What is the Application of Dirac Delta in Charge Constellations?
The discussion centers on calculating the total charge, dipole, and quadrupole moments of a charge constellation using the Dirac delta function. The charge density is defined with multiple delta functions, leading to a net charge of zero. Despite the zero net charge, the dipole moment can still be calculated and was found to be zero due to cancellation. The quadrupole moment is suggested to be non-zero, indicating further complexity in the charge distribution. The use of the delta function in these calculations remains a point of confusion for some participants.
sunrah
We have to give the total charge, dipol and quadrupol moments of a charge constellation, but I seem to be falling at the first hurdle.
Q = \frac{1}{4\pi \epsilon_{0}} \int_{vol} \rho(\vec{r}) d^{3}\vec{r}
whereby the charge density of the group of particles is:
\rho(\vec{r}) =q\delta(\vec{r} - R\vec{e_{x}}) + q\delta(\vec{r} + R\vec{e_{x}}) + q\delta(\vec{r} - R\vec{e_{y}}) + q\delta(\vec{r} + R\vec{e_{y}}) - 2q\delta(\vec{r} - R\vec{e_{z}}) - 2q\delta(\vec{r} + R\vec{e_{z}})
I'm using the following property of the delta function:
\int_{vol} \delta(\vec{r} - R\vec{e_{x}}) d^{3}\vec{r} = \int_{vol} \delta(x - R) dx \int_{vol} \delta(y)dy \int_{vol} \delta(z)dz = 1
ok, so I got zero net charge. Which means I don't have a dipol or quadrupol moment either. help!
You're right. There's zero net charge. A zero net charge doesn't necessarily mean the dipole and quadrupole moments vanish, however.
That's a relief. I still find the delta function a bit confusing.
ahh, I hadn't realized that about the moments. so I worked out the dipole moment like this:
\vec{P} = \int \rho(\vec{r}) \vec{r} \delta(\vec{r} - R\vec{e_{x}}) d^{3} = \Sigma q_{i}\vec{r}_{i}
which in this case was also zero due to cancelling. I'm guessing the quadrupole moment is non-zero, which will be fun :)
  • · Replies 19 ·
