- 3,625
- 3,307
As the atmosphere (the global system, not some parcel or air) being in equilibrium (between the amount of water evaporating and condensing, not being at 100% humidity).phyzguy said:How else should we interpret your statement below?
I guess I also don't see how overall/average water vapor content could be constant in a changing climate. Indeed my understanding was that one of the fears is that water vapor content would rise with temperature, creating a positive feedback.Bandersnatch said:As the atmosphere (the global system, not some parcel or air) being in equilibrium (between the amount of water evaporating and condensing, not being at 100% humidity).
I must be having a really bad day at expressing myself.russ_watters said:I guess I also don't see how overall/average water vapor content could be constant in a changing climate. Indeed my understanding was that one of the fears is that water vapor content would rise with temperature, creating a positive feedback.
I am at risk of a thread deviation of my own thread, but ... errrr, so just for clarity what do you think causes rain?Bandersnatch said:As the atmosphere (the global system, not some parcel or air) being in equilibrium (between the amount of water evaporating and condensing, not being at 100% humidity).
cmb said:Just say what you think this equilibrium level is, then
I didn't spot the number there. Did I miss it?bhobba said:The general principle is rather easy. Water vapor from the sun heating oceans, lakes etc - rises - the higher you go the colder it gets and it begins to condense, form droplets and falls to earth. This forms an equilibrium along with other gasses. Now let's add a little bit of another greenhouse gas like CO2 - but there are many others eg O2 and Methane. They have a crucial difference to water - they do not condense out. This little bit raises temperature a little bit which causes more evaporation, more water vapor, and hence by the greenhouse effect the temperature rises, so you get a positive feedback loop. This is the runaway greenhouse effect some worry about. But to counter this more clouds form which absorbs some of the sunlight reaching Earth so less water vapor and you have the opposite effect - a lowering in temperature. It will form a new equilibrium. To try and figure the equilibrium out we have climate models - and of course there are obviously other factors involved - they too must be taken into account.
The above is just the basics, but I think anyone into science should know it and be able to explain it to people. There are people that think the small amount of CO2 added by man can't possibly make any difference - and they can mount a very persuasive argument - the above explains why that is wrong.
But the models do not all produce the same result eg MIT researchers has the runaway effect not happening until we reach 152%:
http://news.mit.edu/2018/how-earth-sheds-heat-space-0924
Slightly worrying though is it does not contain a link to the associated peer reviewed paper.
Others say doom is only about 11 years away.
This is the sort of thing that makes discussing climate science - how to put it - problematical. I am fairly sure of the basics - but beyond that - shrug.
Thanks
Bill
cmb said:I didn't spot the number there. Did I miss it?
