Atwood machine with friction on one block
1 reply · 2K views
natalydj83
Please help with friction and acceleration
hw Problem:
A block of mass 1 kg rests on a tabletop with coeficient of kinetic frictionequal to 0.3. The block is conected by a string which passes over a frictionless pulley to a second block of mass 2kg which hangs vertically from the string. The acceleration of the two block is...?
mass(1)=1kg
mass(2)=2kg
uk=0.3(coeficient)
Fr(friction)=uk*Fn(normal force)
My solution:
(x)F=ma
box 1
component (x)=Ft(force tension)-Ffr(friction)=ma
component (y)=Fn(normal force)-mg(weight)=m(a=0)
Fn=mg
Fn=1kg*9.8=9.8N
component (x)=Ft-uk*Fn=ma
component (x)=Ft=ma-uk*Fn
Ft=ma-0.3*9.8=ma-2.94
Ft1=ma-2.94N
Box 2
component (y)=mg-Ft=ma
mg-ma=Ft
Now: Ft1=Ft2
m(1)a-2.94=m(2)g-m(2)a
a=(m(2)g+2.94)/m1+m2
a=(2*(9.8)+2.94)/2+1=7.51m/s^2
IS THIS SOLUTION RIGHT? If not please indicate where i made a mistake
and how to fix it
Your solution is correct. The only thing I would suggest is to label the directions of the forces and acceleration to make it clearer. Also, it's always a good idea to check your units to make sure they are consistent throughout the problem. In this case, the units for the tension force are in Newtons (N) and the units for the acceleration are in meters per second squared (m/s^2). Overall, you did a great job breaking down the problem and using the correct equations to solve for the acceleration.
