Aspect ratio for a motorcycle tire
The aspect ratio of motorcycle tires significantly influences handling characteristics, particularly in sportbike and racing applications. A lower aspect ratio results in a circular profile that enhances turn-in responsiveness, while a higher aspect ratio creates a more parabolic shape, increasing contact area during lean and reducing resistance to leaning. Load capacity is primarily determined by tire construction and size rather than aspect ratio. Understanding these dynamics is crucial for optimizing motorcycle performance and rider confidence during cornering.
  • Understanding of motorcycle tire construction and sizing
  • Knowledge of tire aspect ratio and its impact on handling
  • Familiarity with sportbike dynamics and cornering techniques
  • Basic principles of physics related to motorcycle stability
  • Research the effects of tire aspect ratio on motorcycle handling
  • Explore different tire profiles and their applications in racing
  • Learn about tire construction materials and their influence on load capacity
  • Investigate the relationship between tire width and performance characteristics
Motorcycle enthusiasts, sportbike riders, tire manufacturers, and anyone involved in motorcycle performance optimization will benefit from this discussion.
mec_divi
can anyone tell me the method by which the aspect ratio for the motorcycle tire can be decided given that load capacity of bike is known.
I guess it depends on what type of tire, and what the application is.
For sportbike/racing tires, the aspect ratio helps to determine the "turn-in" characteristics of the tire. If it has too low/wide of a profile, it is very hard to turn into a corner (hard to force the bike to lean). If it is too tall, the bike is very "skittish" at turn-in, and can be downright unstable and scary. Don't ask me how I know this. o0)
Can you say what your application is? What range of aspect ratios do you see for the tires you are looking at? :smile:
Load capacity is usually a function of tire construction and size as opposed to aspect ratio.
To help explain berkeman's answer, for the same treadwall height, a higher aspect ratio will be more parabola like, while a lower profile will be circular or lower still like a flattened circular arc. A more parabola like profile will provide more contact area when leaned, and have less resistance to leaning over. For a given aspect ratio, a taller treadwall will flatten the profile. To a rider, the sensation of a more parabolic profile is that it takes less countersteering effort to lean the bike, and the rear end can feel like it's stepping out more, if the rear tire is wider than the front, and the tires profiles have just been changed, as a rider will acclimate to the new feel. I don't recall if you get the same sensation if the front and rear tire are the same (the last bike I had with the same front and rear tires was a 1973 Norton 850 Commando, which used parabolic profile Dunlop K81 or K181 tires, and I don't recall the sensation of the rear end stepping out).
  • · Replies 28 ·
