Antiferromagnetic ground state due to superexchange
The discussion centers on the physical mechanisms behind antiferromagnetic ground states in condensed matter systems, particularly through the lens of superexchange interactions as derived from a Hubbard Hamiltonian. Participants explore the relationship between spin configurations, energy minimization, and the role of quantum mechanics in magnetic ordering.
  • One participant describes a derivation of a Heisenberg-like spin Hamiltonian from a Hubbard Hamiltonian, emphasizing the conditions under which antiferromagnetic ordering arises due to a positive coupling constant.
  • Another participant discusses the equilibrium condition of the system, suggesting that minimizing Helmholtz's free energy is crucial, as flipping spins can increase entropy and thus lower free energy, although this may raise energy.
  • A later reply reiterates the importance of minimizing free energy but acknowledges a misunderstanding of the original question, which was more focused on quantum mechanics rather than thermodynamic potentials.
  • One participant suggests that the question might be better suited for a different forum, indicating uncertainty about the appropriateness of the current discussion context.
  • A recommendation is made to review a related post that discusses the local moment picture and how electron hopping can reduce kinetic energy, potentially linking to the antiferromagnetic state.
Participants express varying levels of understanding and focus on different aspects of the problem, indicating that there is no consensus on the physical connection between the derived Hamiltonian and the energy minimization process related to spin configurations.
Some participants express confusion regarding the quantum mechanical implications of the discussed processes, and there is a lack of clarity on how the concepts of energy and entropy interplay in the context of magnetic ordering.
physlosopher
TL;DR
How does a virtual two-step tunneling process explain antiferromagnetic ordering?
Hi all, thanks in advance for your help!
For context, I'm generally new to condensed matter and many-body QM and am working through Altland and Simons' Condensed Matter Field Theory. I'm thinking in general about magnetic ordering.
I've seen a Heisenberg-like spin Hamiltonian derived by starting with a Hubbard Hamiltonian
$$H = -t\sum_{<ij>}a^{\dagger}_{i\sigma}a_{j\sigma} + U\sum_{j}n_{j+}n_{j-}$$
where the first sum is over nearest neighbors. As long as ##U/t >> 1## we can treat the tunneling terms as a perturbation. This gives us something like $$H = -2\frac{t^{2}}{U}(1 + a^{\dagger}_{i\sigma}a^{\dagger}_{j\sigma'}a_{i\sigma'}a_{j\sigma}) = 4\frac{t^2}{U}(\vec{S}_{i}\cdot\vec{S}_{j}-\frac{1}{4})$$
From the first equality, it makes sense to me that this Hamiltonian is accounting for a process in which we essentially flip two spins at sites ##I## and ##j##. Furthermore, because our model only accounts for tunneling which a spin does not change, I think this process has to be one in which one of the spins hops to the neighboring site, and the other hops to the site that was left unoccupied (please correct me if I'm wrong!). The second equality makes it clear to me that the ordering of the ground state will be antiferromagnetic, due to the positive coupling constant.
This is all fine mathematically. I think what I am confused by is the physical connection between these two equalities. I've seen the antiferromagnetic ordering explained as originating from a virtual process in which spins reduce their energy by briefly hopping to a neighboring site. How exactly does the possibility of this process lower the energy of the ground state? Maybe asked another way, why would a ferromagnetic state, in which this virtual process is unavailable due to Pauli exclusion, necessarily raise the energy of the system?
Disclaimer: I'm very far from being able to understand Atland's book, so I didn't really follow the post either. I just wanted to share my thoughts, hoping they make sense.
Well, at equilibrium the energy of the system has to be minimum only if you fix the volume and the entropy. But here you are asking which configuration of spins represents the equilibrium condition, so the entropy is not fixed. If you flip some spins the entropy will generally change. So, in order to find the equilibrium state, it's better to minimize the Helmholtz's free energy ##F##, which requires only to fix the volume and the temperature of the system (but not the entropy). So we should look at the minimum of ##F = E - TS##. So if you flip some spins, ##S## (the entropy) increases and so ##F## decreases. On the other hand ##E## might increase. It's a tug of war between ##E## and ##S## in order to minimize ##F##.
PS: How many times did I just use the word "so"? :rolleyes:
Thank you for the response! However, my question pertains more to quantum mechanics than to which Legendre transform of the energy is being minimized.
Oh sorry, I am a bit tired, I completely misunderstood your question. I though you were asking about a different thing. Sorry I can't help you
Sorry to post again, but does anyone know whether it would be better to ask this question in a different forum?Maybe it's awkward because it's sort of a QFT question about a condensed matter system?
I recommend you read my reply to a related question in the following post:
https://www.physicsforums.com/threads/what-causes-magnetism-at-the-atomic-level.958654/#post-6085949
To quote the most relevant part:
1) Local moment picture/Heisenberg model, (Insulators): Electrons are almost entirely bound to a particular atom, however there exists enough orbital overlap such that some hopping between neighbors can occur. Recall that for a 1D quantum box of length ##L##, the energy is proportional ##L^{−2}##, thus hopping allows electrons to effectively wander through a larger box, thereby reducing the kinetic energy.
I will read your reply to the other post and think a bit, but this is very helpful. Thank you!
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 0 ·
