-aux.18.A fair coin is tossed 8 times.
  • Context: MHB
  • Thread starter Thread starter karush
The discussion revolves around the probability of obtaining heads when tossing a fair coin 8 times. Participants explore the application of the binomial probability formula, calculations for specific outcomes, and the reasoning behind the binomial coefficient.
  • One participant initially misapplies the probability formula, suggesting that the probability of getting four heads is calculated incorrectly as $\frac{4}{2}=4$.
  • Another participant emphasizes that probabilities must lie within the range of [0,1] and introduces the binomial probability formula: $P(x)={n \choose x}p^x(1-p)^{n-x}$.
  • Several participants attempt to apply the binomial formula, with one calculating $P(4)={8 \choose 4}.5^4(1-.5)^{8-4}$ and arriving at $\frac{35}{128}$.
  • Another participant suggests simplifying the expression to $\dbinom{8}{4}(0.5)^{8}$ and raises a question about the size of a computed probability, initially stating $46592$.
  • Corrections are made regarding the exponent in the probability calculations, with one participant concluding that the corrected answer should be $0.710938$ for part (a). Another participant confirms this correction.
  • A participant elaborates on the reasoning behind the binomial coefficient, explaining how it accounts for indistinguishable outcomes when calculating probabilities of heads in multiple trials.
  • Discussion includes the symmetry of the binomial coefficient and its implications for verifying identities in part (c) of the problem.
Participants generally agree on the necessity of the binomial probability formula and the requirement for probabilities to remain within the [0,1] range. However, there are discrepancies in the calculations and interpretations of specific outcomes, indicating that the discussion remains unresolved in some areas.
Some calculations presented by participants contain errors or misinterpretations, particularly regarding the application of the binomial formula and the resulting probabilities. The discussion also reflects varying levels of understanding of the underlying principles of probability.
This discussion may be useful for individuals learning about probability theory, particularly in understanding the binomial distribution and its applications in practical scenarios involving repeated trials.
karush
MHB
I know this a very easy problem, but trying to learn the probability formula's
(a) $P(H,H,H,H)= \frac{1}{2}+\frac{1}{2}+\frac{1}{2}+\frac{1}{2}
=\frac{4}{2}=4$
or is there another better way to do especially if the problem is much bigger and more complicated.:confused:
You should observe that when you obtain a probability that is not on $[0,1]$ then you have made an error. A probability can range from 0 (impossible) to 1 (certain).
For this problem, you want to apply the binomial probability formula:
$$P(x)={n \choose x}p^x(1-p)^{n-x}$$
where:
$n$ is the number of trials
$x$ is the number of successes
$p$ is the probability of success for each trial
Can you identify the value of each variable for part a)?
where:
will try..
$\displaystyle P(4)={8 \choose 4}.5^4(1-.5)^{8-4}$
this is $= \frac{35}{128}$ ??
karush said:
will try..
You can write simply as $\dbinom{8}{4}(0.5)^{8}$.
So c) becomes $\sum\limits_{k = 3}^5 {\dbinom{8}{k}{{(0.5)}^{ 8}}} $
i got $46592$ is it really that large?
No. That should be a positive 8 for the exponent. Like MarkFL said, all probabilities must be between 0 and 1. If you get anything outside of that range then you've made a mistake.
ok, corrected, it ans should be then $0.710938$
so should (b) b in W|A
Binom[8,3]*.5^8=0.21875
You were right the first time.
I wanted to say a few words about the binomial probability formula. To see why the binomial coefficient is required, consider the following:
We are going to flip a coin $n$ times and we wish to find the probability that we get $m$ heads, where $0\le m\le n$. So let's draw $n$ place holders to represent the $n$ trials, or flips of the coin:
__, __, __, ..., __ (there are $n$ placeholders)
Now, for the first head, we have $n$ choices where we may place it. For the second head, we have $n-1$ choices, and so forth all the way down to $n-m+1$ for the last or $m$th head. Using the fundamental counting principle, we can calculate that there are:
$$n(n-1)(n-2)\cdots(n-m+1)=\frac{n!}{(n-m)!}$$
ways to make our choice. But, we have to consider that there are $m!$ ways to make each choice, since the order in which the same sequence of heads and tails is chosen does not matter, the result is the same. For example, suppose we are flipping the coin 3 times and we wish to calculate the probability of getting two heads.
So, as one possible outcome, we choose first the third trial to be a heads, and then the first trial to be a heads. This is identical to having chosen first the first trial to be heads and then the third trial to be heads. Both choices results in heads, tails, heads...they are identical and indistinguishable outcomes. So we need to divide by the number of ways to choose the same outcome, which is the factorial of the number of favorable outcomes. In other words, there are $m!$ ways to order $m$ objects.
So we may conclude that there are:
$$\frac{n!}{m!(n-m)!}={n \choose m}$$ ways to choose $m$ from $n$.
This is where the binomial coefficient comes from in the binomial probability formula. Then we take the product of all the probabilities, as the other factors in the formula, $m$ favorable and $n-m$ unfavorable. For each trial, where there are two possible outcomes, it is certain that one or the other outcome will happen. Suppose that $p$ is the probability for a favorable outcome for each trial. Let $q$ be the probability of the other or unfavorable outcome. Mathematically, we may state the certainty of either outcome occurring as:
$$p+q=1\,\therefore\,q=1-p$$
Now, putting everything together, we find that the probability of obtaining $m$ favorable outcomes during $n$ trials is:
$$P(m)={n \choose m}p^m(1-p)^{n-m}$$
Something we can sometimes use to simplify our calculations is the symmetry of the binomial coefficient, that is, the identity:
$${n \choose r}={n \choose n-r}$$
Do you see how you can use this in part c) of the given problem? Can you use the definition above of the binomial coefficient to verify this identity?
We should expect to find that the sum of all the possible probabilities is 1, and indeed we see (using the binomial theorem):
$$\sum_{m=0}^n{n \choose m}p^m(1-p)^{n-m}=(p+(1-p))^n=1^n=1$$
I hope this helps, as I find that when I understand where a formula comes from, it is much easier to remember and use. :D
  • · Replies 41 ·
9K
  • · Replies 16 ·
  • · Replies 45 ·
  • · Replies 16 ·
