Homework Helper
- 4,078
- 2,127
- TL;DR
- How often do you get to see an orbital-class rocket operate in ground effect?
Here is an interesting YouTube video explaining what happened with the most recent Astra launch. One of five rocket engines failed almost immediately.
According to the video, this left the rocket with a thrust-to-weight ratio of 1.00 until the fuel burned off. But it took about 10 seconds before it started rising. So the direct thrust would have been below 1.00 for most of that 10 seconds.
Since the navigation system performed spectacularly well - it is best to assume that it was generating as much thrust as it could to pull itself out of this mess. That leaves only one possible reason for it to hang out that close to the ground without any substantial change in altitude: ground effect.
In fact, I think this might require that some descriptions of ground effect be rewritten - because this is one case where it cannot be described in terms of reduced drag on a lift system.
