln 2\approx 1.4\times 10^{-5}##, which is barely 0.007% of the length of the rope at that time.
The ant is barely moving with respect to the rope, and one tiny bit of the rope is barely moving with respect to the next tiny bit, so it would be quite surprising if the ant moved very far from its end in such a short time.
Ah. There it is.martinbn said:This is quite famous it has a wiki page
https://en.wikipedia.org/wiki/Ant_on_a_rubber_rope
Aagh. Misread the question. Post struck-through.A.T. said:Why? Nothing moves faster than 1 km/s here.
The ant is always advancing to a new bit of rope, so it covers an increasing fraction of the rope. As that fraction increases, the speed with which the target moves away from it decreases. If that fraction gets big enough, its rate of crawl exceeds the rate at which the rope ahead of it is lengthening.jedishrfu said:But does it matter, the ant is still moving away from the destination.
This reminds me of the expanding universe for some reason.DaveC426913 said:Here's the animation from the wiki page:
The effect is vastly downgraded, as the rope's expansion is on the same order of magnitude as the ant's pace, but still...
The worst part is when people stand on both sides of the moving walkway and theres no method to walk around them, and the connecting flight is only 30 minutes from boarding. Sometimes it is quicker to use the regular floor.jedishrfu said:It reminds me of the horizontal escalators in airports. Some people stand still while others continue walking but it feels like running.
I’ll have to consider my answer in light of these new insights. Thank you all for showing me error of my ways.
I come up behind them and politely say "Excuse me". They always move.AlexB23 said:The worst part is when people stand on both sides of the moving walkway and theres no method to walk around them, and the connecting flight is only 30 minutes from boarding. Sometimes it is quicker to use the regular floor.
I do the same. Most of the time it worksDaveC426913 said:I come up behind them and politely say "Excuse me". They always move.
If I am irritated, as I pass I say "Walk left; stand right."
And if they give me any guff, I say "New to the Big City are we?"
You can notice from the animation that the ant absolutely moves at an increasing speed, while the rope end absolutely moves at a constant speed.DaveC426913 said:Here's the animation from the wiki page:
And that's a pretty stretchy rope.Gavran said:By the way, 8,9×1043421 years is a long period, and the ant will definitely die before it reaches the rope end.
