Applying Modus Tollens in Conditional Statements
  • Context: Undergrad
  • Thread starter Thread starter entropy1
    logic
9 replies · 2K views
entropy1
I can't figure out this: Say we have event B given α, denoted as {B|α}. If B happens, that implies that R happens: {B|α} → R.
Now I want to apply modus Tollens. So if I do, do I get the result: ¬R → {¬B|α}? I mean, I hope I can keep the α unaffected. Is that the case? ¬X meaning X does not happen.
This doesn't seem right to me. What you have written looks like a conditional probability, rather than one of the usual operations used in symbolic logic; e.g. conjunction, disjunction, negation, or implication. For starters B and A (let's use A rather than α) are both events, each with its own probability of occurring. The conditional probability Pr(B | A) is defined as:
$$Pr(B | A) = \frac{Pr(A \wedge B)}{Pr(A)}$$
With symbolic logic an expression is either true or false, so probability doesn't enter into the calculations. It seems to me you are mixing symbolic logic and probability.
I forgot to mention that the α signifies all other factors are left unchanged. Maybe that is reasonable? My original formulation was {B, α}, a loose formulation.
I do not see how ## \alpha## is necessary here. Just put it into ##B'##. So if ##B' \to R## and ##\lnot R## then modus tollendo tollens says ##\lnot B'##. Now that we have ##B'=\{B\,|\,\alpha\}## as given ##\alpha##, you can independently investigate ##\{B\,|\,\alpha\}## and ##\{B\,|\,\lnot \alpha\}.##
B is a specific event out of set {}B. ¬B is any event different from event B out of the same set. Likewise for R.
Suppose that {B, α} → R (1) and {¬B, α} → ¬R (2), where α is an element out of the set of possible circumstances for events out of set {}B.
Then (2) would be the same as {B, α} ← R, would it? R implies B, but not the circumstances α. α is more or less a given.
I am officially confused by your special anysets of circumstances. Reminds me a bit of the famous anykey. My first reaction was: draw me a Venn diagram.
You can only conclude ##R\longrightarrow \lnot \{\lnot B,\alpha\}##. Whether ##\lnot \{\lnot B,\alpha\} \longleftrightarrow \{B,\alpha\}## cannot be said from the information you gave us.
It sounds like you're just using {B|a} to mean B and a. The negation would be not R implies (not B or not a).
Jarvis323 said:
It sounds like you're just using {B|a} to mean B and a. The negation would be not R implies not B or not a.
Exactly what I was thinking.
It seems to come down to (Bn AND α) → Rn, or ¬Rn → (¬Bn OR ¬α).
Thanks!
Thanks!
That makes more sense. Here you're using one of de Morgan's Laws to convert ##\neg (B_n \wedge \alpha)## to ##(\neg B_n \vee \neg \alpha)##.
The modus tollendo tollens rule is a logic rule that is usually called modus tollens and which can be derived via transposition from the modus ponens rule − some writers refer to modus tollendo ponens and some writers refer to modus ponendo tollens -- anyway the modus ponens rule is that if A then B, and A, then B, and the modus tollens rule is that if A then B, and not B, then not A.
