Approaching the problem o 1D well that changes size
The discussion centers on a one-dimensional infinite potential well that is reduced in width from 'a' to 'a/2', affecting a particle in the first excited state (n=2). The allowed energy for the particle in the new well is calculated as E_2 = 16π²ħ²/m. The probability of finding the particle in the ground state (n=1) is determined using the series expansion of the wave function, yielding a probability of (c_1)² = 32/(36π²). The participants express concerns regarding the normalization of the wave function after the wall is pushed inward, highlighting the complexities of the problem.
  • Understanding of quantum mechanics, specifically infinite potential wells
  • Familiarity with wave functions and eigenstates
  • Knowledge of normalization conditions for wave functions
  • Ability to perform integrals involving trigonometric functions
  • Study the implications of wave function normalization in quantum mechanics
  • Explore the concept of potential wells and their effects on particle states
  • Learn about the mathematical techniques for evaluating integrals of trigonometric functions
  • Investigate the reverse problem of extending wave functions in quantum systems
Students and professionals in quantum mechanics, particularly those studying potential wells, wave functions, and normalization issues in quantum systems.
Emspak
You have a potential well, it's 1-dimensional and has a width of 0 to a. All of a sudden the wall of the well is pushed inward so that it's half as wide. Now the well is only extending from 0 to a/2.
in the well is a particle (mass m) that is in the first excited state n=2.
We want to know the following:
- What are the allowed energies and eigenfunctions in our new (smaller) infinite well?
- what is the probability of finding our particle in the ground state? The first excited state?
We know the ground state of a particle (the wave function) is
## \psi_0 = \sqrt{ \frac{2}{L}} \sin \left( \frac{n \pi}{L} x \right) ## and that ##E_n = \frac{\pi^2 \hbar^2}{2mL^2}n^2##
What I did here was look first at the equation for E. I can just plug in n=2 and a/2 = L and get
E_2 = \frac{16 \pi^2 \hbar^2}{m}, which tells me the n=2 energy.
So I want to know th probability of the ground state, though. For that I need the series expansion
## \sum c_n \psi_n ##
where
## c_n = \sqrt{ \frac{2}{a}} \int_0^{\frac{a}{2}} \sin \left(\frac{n\pi x}{a} \right) \sqrt{ \frac{2}{L}} \sin \left(\frac{n\pi x}{L}\right) dx##
and making sure that I plug in a/2 for L:
## c_n = \sqrt{ \frac{2}{a}} \int_0^{\frac{a}{2}} \sin \left(\frac{n\pi x}{a} \right) \sqrt{ \frac{4}{a}} \sin \left(\frac{2 n\pi x}{a}\right) dx##
pull out the constants:
## c_n = \frac{\sqrt{8}}{a} \int_0^{\frac{a}{2}} \sin \left(\frac{n\pi x}{a} \right) \sin \left(\frac{2 n\pi x}{a}\right) dx##
and we have here a pretty well-behaved function. A trig substitution / identity gives me:
## c_n = \frac{\sqrt{8}}{a} \int_0^{\frac{a}{2}} \frac{1}{2} \left[\cos \left(\frac{n\pi}{a}-\frac{2 n\pi}{a} x \right) -\cos \left(\frac{n\pi}{a}+\frac{2 n\pi}{a} x \right) \right] dx##
##= \frac{\sqrt{8}}{2a} \int_0^{\frac{a}{2}} \cos \left(\frac{ n\pi}{a} x \right) -\cos \left(\frac{3 n\pi}{a} x \right) dx##
##= \frac{\sqrt{8}}{2a} \left[ -\frac{a \sin \left(\frac{ n\pi}{a} x \right)}{n\pi} -\frac{ a \sin \left(\frac{3 n\pi}{a} x \right)}{3n\pi} \right]^{\frac{a}{2}}_0 ##
##= \frac{\sqrt{8}}{2a} \left[ -\frac{a \sin \left(\frac{ n\pi}{2} \right)}{n\pi} -\frac{ a \sin \left(\frac{3 n\pi}{2} \right)}{3n\pi}\right] = -\frac{\sqrt{8}}{2n\pi} \left[ \sin \left(\frac{ n\pi}{2} \right) +\frac{ \sin \left(\frac{3n\pi}{2} \right)}{3}\right] ##
So I see that the sine terms are
n=1 --> 2/3
n=3 --> -2/3
n=5 --> 2/3
and so on. So I want to know the probability that the particle is in the first excited state, n=2. It turns out that it can't be there, because ##c_n## is zero wherever n is even. But at n=1 ##(c_1)^2 = \frac{8}{4\pi^2}\frac{4}{9} = \frac{32}{36\pi^2}##. That's my probability for that particular state. At ##(c_3)^2 = \frac{8}{36\pi^2}\frac{4}{9} = \frac{32}{324\pi^2}##, et cetera.
Ayhow I am checking to see if I approached this thing right, and didn't make a dumb mistake.
This tells you the wave function ##\psi##. There is a 2 in there, but no longer an n.
To get the ##c_{n'}## you need to evaluate ##\int \psi^*_{n'}\; \psi##.
I have a problem with this exercise, because pushing in the wall can't leave the wave function as it was: it has to remain normalized. And I think there's no telling what that does to the energy of the particle.
(The reverse problem allows one to extend the wave function with 0 in the 'new' range, thus avoiding this renormalization issue)
As I recall the problem was stated as an infinite potential is inserted at a/2, if that helps, and the idea was w could just ignore the part of the well on the right. But if I hear you right I should set up \int \psi^*_n' \psi [\itex] as ##\int \psi^*_n' \psi_2 ## ?
As I recall the problem was stated as an infinite potential is inserted at a/2, if that helps, and the idea was w could just ignore the part of the well on the right. But if I hear you right I should set up \int \psi^*_n' \psi [\itex] as ##\int \psi^*_{n'} \psi_2 ## ? And then the issue is figuring out what n' is? (Or can I go with 1 since the well is half-size, and the wave is going to be cut in half -- foe purposes of this problem I don't think we had to renormalize).
i just tried getting the dangd Latex to work and it's buggy today. but i think you ought to be able to see what i was asking.
Yeah, you need curly brackets around {n'} :)
Cutting the wave function in half makes the probablility the particle is somewhere equal to one half, which I find hard to swallow.
Otherwise, yes, I agree: that's what I tried to bring across. n (for the full width well) is fixed to 2 by the exercise statement.
  • · Replies 24 ·
  • · Replies 19 ·
