Atwood machine with block removed after 2 seconds
konichiwa2x
Hi this problem stumps me.
Two bricks each having a mass of 0.2 kg tied at the end of a light flexible cord and are passing over a small frinctionless pulley. A 0.1kg block is placed on one of the blocks and removed after 2 seconds. How far will each block move in the first second the 0.1kg block is removed?
My Work:
for one of the blocks: [tex]0.3(10) - T = 0.3a[/tex]
for the other block: [tex]T - 2 = 0.2a[/tex]
solving, [tex]a = m/s^2[/tex]
Then I found the velocities of each block after the 0.1kg block is removed. i,e [tex]v = 2(2) = 4m/s[/tex]
actually, one of the blocks will have 4m/s and the other -4m/s.
for the block that has -4m/s velocity,
the displacement in the first second:
[tex]s = -4(1) - \frac{1}{2}(10)(1)[/tex]
[tex]= -9m[/tex]
and for the other block i got the displacement as 1m.
BOOK SOLUTION: my book says the correct answer is 4m for each block.
Please tell me where I went wrong. Thanks for your time!
After the one kg block is removed, there is not acceleration of the two blocks. One 2 kg block balances the other, and both contribute to the tension in the cord.
One calculated the speed a 4 m/s for one block and -4 m/s for the other block, i.e. one moves up and the other down. In one second, what is the distance traveled at constant velocity?
allright thanks. got it now:smile:
by the way, can you please look at this thread I posted earlier today?
https://www.physicsforums.com/showthread.php?t=132919 It is related to the same topic. I have been practicing laws of motion problems all day and I really want to get it straight. only that question is left..thanks
