Area Of An Isosceles Triangle As A Function Of Theta
The area of an isosceles triangle as a function of the vertex angle θ and the length of the congruent sides x is correctly expressed as A = (1/2) x^2 sin(θ/2) cos(θ/2). The derivative of the area with respect to time, dA/dt, is derived incorrectly in the discussion. The correct approach involves using partial derivatives, specifically dA/dt = (∂A/∂x)(dx/dt) + (∂A/∂y)(dy/dt), where both x and θ are functions of time. The discussion emphasizes the importance of clarity in defining variables and their relationships.
  • Understanding of trigonometric functions, specifically sin and cos.
  • Familiarity with the concept of derivatives and partial derivatives.
  • Knowledge of the geometric properties of isosceles triangles.
  • Basic calculus, particularly in relation to functions of multiple variables.
  • Study the derivation of the area of triangles using trigonometric identities.
  • Learn about partial derivatives and their applications in multivariable calculus.
  • Explore the relationship between geometry and calculus in dynamic systems.
  • Investigate the implications of changing variables in geometric formulas.
Mathematicians, physics students, educators, and anyone interested in the application of calculus to geometric problems.
Bashyboy
Would this would the proper function, as described in the title of this thread, A = 1/2 x^2 \cos \frac{\theta}{2}?
And suppose that the side x and the angle were changing with time, would the derivative, with respect to time, be \frac{dA}{dt} = x \cos \frac{\theta}{2} - 1/4 x^2 \sin \frac{\theta}{2}?
Did I properly derive these?
You could use some parentheses in those expressions. A much easier formula to work with is$$A =\frac 1 2 x^2\sin\theta$$
I neglected to answer that. The answer is no.
You really have left a lot to us to interpret. I assume that you mean that "\theta" is the "vertex" angle- the one opposite the "odd" side. Further, I assume that you are taking "x" to be the length of the two congruent sides. I can't be certain because you do not say any of that.
If that is what you intended, the dropping a perpendicular from the vertex gives two right triangles with angle \theta/2 and hypotenuse of length x. The "opposite side", half the base of the original triangle, has length x sin(\theta/2) and the "near side", the altitude of the original triangle, is x cos(\theta/2). The whole base of the triangle is 2x sin(\theta/2) and so the area is A= (1/2)(2 x sin(\theta/2))(x cos(\theta/2))= x^2 sin(\theta/2) cos(\theta/2)[/itex].<br /> <br /> In any case, your result, dA/dt= xcos(\theta/2)- (1/4)x^2 sin(\theta/2) cannot possibly be correct because there is no derivative with respect to time. If A is a function of x and y and both are functions of t, then dA/dt= (\partial A/\partial x)(dx/dt)+ (\partial A/\partial y)(dy/dt). You have only &quot;\partial A/\partial x+ \partial A/\partial y&quot;.
  • · Replies 20 ·
