Are all inner products just summations?
  • Thread starter Thread starter farleyknight
All inner products can be characterized as summations, with specific examples including the dot product, complex vector inner products via matrix multiplication, and integrals in Hilbert Spaces. The discussion highlights that the Cauchy-Schwarz inequality can be proven without relying solely on the summation aspect of inner products. It emphasizes that inner products on function spaces are often integrals, which can be viewed as infinite sums. The conversation also touches on the construction of orthonormal bases in finite-dimensional vector spaces and the implications of Zorn's lemma for potentially uncountable dimensions.
  • Understanding of inner product spaces
  • Familiarity with the Cauchy-Schwarz inequality
  • Knowledge of orthonormal bases and their construction
  • Basic concepts of Hilbert Spaces and integrals
  • Study the proof of the Cauchy-Schwarz inequality in various inner product spaces
  • Explore the properties of orthonormal bases using Zorn's lemma
  • Investigate the role of integrals as inner products in function spaces
  • Learn about the triangle inequality and its applications in continuity proofs
Mathematicians, students of linear algebra, and anyone interested in the theoretical foundations of inner product spaces and their applications in various fields of mathematics.
farleyknight
This isn't homework, I just want to get some intuition about something.
So I'm looking at the definition, along with some examples, of http://en.wikipedia.org/wiki/Inner_product_space" . It seems to me that the five examples they list are just special cases of summations. The dot product is obviously a summation. The complex vector version of inner product becomes a summation via matrix multiplication. The integral used on Hilbert Spaces is another version of (continuous) summation. Expectation of random variables and the trace of the product of two matrices are both just summations.
So are all inner products just a "summation", in a sense?
My main curiosity is actually how would one prove the Cauchy-Swartz inequality in any given inner product space. Does it usually involve boiling it all down to summations, or are there other standard tricks involved?
The proof of Cauchy-Schwarz does involve a trick. But it doesn't use the fact that that the inner product is defined as a form of summation. It looks the same in any inner product space.
Unfortunately, immediately after I posted, I scrolled further down the Wikipedia page and I think I saw the trick you are talking about. :(
Are there other inequalities (I know of the triangle inequality off hand) that are useful in continuity proofs? I'm looking to get some more practice with this area. Most of my day dream math is usually abstract algebra, so I'm not as familiar with this topic as I ought to be..
Personally, I do not know of an inner product that couldn't be "abstractly" characterized as a sum. For example, inner products on function spaces are often integrals, which some might argue are infinite sums. A common inner product on matrix spaces is the trace-inner product which again can be written in terms of a sum.
Probably the reason why sums are so common when dealing with inner products is that one inherently has "addition" on the vector space. Since the inner product must itself be conjugate linear in its arguments, that linearity often manifests itself in terms of a summation on the underlying field.
So if you don't count integrals as sums, there's an example for you. Unfortunately though, if your question is "is there an inner-product on a vector space that does not make use of the underlying field addition", that's too advanced a question for me to answer.
If you write things in the correct basis then yes, but not really in the way that you are describing it.
Let's look at just the finite dimensional case. You have some inner product <,> and a vector space V of dimension n. Start by picking any vector, which we will call e1 such that <e1,e1>=1 (we know we can do this because if <v,v>=x, then <v/sqrt(x),v/sqrt(x)>=x/x=1) If U is the set of vectors orthogonal to e1, we can pick a vector e2 from U such that <e2, e2>=1. Then if W is the set of vectors orthogonal to both e1 and e2 we can pick a vector e3 from W whose inner product with itself is 1 also.
Eventually we've picked vectors e1,...,en which are mutually orthogonal and each have <ei,ei>=1. If you write out a vector v as v=\sum_i &lt;v, e_i&gt; e_i in the coordinates of this basis, then one can see that &lt;v,u&gt;=\sum v_i u_i where v_i=&lt;v,e_i&gt;.
So basically every inner product is just the dot product with respect to some basis.
This isn't really the right way to approach the Cauchy-Schwartz inequality though
Office Shredder:
Have you not implicitly assumed that your vector space is of countable dimension? I don't think it needs to be separable let alone countable.
Kreizhn said:
Office Shredder:
So that probably means it's countable
However, Zorn's lemma guarantees you can find some (possibly uncountable) orthonormal basis (in which you allow infinite series as well as finite sums of basis vectors
Ah yes, I must have missed that. Mea Culpa.
For example, the set of all functions, defined on interval [a, b] such that \int_a^b f^2(x) dx is a vector space on which an inner product (dot product) can be defined as \int_a^b f(x)g(x)dx.
  • · Replies 43 ·
