Any evidence of white holes in the Universe?
  • Context: Undergrad
  • Thread starter Thread starter Slavik Komarova
    Evidence Holes Universe
The discussion revolves around the existence and evidence of white holes in the universe, comparing them to black holes. Participants explore theoretical predictions, the absence of observational evidence, and the implications of these points within the context of astrophysics.
  • Some participants note that while black holes have substantial evidence supporting their existence, the same cannot be said for white holes, which raises questions about their reality versus being mere mathematical constructs.
  • One participant argues that the absence of evidence does not necessarily imply the non-existence of white holes, referencing Carl Sagan's perspective.
  • Another participant asserts that white holes are not predicted by theory in the same way black holes are, emphasizing that theoretical solutions do not guarantee physical realization.
  • Concerns are raised about how one would identify a white hole if it existed, with suggestions that one would need to calculate expected spectra and eliminate other possibilities.
  • Participants discuss the unpredictability of white holes, stating that they do not provide valid initial conditions for making predictions, unlike black holes.
  • Historical context is provided regarding the development of black hole theory, suggesting that the path to acceptance was complex and not as straightforward as some might claim.
  • One participant draws an analogy between white holes and mathematical operations, questioning the validity of comparing them to black holes.
Participants express differing views on the existence and theoretical grounding of white holes, with no consensus reached on their reality or the implications of their absence in observational data.
Limitations include the dependence on theoretical models and the unresolved nature of the discussion regarding the physical possibility of white holes versus their mathematical consistency.
Slavik Komarova
We have much evidence of the existence of black holes in our universe ... so why does not the same occur in relation to white holes since they are also the result of the same theoretical prediction ?
Astronomy news on Phys.org
What research have you done to answer that question?
lately I have researched the topic white holes and have not found an answer to some questions, among them the absence of evidence of these astrophysic objects
Do you think the absence of evidence is evidence of absence? Carl Sagan said that's not the case but perhaps in this case the absence of evidence really IS because they don't exist in the real world but are merely a mathematical construct.
EDIT: I see you've marked this thread as Advanced, so I assume you are familiar with Einstein's field equations, yes?
Simple. White holes are not predicted by theory. That a white hole solution to Einstein’s field equations exists does not mean it needs to be realized in our universe.
The black holes in our universe result from the collapse of a sufficiently large star. There is no astrophysical process that would result in a white hole.
And, at the risk of piling on, if there were a white hole in some distant galaxy, how would you tell?
Well I imagine you would calculate the expected spectrum (thermal ?) and compare it with observation. You would look to eliminate other possibilities like black hole accreation disks massive stars etc.
One could of course have made such disparaging remarks about black holes in my life time.
Regards Andrew
Picking a glaxy at random, M81 for example has a quarter of a trillion thermal sources (stars), How do you tell which one is actually a white hole?
First, the word for "how are you going to tell observationally/experimentally?" is not disparagement. It is science.
Second, the observational evidence for BH's was laid out in advance -accretion disks, nearby star orbits, interferometric imaging, GWs, etc.
The same could have be said of black holes.
In advance of what? Certainly, not the discussion of if they existed or not. You are reflecting the polished hindsight view of the reality of the the road to the acceptance of the reality of black holes and that they had been observed conclusively.
The disparagement was was in the "risk of piling on". The same question was posed about black holes it was not all laid out in advance as you stated.
Regards Andrew
  • Sad
On reflection the big difference between black and white holes was that there was/is a theoretical way to created a black hole from what had already been observed or near extrapolation while none exists (as far as I know) for white holes.
Regards Andrew
No, they aren't. To expand on previous comments, the theoretical prediction that we should observe black holes in our universe is based on (a) models of gravitational collapse to black holes, starting with the 1939 Oppenheimer-Snyder 1939 paper, and (b) theoretical work on the possible states of matter, starting with the work of Harrison, Wakano, and Wheeler in the 1950s, which showed that all non-black-hole states of matter that are supported by degeneracy pressure have a maximum mass limit, so that objects over the limit must collapse to black holes.
The above work does not predict that white holes should be observed.
You can't do this for a white hole, because a white hole is inherently unpredictable: the initial singularity inside the hole could produce anything (or, what comes to the same thing, you could say it does not provide a valid set of initial conditions at all to ground any predictions at all). That is why your comparison with black holes along these lines is not really valid: you can make predictions about what kind of spectrum black holes should produce under various conditions (making reasonable assumptions about its mass, spin, and what kind of matter is falling into it).
Yes, this is correct.
I'm not sure the historical development of BH theory and observation is quite that clean; Kip Thorne's Black Holes and Time Warps gives a good overview, in which various theoretical and observational lines proceeded in a rather jumbled fashion until the "golden age" of the 1960s when things started to be tied together into a unified picture. By the time projects like LIGO were under discussion, of course, the unified picture had been in place for some time and was indeed being used to drive various observational efforts.
In any case, it is true that observational predictions about BHs can be laid out in advance, whereas for white holes they can't; it's theoretically impossible, for the reason I gave in post #13.
PeterDonis said:
You can't do this for a white hole, because a white hole is inherently unpredictable: the initial singularity inside the hole could produce anything (or, what comes to the same thing, you could say it does not provide a valid set of initial conditions at all to ground any predictions at all). That is why your comparison with black holes along these lines is not really valid: you can make predictions about what kind of spectrum black holes should produce under various conditions (making reasonable assumptions about its mass, spin, and what kind of matter is falling into it).Yes, this is correct.
This is probably a weak analogy, but is it akin in conception to multiplying by zero as opposed to dividing by it?
Not really, that I can see. Dividing by zero is a mathematically forbidden/inconsistent operation. A white hole is not a mathematically forbidden or inconsistent solution; the issues with it are issues of physical possibility or reasonableness, not mathematical consistency.
  • · Replies 17 ·
