At which points on the x-axis (not at infinity) is the electric potential zero?
The electric potential is zero at two specific points on the x-axis due to the presence of two point charges: -2Q at the origin and +3Q at x = L. The potential at a point x is given by the equation V = k(-2Q/|x|) + k(3Q/|L-x|). Setting V to zero and solving for x reveals that the potential is zero at one point between the charges and another point outside the charges, closer to the -2Q charge. The absolute values of x and L-x must be considered to accurately determine the locations where the potential equals zero.
  • Understanding of electric potential and its mathematical representation
  • Familiarity with Coulomb's law and point charges
  • Knowledge of absolute values in mathematical equations
  • Basic algebra for solving equations
  • Study the concept of electric potential and its calculation for multiple charges
  • Learn about the implications of absolute values in physics equations
  • Explore the differences between electric potential and electric field
  • Investigate the behavior of electric potential in various charge configurations
Students studying electrostatics, physics educators, and anyone interested in understanding electric potential in relation to point charges.
dmitriylm
Two point charges -2Q and +3Q are on the x-axis at the origin and at
x = L. Find all the points on the x-axis (not at infinity) where the electric
potential is zero. Express your answers in terms of L and Q.
V= k*Q/r
I understand that when dealing with two positive charges there is a point between them (if they are equal magnitude, this would be right at d/2) where the field magnitude is zero (because the fields repel each other) but with two opposite charges am I wrong to assume that the only place where the potential would be zero would be directly at the negative charge as field lines always point in the direction of decreasing potential? How would I express this?
The electric field decreases from the point proportional to 1/r^2 so at distances close to one of the charges it's electric field dominates. So you are looking for a point closer to your -Q point since it is a lower magnitude.
That's what I was thinking, that zero potential would be directly at the origin. How would I express this in terms of L and Q?
The potentials will be zero at the points where pogtential due to -2Q and 3Q are equal. You will get two such points. One in between the charges and another out side the two charges, nearer to the smaller charge.
Would this be correct:
k(-2)/L + k(+3)/L = 0
-2/L + 3/L = 0
-2/L = -3/L
Potential is equal to zero at L = -2 and -3?
-2/L + 3/L = 0
-2/L = -3/L
N0. Let x be the distance from -2 where the potential is zero. So
k(-2)/(x) = k(+3)/(L-x)
For the second answer
k(-2)/(x) = k(+3)/(L+x)
Solve for x.
If the ‒2Q charge is at the origin and the 3Q charge is at x=L, then the electric potential at location x on the x-axis is given by:
V=k\frac{-2Q}{|x|}+k\frac{3Q}{|L-x|}
Set V=0 and solve for x.
BTW: You are looking for the location(s) where electric potential is zero, NOT the location(s) where the electric field is zero.
How do you end up with more than one answer for x, using the above location? Do you have to use the abs. value of L-x or something??
Yes, you need to use abs. value of both x and L-x.
0 < x < L : If x is between 0 & L, assuming L is a positive number, then |x| = x, and |L-x| = L-x.
x < 0 < L: If x is negative, then |x| = -x, and |L-x| = L-x
0 < L < x : If x is greater than L, then |x| = x, and |L-x| = -(L-x) = x-L
Since we're looking for V=0, the last two cases give equivalent equations.
  • · Replies 22 ·
