Area of Window w/ Perimeter 15ft: Function of Side Length
  • Thread starter Thread starter skeeterrr
    Area Function
4 replies · 4K views
skeeterrr
A window has the shape of a rectangle surmounted by an equilateral triangle. Given that the perimeter of the window is 15 feet, express the area as a function of the length of one side of the equilateral triangle.
A = lw
A = 1/2(bh)
By using the Pythagorean theorem, I find the height of the triangle.
Let x represent the side length of the triangle, which is equal to the side of the rectangle which the triangle is surmounted on.
Let h represent the height of the triangle.
h^2 = x^2 - (x/2)^2
h = root(x^2 - (x/2)^2)
h = root (x^2 - (x^2)/4)
h = root ((3x^2)/4)
h = (x root(3))/2
Let P(x) represent the perimeter of the window, and let y represent the other sides that is not equal in side length of the triangle.
P(x) = 15
15 = 3x + 2y
15 - 3x = 2y
15/2 - 3/2x = y
Let A(x) represent the area of the window.
A(x) = xy + 1/2(xh)
A(x) = x(15-3x)/2 + 1/2(x(x root(3)/2)
A(x) = 15x - 3x^2 + (x^2 root(3))
2 4
A(x) = 30x - 6x^2 +x^2 root(3)
A(x) = x(30 - 60x + x root(3))
I am stuck here, I'm not sure if I am even doing it right... Any insights will be appreciated!
on Phys.org
Since x is the length of both the triangle sides and the sides of the square, then the perimeter consists of two triangle sides and three sides of the square (each of which is x). I'm not sure why y is needed in your formulation. I'd think you'd start with 5x = 15. Thoughts?
--Elucidus
EDIT: Nevermind. I see now the bottom portion of the window is a rectangle. I must be seeing things. I originally read "square" the first time I read the problem through.
Your work looks correct. The formula is not pretty.
Thanks for the reply
Can I go further with this equation or anything? I'm a little skeptical...
Only to rearrange the function expression,
e.g.
[tex]A(x) = \frac{(\sqrt{3} - 6)x^2 + 30x}{4}[/tex]
or
[tex]A(x)=\frac{15}{2}x - \frac{3}{2}x^2 + \frac{\sqrt{3}}{4}x^2[/tex]
or somesuch. Either way you slice it, it's clunky.
--Elucidus
Cool, thanks for your help!
