blue_lilly
- 36
Consider a pretend atom for which the electrons can be in anyone of the following energy states:
Label Energy
A -1.400×10-18J
B -8.000×10-19J
C -5.000×10-19J
D -3.000×10-19J
Start by arranging the four levels on a graph, then answer the following questions.
A) An electron jumps from one energy state to another, as described in each of the statements below. Describe whether a photon is absorbed or emitted in the process.
From level B to level A [Absorbed/Emitted]
From level D to level C [Absorbed/Emitted]
From level A to level C [Absorbed/Emitted]
From level C to level B [Absorbed/Emitted]
Incorrect Answer: 1)Emitted 2)Absorbed 3)Absorbed 4)Absorbed
B) What is the energy of the photon absorbed in the transition from level A to level C?
9 E-19J This is the Correct Answer
C) Label each of the following photons as ones that can or cannot be absorbed by this atom. The value stated is the energy of the photon.
7.00 E-19 J [Can be Absorbed/ Cannot be Absorbed]
4.00 E-19 J [Can be Absorbed/ Cannot be Absorbed]
1.40 E-18 J [Can be Absorbed/ Cannot be Absorbed]
6.00 E-19 J [Can be Absorbed/ Cannot be Absorbed]
2.00 E-19 J [Can be Absorbed/ Cannot be Absorbed]
Energy(Absorbed) = Energy(Final) - Energy(Initial)
Energy(Emitted) = Energy(Initial) - Energy(Final)
Absorbs a Photon- when electron moves into a higher energy state
Emits a Photon- when electron moves into a lower energy state
A) The problem says that you first need to arrange the 4 energy levels on a graph. The new order I got was:
B -8.000 E-19 J
C -5.000 E-19 J
D -3.000 E-19 J
A -1.400 E-18 J
1) From level B to level A ; Starting a B and moving to A means that the electron would be moving to a lower energy state, so this would be Emitted.
2) From level D to level C ; Starting a D and moving to C means that the electron would be moving to a higher energy state, so this would be Absorbed.
3) From level A to level C ; Starting a A and moving to C means that the electron would be moving to a higher energy state, so this would be Absorbed.
4) From level C to level B ; Starting a C and moving to B mean that the electron would be moving to a higher energy state, so this would be Absorbed.
This is incorrect!B) Photon starts at Energy Level A and moves to Energy Level C
E-absorbed=EnergyLevelInitial -EnergyLevelFinal
E-absorbed=(1.400 E-18) - (5.00 E-19)
E-absorbed= (9 E-19 J) This is Correct!
C) This problem says that the value they will give you is the E-absorbed. So I thought I was just supposed plug that number into the equation:
But I couldn't figure out what either the Final Energy nor the Initial Energy would be. So instead I used the graph to figure out what levels the atom can possibly absorb:
B -8.000 E-19 J
C -5.000 E-19 J
D -3.000 E-19 J
A -1.400 E-18 J
Initial A Final D ; (1.400 E-18) - (3.000 E-19) = (1.1 E-18)
Initial A Final C ; (1.400 E-18) - (5.000 E-19) = (9.0 E-19)
Initial A Final B ; (1.400 E-18) - (8.000 E-19) = (6.0 E-19)
Initial D Final C ; (3.000 E-19) - (5.000 E-19) = (-2.0 E-19)
Initial D Final B ; (3.000 E-19) - (8.000 E-19) = (-5.0 E-19)
Initial C Final B ; (5.000 E-19) - (8.000 E-19) = (-3 E-19)
And then I compared those numbers to the photons given in the question.
1) 7.00 E-19 J ; can't
2) 4.00 E-19 J ; can't
3) 1.40 E-18 J ; can't
4) 6.00 E-19 J ; can
5) 2.00 E-19 J ; can't
But those answers are incorrect.Any help would be greatly appreciated.
