Associated Legendre Function with Angles
The discussion centers on the validity of using the substitution x = cos(θ) in the context of associated Legendre functions. It highlights that while the left-hand side of the equation is always positive, the right-hand side can be both positive and negative depending on the angle θ. The importance of managing the range of θ is emphasized, particularly noting that in spherical coordinates, θ is typically constrained between 0 and π, ensuring that sin(θ) remains non-negative. This range allows for the effective application of the substitution in mathematical contexts. Overall, the substitution is justified within the specified domain of the associated Legendre functions.
bryanso
In Associated Legendre Function with Angles ... why is the following argument used?
## \sqrt{1 - x^2} = sin\,\theta ##
In Wikipedia https://en.m.wikipedia.org/wiki/Associated_Legendre_polynomials, Section Reparameterization in terms of angles, I see this argument:
Let ## x = cos\,\theta ##
This is also in Griffiths' Introduction to Quantum Mechanics.
Why is this a valid argument?
The LHS is always positive. The RHS is sometimes positive and sometimes negative. ##\theta = -1## makes it wrong.
Yes, one has to manage the range of the angels. For ##\theta > \pi## we need the negative root. I assume that most applications have angels from ##[0,\pi]## and in the other case: switch to the opposite orientation of the coordinate system. The problem only occurs if angels occur in both ranges.
Thanks!
bryanso said:
Homework Statement:: In Associated Legendre Function with Angles ... why is the following argument used?
Relevant Equations:: ## \sqrt{(1 - x)^2} = sin\,\theta ##
No, that's not what it says. Instead, it's ##\sqrt{1 - x^2}##. This is a standard substitution used in trig substitution in integrals.
You also have the same incorrect equation in your Relevant Equations.
It's better to manage the range of the angles. I don't think we'd have much luck trying to manage angels.
Likes fresh_42
Yes I had a typo. I will try to edit it. The question remains.
Thanks. I have edited the equations.
The range of ##\theta## in spherical coordinates (which is where the associated Legendre functions are used) is 0 to ##\pi##. Therefore ##\sin(\theta)## is always positive.
Likes vela, vanhees71 and marcusl
Put differently, the domain of the associated Legendre functions (just as that of the Legendre polynomials) is [-1,1]. This is why ##x = \cos\theta## works so well with ##\theta \in [0,\pi]## (and, consequently, ##\sin\theta \geq 0##).
Likes vela
  • · Replies 22 ·
