Athlete jumps at angle with distance find speed
  • Thread starter Thread starter afa
    Angle Speed
The discussion revolves around a physics problem involving projectile motion, specifically analyzing the take-off speed of an athlete jumping at an angle. The original poster presents a scenario where the jump distance is known, and there is a question about how an increase in speed affects the jump distance.
  • Participants discuss the relationship between jump distance and take-off speed, with some attempting to apply trigonometric equations to find the speed. Questions arise regarding the specifics of the jump's trajectory, including whether the distance is horizontal, vertical, or diagonal. There is also a focus on the importance of time in solving the problem.
The discussion is ongoing, with various participants offering insights and raising questions about the assumptions made in the problem. Some guidance is provided regarding the use of equations of motion, but there is no clear consensus on the approach to take or the necessary information required to solve the problem effectively.
There are mentions of missing information, such as the time of flight, which complicates the ability to solve for the unknown variables. Participants express uncertainty about how to proceed with the calculations given the constraints of the problem.
afa
Leaves the ground at a 33.6 degree angle and travels at 7.77 m. What is take off speed?
If speed were increased by 4% how much longer would the jump be?
Vx=Vcos(theta)
7.77=vcos33.6 got 9.33 but says it wrong, then I added 4% to this and did 9.7cos33.6 which also seems to be wrong..what am I missing?
Time my friend-time. What`s the time what it takes to travel.
Hi afa, could you be a little more specific please, you say he travels 7.77m, but where? Horizontally / Vertically / Diagonally? Is this all of the question or is there more detail to it?
Jared
I'm having a similar problem:
An athlete executing a long jump leaves the ground at an angle of 30 degrees and travels 8.90m. What was the take-off speed?
Both responses from juggernaut and myself above apply to this second problem as well.
Jared
travels horizontally 8.90m, no vertical displacement, time is unknown, how do I solve for two variables? Or what do I substitute velocity or time with to solve for the other?
Leaves the ground at 30 degrees, but there's no vertical displacement?
You really do need the time factor, and based on what you have given you can't calculate it as far as I can tell.
I'm not sure if you can solve with only two variables. Try rearranging your equations of motion to get something you can solve (perhaps simultaneously).
You can't just substitute time or velocity as they'll generate different answers.
dmkeddy, you should start your own threads for things like this and not hijack an old one as it will gain you a better response.
Since you have to assume that his y displacement is zero by the time he lands, you could use the range equation for this which is (v^2)sin(2x)/g. You know the range is 7.77 and you know x, which is the angle. So solve for v. For the second case, all is being kept constant, except for velocity. So the equation should be kept normal but except for where you write v^2 write (1.04v)^2. If you simplify, you'll note that everything is the same except for the 1.04^2. Hence, just multiply 7.77 by 1.04^2.
  • · Replies 26 ·
  • · Replies 18 ·
