Are You Struggling to Understand Reference Frames in Relativistic Dynamics?
6 replies · 4K views · last reply
Insights Author
I'm having trouble getting all of the relativistic dynamics information straight in my head. In particular, I'm having trouble with reference frames. It seems that when I am trying to solve problems, even simple ones, I am struggling with what each observer in the different frames should be seeing.
For example, let's say in the rest frame O an observer sees a particle moving with velocity V. The particle has a four velocity given by (note: I use c=1 units everywhere)
[tex]\bar u = \frac{d \vec x}{d \tau} = (\gamma, \gamma \vec V)[/tex]
and the four force on the particle would be
[tex]\bar f = \gamma (\vec F \cdot \vec V, \vec F)[/tex]
Now let's say an observer in the frame O', moving with velocity v along the x-axis of O, observes the particle. From the velocity law, he sees the particle moving at speed:
[tex]V^{x'} = \frac{V^x-v}{1-vV^x}[/tex]
where [itex]V^x[/itex] is the observed velocity in O.Question: Is it true that the particle's four velocity and four force are transformed to use this [itex]V^{x'}[/itex] ? Why or Why not?
Question: Is the velocity in the Lorentz Factor [itex]\gamma[/itex] the velocity of the particle in the rest frame V, or the relative velocity between the frames v?
Question: Is it correct to say that for any problem where a particle's velocity is being observed there are 3 reference frames to worry about: the rest frame O, the moving frame O', and the frame of the particle? If it is relevant, I encountered these thought problems while trying to find the four force and four velocity components for a particle moving in the Lorentz Force Field (Hartle problem 5.21),
[tex]\vec F = \frac{d \vec p}{dt} = q(\vec E + \vec V \times \vec B)[/tex]
which is invariant between inertial frames.
I realize that this is all quite basic stuff math wise, but the thought process that leads to the correct calculations is giving me trouble, and it is crucial I get it solidified into my head correctly.
Yes, of course. In O', the only thing you see is the particle's three-velocity Vx'. The four-velocity and four-force aren't going to depend on quantities observed in a different frame. After all, there would be an infinite number of frames you could choose from, right? Which one would you pick?
If you're calculating the four-force or four-velocity in O', you'd use neither. You'd use the three-velocity of the particle as observed in O'. Is this what you were asking about? Your question seemed a bit ambiguous.
Not for any problem. In particle physics, sometimes you can do an entire problem in the lab frame; sometimes, it's convenient to use a center-of-mass frame, where none of the particles is at rest; sometimes, you find the particle's rest frame a convenient choice. If you're working with massless particles, like photons, there is no rest frame (of the particle).
The lorentz factor is,
[tex]\gamma = \frac{1}{\sqrt{1-v^2}}[/tex] in units of c=1.
My question related to the fact that many things get multiplied by this gamma factor: Lorentz Coordinate Transformations, four-velocity, etc.. but is the velocity in gamma always the same? i.e. Are we using the velocity between frames in gamma for the Lorentz Transformations, but the three-velocity in gamma when calculating the four-velocity?
No, the appropriate velocity in γ depends on the context. For the four-velocity, it is the velocity of the particle. For a Lorentz boost, it's the velocity of the moving frame.
Just to make sure I understand, is this correct?
"Assume that in all frames the force on a charged particle is given by the lorentz force law (given above). Consider a frame moving with speed v along the x-axis relative to the lab frame. Find the components of the 4-force in terms of E, B and the components of the 4 velocity."Assume the particles velocity is [itex]V'=\frac{V-v}{1-Vv}[/itex] as observed from the moving frame. Then,
[tex] \bar f' = \gamma (\vec F \cdot \vec V', \vec F)[/tex]
[tex]\vec F \cdot \vec V' = q(\vec E + \vec V' \times \vec B) \cdot \vec V'=q|E||V'|cos 0 =qEV'[/tex]
because V'xB is perpendicular to V' their dot product is zero.
[tex]\bar f' = \frac{q}{\sqrt{1-\vec V'^2}} \left [ EV', (\vec E + \vec V' \times \vec B) \right ][/tex]
and since,
[tex]\bar u' = \frac{1}{\sqrt{1-\vec V'^2}} ( 1, \vec V' ) = ( \vec u_{t'}, \vec u_{x'})[/tex]
we get:
[tex]\bar f' = q\left [ E \vec u_{x'}, (\vec E \vec u_{t'} + \vec u_{x'} \times \vec B) \right ][/tex]
You're assuming the electric field and velocity point in the same direction. If you don't assume that, the best you can do is say that
[tex]\vec{F}\cdot\vec{V}' = q\vec{E}\cdot\vec{V}'[/tex]
