How Can I Suppress an Annoying PA System Annunciator Tone?
  • Thread starter Thread starter XYZ343631
    Audio
The discussion centers on suppressing a 950 Hz audio annunciator tone from a public address system while still allowing the message to be heard. The proposed solution involves using a 567 tone decoder chip and a Picaxe 8M microcontroller to detect the tone and control a relay that blocks the audio signal during the tone's duration. The relay should be activated for a calculated time based on the longest expected speech duration. This method allows for local suppression without interfering with the global annunciator system.
  • Understanding of audio frequency detection, specifically around 950 Hz.
  • Familiarity with the 567 tone decoder chip and its applications.
  • Basic programming skills for the Picaxe 8M microcontroller.
  • Knowledge of relay circuits and their operation in electronic systems.
  • Research the specifications and programming techniques for the 567 tone decoder chip.
  • Learn how to program the Picaxe 8M microcontroller for audio signal processing.
  • Explore relay circuit designs and their integration with microcontrollers.
  • Investigate alternative methods for audio signal suppression, such as notch filters.
Electricians, audio engineers, and anyone involved in public address system management who seeks to optimize audio signal handling without compromising message clarity.
XYZ343631
I am searching for an easy solution for an exasperating nuisance.
There is a public address system at work and before the start of the messaage a loud audio annunciator frequency has been added to warn people of the upcoming message and I want to locally supress it but still receive the message.
The speaker is located just above my shop and do not want to interfere with the global annunciator but only this one speaker.
I am an electrican who was trained in electronics decades ago and my idea is that when the annunciator tone is present, rectify it and pick up a relay that starts a delay on timer that blocks the signal until timing is completed.
The annunciator tone is app. 900HZ to 1000HZ and centered around 950HZ as measured with an o'scope. The annunciator tone lasts for one second and is very disturbing and want to cancel it during that time and then have the timer close the circuit again to hear the message. That is it in a nut shell.
I tried using a standard bridge rectifer powering a 5V relay but the relay would not pick up and if I can pick up the relay then the local problem will be solved.
Please give me advice on how to accomplish my goal which will make all of the electricans happy in the electrical shop. Thanks for any and all responses.
Would it be easier to just put a notch filter inline that attenuated 950Hz, wouldn't have to be very narrow so not hard to design.
It would distort the voice a bit but should still be recognizable
The trouble with detecting the tone and turning it off is that unless you do some clever analysis of rise time etc, just detecting the frequency would mean you would also turn off the speaker when the person talking happened to hit that note.
- pf readers are all over the world in different time zones, but mostly in USA/Europe - so depending when you post you might have to wait 8-12 hours for anyone to see it.
The beeper tone should only be used in case of emergencies. Have you tried talking to the folks that manage the audio paging system? You should be able to make a case for only using the beeper for emergency messages. That's how many paging systems are run.
You could connect the speaker so that it only gets sound if a relay is pulled in.
Then you would need the following:
a source of regulated 5 volts.
a 567 chip
a Picaxe 8M chip
a transistor to pull the relay in.
Run the speaker input line to the 567 tone decoder chip.
This will make its output go low when the input tone matches the 950 Hz expected.
Take this to the Picaxe chip.
Program this to look for this low input on one of its pins.
Look again each 50 mS to see if it is still there.
When it isn't there any more, pull in the relay via the transistor.
Estimate the longest time anyone would talk on the PA and double it.
Leave the relay pulled in for that amount of time. (Easier than trying to detect speech on the line.)
Disconnect the relay.
If the 567 detects another message starting while the relay is still pulled in, the Picaxe can disconnect the relay while the tone is present. However, you may hear the beginning of the tone if this happened because the Picaxe would have to allow a period of 50 mS to be sure the tone was a sustained tone and not an accidental 950 Hz in someone's voice.
  • · Replies 23 ·
10K
