Atwood machine: finding maximum height with work-energy theorem
3 replies · 2K views
Shah 72
MHB
Particle X of mass 2 kg , and particle Y of mass m kg are attached to the ends of a light inextensible string of length 4.8m. The string passes over a fixed smooth pulley and hangs vertically either side of the pulley. Particle X is held at ground level, 3m below the pulley. Particle X is released and rises while particle Y descends to the ground
a) Find an expression in terms of m for the tension in the string while both particles are moving.
By getting two equations
T-20=2a and T-10m=-ma
Solving simultaneously and removing a I got mT+2T-40m=0,
I finally got T=40m/(m+2) N
b) use work energy principle to find how close particle X gets to the pulley in subsequent motion.
Iam not able to get this ans. Pls help
Mathematics news on Phys.org
work done on the 2kg mass by the force of tension ...
$W = (T \, Newtons) \cdot (1.2 \, meters) = 2gH$, where $H$ is the highest point mass X rises above ground level.
Thanks!
The problem I have with
"a) Find an expression in terms of m for the tension in the string while both particles are moving.
T-20=2a and T-10m=-ma"
is that you have not said what either "T" nor "a" are!
I can guess that "T" is the tension in the string and that "a" is the acceleration of the particles but you really should have said thar.
